May 3, 2009, 05:06 PM
#46
Silver Sponsor +1
Personal Sales Rating: ( 445)
Drives: 2008 Evolution GSR SSS, 2005 Evolution MR, 2003 Evo GSR, 1995 TsiAWD, 1995 GST, 1995 Tsi 2wd, 1991 GVR4 WW, 1991 GVR4 NBM, 1993 TsiAWD, 1991 Tsi, 1995 RS N20
Quote:
Originally Posted by R/TErnie
If you need that much flow to find a leak YOU'RE DOING IT WRONG.
Having sufficient flow on tap allows one to fix leaks while the leaks still exist. You have 0-35psi on tap that will not take 10 minutes to build up those pressures.
I've been doing boost leak tests for 14 years.
__________________
2005 Evolution VIII MR
763whp/595tq HTA86
10.19 & 143.3mph stock ECU
Factory ECU Expert
2008 Evolution X GSR
12.0@113mph Full Wt+
In House Mustang Dyno AWD-500!
www.ttp-engineering.com
(407) 475-0010
AIM=TTPEngineering
MODIFYING THE 4G63 SINCE 1995, YES 14 YEARS!
TUNING EVO V - EVO X & 2009 RALLIART!
TTP's Myspace page!
Offline
May 3, 2009, 05:12 PM
#47
Personal Sales Rating: ( 3)
Four ****ing pages dedicated to doing a boost leak test. I'm in awe, ****ing sad.
Offline
May 3, 2009, 05:21 PM
#48
Personal Sales Rating: ( 0)
Location: I'm Canadian living and working in Dubai/Kuwait/Bahrain
Drives: 08 Yamaha R1/06 Evo IX/99Yamaha R1
^ it took 4 pages to understand why air was getting into the oil system bud... knowing the reason behind it and getting input from professionals makes me feel a whole lot better... after all that's what this forum is for...
dxbtune
Offline
May 3, 2009, 06:39 PM
#49
Offline
May 3, 2009, 11:20 PM
#50
Personal Sales Rating: ( 2)
Drives: TB Evo IX
What I'm saying is... if you can't find a leak that needs more air volume than a schrader valve supports, then you don't need an air leak tester to find that you didn't put a coupler back on. Either that or you need to turn down your radio. It takes a matter of seconds (2-3) to pressurize the whole system through a schrader valve... so don't tell me it takes too long.
The length of which you do something doesn't correlate to the correctness of how you did it.
__________________
11.1@129mph - 521whp via Dynojet
Offline
May 4, 2009, 02:45 AM
#51
Personal Sales Rating: ( 27)
2005 Mitsubishi Lancer Evolution
Drives: '05 Tarmac Black SSL VIII
Uh... the ole schrader valve works quite well and can pressuirze the system in a few seconds, and this as at 25 psi... If you have a leak its not rocket science, nor should it take 10 minutes trying to figure out where the leaks coming from.... why try to over engineer it...
Tom no problem buddy, let me know if you need anything else okay!
__________________
FP Red*Greddy ProfecB Spec II*HKS TT*Nesei Short Route IC Piping*Synapse BOV*COMP 272s*Injen Intercooler*AFE Power Dry Filter*R/TErnie Intake*R/TErnie FULL 3" O2 housing with V-band*R/TErnie Modified DCsports 3" Down/Test/Flexpipe with V-Band*Greddy Ti-C Exhaust*255lph*Tein S-Techs*18" Volk LE-28s*Progress 25mm Rear Sway*Project Mu pads*JDM Tails*Cusco Heat Shield*Mishimoto Radiator hoses/Cap*ARC shift knob*Injector Dynamics 1000cc...
Offline
Jun 21, 2009, 10:33 PM
#52
Personal Sales Rating: ( 8)
Drives: EVO\\\, 4g64 Mighty max, Gmc Acadia, Yota Tundra
So is this normal op? am having this issue with stock turbo, i hear gurgling in crankcase, while oil cap is off. I pressure test the whole system. am gonna eliminate turbo, and pressurize at ic inlet tomm..
__________________
380whp/340wtq Mustang dyno
Stock 8 turbo @25psi
E85 clean air vehicle (:
GST Motorsports tune
Offline
Oct 11, 2009, 08:42 AM
#53
^so, what did you find?
car runs strong no white smoke nothing, been 5 months now, no burning oil more than normal.
GT series turbo design I'm almost damn sure of it.
Offline
Oct 11, 2009, 09:16 AM
#54
Same for me, the tire valve works great. A few seconds of compressed air and I'm up to 20-25psi on my boost guage.
Offline
Tags
boost, bov, burst, check, control, evo, hook, inlet, leak, mitsubishi, motorat, r1, right, synapse, test, testing, turbo  |
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
HTML code is Off
