May 1, 2009, 02:19 PM
Personal Sales Rating: ( 1)
Drives: 2003 evo 8
+1 i had a post on this a few months back. my car does the same thing. air comes out of the valve cover when i boost leak test. never got a answer. i suspect something with the turbo because it never did it with the stock turbo.
Offline
May 1, 2009, 02:25 PM
Personal Sales Rating: ( 0)
Location: I'm Canadian living and working in Dubai/Kuwait/Bahrain
Drives: 08 Yamaha R1/06 Evo IX/99Yamaha R1
There are 2 lines connected to the wastegate...
1 to the boost controller solenoid (vacuum)
1 to the vacuum/boost line
but then again this is on the hot side guys...
i think the culprit is the oil feed line for the turbo but how the heck does that leak only one way because wouldent you think the oil pressure would make the oil flood into the cold side when idling.... no oil!! clean as a whistle...
ok removing the feed line would pinpoint but right now its hard for me to do that job as its a big and messy job if need be i will do it but i would like to avoid that especially if its not the problem..
Offline
May 1, 2009, 02:28 PM
Quote:
YES exactly like me stock turbo did not do it... this setup its the first time to boost leak test and this is what i'm getting...
Offline
May 1, 2009, 02:33 PM
Drives: 06 Rally Red MR
It's normal to have some pressure vent at the valve cover ONLY IF you do a normal boost leak test, in which you leave the throttle body connected, and pressurize the entire engine. Some of the valves are open and pressure will leak slowly past the rings into the crankcase - and vent.
The OP in theory should be able to completely seal the system he is testing, as he is NOT connected to the intake manifold.
Offline
May 1, 2009, 02:40 PM
Drives: vi rs
Quote:
Originally Posted by travman
Whoever told you to do a boost leak test like that - never take advice from them again.
- Put your UICP back onto the TB, tighten it down and start pressurizing again.
Yo buddy! Are you high or something? This guy has a very nice test going to determine if there is any leak in the I/C pipe. Once he is sure there is no leak in the IC pipe, he can put back the UICP on the TB and move on to testing the TB.
What don't you understand about that?
__________________
10.7 granny shifting - http://www.youtube.com/watch?v=sOEL7uGJIuc
Autronic, 2.4l, MAD spec piper cams, AMS kit, FP HTA 35R, RC 3" exhaust, AIM Dash, Kansai inlet, q45 TB, Buschur COP
Tuned by Mark Shead
Offline
May 1, 2009, 02:42 PM
Drives: vi rs
+1 on those points.
__________________
Tuned by Mark Shead
Offline
May 1, 2009, 02:44 PM
yes slipped my mind there absolutely right...
perhaps this turbo has a one way valve system...
lets break it down.... doing a compression test in this case is compressing air before the blades where in normal running condition the compression will happen after the blades....
is it possible that the design is to allow the aspirated low pressure air before the compression stage into the system and with the boost test i'm actually creating a pressurized state before the compression stage?
sounds like astronomy but read it a few times to get my point...
Offline
May 1, 2009, 02:46 PM
be right back, taking a pic of the intake part of the turbo to show you the design feature im talking about..
Offline
May 1, 2009, 03:05 PM
ok so here we are, with what said earlier.. there is a cone inside the intake supported by three screws to centralize it and possibly there is a one way valve incorporated in there or something...
apparently the design is to allow the air to flow more smoothly and doubt it has anything to do with my issue but might as well show a clearer picture of the situation i am facing
Offline
May 1, 2009, 03:14 PM
I think I followed that  Are you talking about an anti-surge compressor housing? If so, it just allows over-boost to equalize back to the low pressure area in front of the turbo inlet:
That would not change anything about your boost leak test.
Offline
May 1, 2009, 03:21 PM
Drives: nitrous built dohc vtec 94 ej1
well theres your problem right there,u have it set to M for mini. when u should have it set to W for wombo
__________________
looking for a special edition apex silver or graphite grey evo 9 in central florida area.
Offline
May 1, 2009, 03:48 PM
well thats clarified.....
now back to the strange situation im facing....
Offline
May 1, 2009, 05:38 PM
bump
Offline
May 1, 2009, 09:52 PM
Personal Sales Rating: ( 5)
Drives: evo 8
holy shiet...i laughed when i read how you did the boost leak test first..lamo..sorry
__________________
mods: Agency power turbo kit, GARRET dbb gt35r, Ap intake, custom licp , FORGE mbc, JGT catback, PERRIN test pipe, , AEM wideband, EXEDY stage 2 PP with ACT 6 puck, ACT streetlite FW , WALBRO fuel pump, FORGE bov, huge ebay front mount, HKS 280s, 1000cc injectors, ARP headstuds, AMS mini battery with ams battery tray, omni power coilovers, WingzPerformance tune
http://i188.photobucket.com/albums/z...e/e85ftw-1.jpg
best 1/4 mile time on e85 (8 turbo)
12.2 @ 116mph
Offline
May 1, 2009, 10:11 PM
2004 Mitsubishi Lancer Evolution
Has any one thought simple...?
Any one ever felt the air that comes out of these power pumps that run on electricity vs. the ones that are in a big air tank. It looks the a little travel unit... I am no expert, and am not claiming to be, just read through the post, visualized, inspected, and have a theory...
That little air pump probably gets real hot. I would have to say that hot air rises. One, could a valve be open, and as the air goes through the blower side of the turbo, could it be warm enough to rise through the exhaust, or through the oil line, to bubble any where that is up. 2nd thing, its pressurized, which makes it move or travel that much faster, fill every ounce of open space, even if it is the minutest of cracks. Doesnt matter which end of the mattress the pump blows air, it all pressurizes the same. Oil may be thick, but oxygen or compressed air still rises through it. And if you think about a valve that only moves one way in circulating system, could this be a design flaw by Mitsu, and they actually reversed the valve so it opens up stream, instead of down stream...I would doubt this one.
Then I read this:
I would imagine that even with the ic pipe off, that it could still be something in this area. Just because the UICP is open, he still has it sealed, if you think about it, the butterfly on the other side to the intake, is sealed as well. A seal is a seal, either way, air still travels the same way, and I would imagine that you answered the question with this idea. Good job dude. So I second your theory, and would bet by doing a TDC, or whatever closes the valves the most, should help test this theory. Then if no leaky leaky, you have your anser.
Just my 2 cents here.
__________________
Raceghost
FOR SALE: Cobb Access Port unmarried with EVERYTHING in the box. $300 OBO Shipped....MAKE ME AN OFFER.
Wanted: Used FP White, or Green. PM me details.
04 Mitsubishi Evolution VIII "Black Betty" (...325 WHP and climbing)
Personal thanks from the RG team to
Tephra, MRFred, MAPerformance, Appauldd, Fostytou, John Bradley, Jack_of_Trades.
My Space
Black Betty Centerfold
Offline
Tags
boost, bov, burst, check, control, evo, hook, inlet, leak, mitsubishi, motorat, r1, right, synapse, test, testing, turbo  |
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
HTML code is Off
