Jul 29, 2009, 05:32 AM
#196
Personal Sales Rating: ( 5)
Drives: Evo VIII/SVO Mustang/BMW E30 M3
The only outstanding issue involves the size of the throttle shaft wheel, and it takes all of about 1 min to replace it on the car. I'm working with Hypertune to resolve it right now, so it will soon be a non-issue, one way or another.
__________________
Ted B. Spec JAM LR 2.0L - Headway Perf CNC Head - DI Int Man - 75mm Hypertune TB - HTA3582 TS 1.06 A/R T4 - 12mm lift Billet Cams - MPFab TS T4 Manifold, TBE, UICP, LICP - MPFab FMIC - TiAl 44mm WG - Skunk2 Pro Cam Gears - FIC Bluemax 1250cc - FullBlown Dual 255lph - Synchronic BPV - Spark Tech COP Ignition - TRE Trans - Shep TC + LSD - SPEC Super Twin P-Trim Clutch
Offline
Jul 29, 2009, 06:14 AM
#197
Personal Sales Rating: ( 1)
Drives: EVO VII JDM
Quote:
Good Luck ...
Offline
Aug 27, 2009, 06:49 PM
#198
Personal Sales Rating: ( 0)
Drives: EVO1
any updates Ted?
Offline
Aug 28, 2009, 06:11 AM
#199
Still awaiting the replacement Hypertune TB ...
We've determined that the spring pressure on my Hypertune TB is enough to significantly compress the rubber grommet at the end of the throttle cable that is attached to the pedal. When this happens, it reduces cable travel significantly.
Aside from that, the engine is running very well, and I am tuning and tweaking as I have time. The CNC port job and 12mm lift cams really make the 2.0L engine feel torquey.
__________________
Offline
Aug 28, 2009, 12:28 PM
#200
Personal Sales Rating: ( 22)
Drives: 08 Sti, Discovery II, 07 cbr1000rr
Still waiting? Jesus christ. At this point slap on a ported stocker and be done with it!
Offline
Aug 28, 2009, 12:36 PM
#201
Silver Sponsor +1
Personal Sales Rating: ( 461)
Drives: 2008 Evolution GSR SSS, 2005 Evolution MR, 2003 Evo GSR, 1995 TsiAWD, 1995 GST, 1995 Tsi 2wd, 1991 GVR4 WW, 1991 GVR4 NBM, 1993 TsiAWD, 1991 Tsi, 1995 RS N20
Quote:
Or better yet Ted...
Official Boomba 75mm Big Bore Throttle Body Review and Dynotesting by TTP!
__________________
2005 Evolution VIII MR
763whp/595tq HTA86
10.19 & 143.3mph stock ECU
Factory ECU Expert
2008 Evolution X GSR
12.0@113mph Full Wt+
In House Mustang Dyno AWD-500!
www.ttp-engineering.com
(407) 475-0010
AIM=TTPEngineering
MODIFYING THE 4G63 SINCE 1995, YES 14 YEARS!
TUNING EVO V - EVO X & 2009 RALLIART!
TTP's Myspace page!
Offline
Aug 30, 2009, 07:03 AM
#202
The Boomba is the fallback option. I just dread the idea of pulling the manifold and sending it back to Tom of DI to be reflanged. We'll see if the Hypertune TB is waiting when I return home on Wed.
__________________
Offline
Aug 30, 2009, 07:17 AM
#203
Drives: 2003 Evolution
Bummer - hope you can get it fixed and back onto the road soon.
Online
Aug 30, 2009, 07:19 AM
#204
The car is on the road and running well, it's just that so long as this TB has excessive spring tension, it cannot open the throttle valve to the full WOT position.
__________________
Offline
Aug 30, 2009, 12:26 PM
#205
Personal Sales Rating: ( 2)
Drives: C5 Z06
That is no fun at all. Need to fix that TB so you don't damage your throttle cable.
__________________
C5 Z06
evo9 11.554 @ 122.73 (sold)
Offline
Tags
0w20, 94, bearing, bearings, bmw, cam, clearances, engine, evo, failure, knock, magnetic, remachining, rod, run, tighter, tsi  |
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
HTML code is Off
