Apr 22, 2009, 07:20 AM
Personal Sales Rating: ( 17)
Drives: 2005 Evolution VIII
My Engine Build w/pics (Drop-In Setup)!!
Offline
Apr 22, 2009, 07:35 AM
Some of my mods:
Manly H-Beam rods
Wiseco 9:1 CR Std. Bore pistons w/Upgraded wrist pins (1400HD pins)
Cosworth 1.3mm Headgasket
ACL Race bearings
Arp Headstuds
Supertech Springs w/Titanium retainers
GSC S2 cams
UR cam gears
ETS HTA 35r equal length turbo kit
ETS 3.5" FMIC
ETS Full short route intercooler piping kit
FIC 1450cc inj.
Aeromotive -10AN fuel rail
Full blown twin 255lph walbro setup
-10AN SS feed line and -8AN return w/Aeromotive FPR
Turbo XS 3" TBE
MilSpec 65mm TB
Ported/Gasket Matched Intake Manifold
SparkTech COP ignition
...probably forgetting some, but think I covered the important stuff
Offline
Apr 22, 2009, 10:33 AM
Personal Sales Rating: ( 5)
Drives: evo 8
that looks nice...so did you hone the block??
__________________
mods: Agency power turbo kit, GARRET dbb gt35r, Ap intake, custom licp , FORGE mbc, JGT catback, PERRIN test pipe, , AEM wideband, EXEDY stage 2 PP with ACT 6 puck, ACT streetlite FW , WALBRO fuel pump, FORGE bov, huge ebay front mount, HKS 280s, 1000cc injectors, ARP headstuds, AMS mini battery with ams battery tray, omni power coilovers, WingzPerformance tune
http://i188.photobucket.com/albums/z...e/e85ftw-1.jpg
best 1/4 mile time on e85 (8 turbo)
12.2 @ 116mph
Offline
Apr 22, 2009, 11:33 AM
Personal Sales Rating: ( 26)
Drives: 05 Silver Evo 8.5, 03 TB Evo 8 Project, 03 Flat Black Evo 8 daily, 07 R1... Also Sievers' 2.3L Evo 8 @ 40+ psi
Yea that things going to be a beast. Nice pics.
Offline
Apr 22, 2009, 12:43 PM
Quote:
the block/motor was so "green" that all we did was check all the cylinder bores/all clearances and then used a ball hone. All cylinders were rechecked afterwards and we made sure that the clearances were on the "conservative" side as per Mitsu, Wiseco, and Manley
Offline
Apr 22, 2009, 01:15 PM
Personal Sales Rating: ( 2)
Drives: EVO IX GSR, 09 FX35, Jag X-Type
Excellent thread mate!
I am building my motor too next month with similar parts. The same wiseco pistons, h-beam rods but I went with carrillo, cosworth gasket too, ferrea valvetrain (behive), and I will also use a fluidampr damper.
Most probably I will also do an HTA upgrade from my 3065 plus the regular supporting mods...
Offline
Apr 22, 2009, 01:39 PM
Personal Sales Rating: ( 9)
2003 Mitsubishi Lancer Evolution
Drives: 2003 Apex Silver Evo 8
Looking good Mike  Mojo Motorsports FTW!!!!!
Offline
Apr 22, 2009, 02:18 PM
Quote:
yes sir! Only snags we ran into is that the wg recirc tube the ETS uses to bolt onto the dp didn't fit and hit/made contact w/the o2 housing. They also forgot to include the oil feed adapter for the oil inlet on the HTA 35r. Adam is going to call them to find out why the recirc tube doesn't fit right.
Offline
Apr 30, 2009, 04:12 PM
car is all together and took her out today to do some tuning on wg boost..so far i'm hitting full spool at 4k rpms@15psi with the HTA 35r and a .82 A/R turbine housing. Once I get my Turbosmart dual stage boost controller i'm going to be running 23psi or so on 93oct and 33psi or so on E85...all on stock ecu
Offline
May 3, 2009, 06:44 PM
Quote:
Very nice bro
Offline
May 3, 2009, 06:47 PM
Personal Sales Rating: ( 16)
Drives: 03 Evo VIII
Sounds like its going to be a beast!
__________________
2003 EVO 8: Sold
2003 Black Terminator...UPR CAI, UPR Short Throw, Bassani Cat Back, BF 2.76 Upper w/Idlers, BF IRS Brace, Accufab TB, H&R Race Springs, MM Caster/Camber Plates, Evenflow Mod.
Offline
May 3, 2009, 06:49 PM
Personal Sales Rating: ( 4)
Drives: 03' Evo
sweet! Congrats! Very Nice!
__________________
Built by the DTM Crew
Tuned by Nick@DTM
DTM Built Head
DTM 2.3L Block
DTM Twin Scroll Big Turbo
499awhp/422awt on pump gas@25lbs
Offline
May 3, 2009, 07:13 PM
Drives: 03 Evo 8, 05 Suzuki GSX-R 600, 88 MX-6 Turbo
Post your compression results.
__________________
255/40/17 Falken Azenis RT-615s on stock Enkei rims, TEIN Flex coilovers with TEIN EDFC, Walbro 255, Helix V1 272 cams, Hawk HPS front & rear pads, HKS turbo timer, Perrin Turbo Back, Perrin straight pipe, HKS RS intake, IX BOV, Hallman MBC, A/C delete, Ebay manifold + o2 housing, ebay FMIC, Exedy Twin plate, Flashed by Jestr, other ECU tricks performed by Kreionic, Stock 03 turbo, stock 9.8 hotside. 350whp & 322 ft-lbs using 93 octane. 12.3 secs @ 114mph
Offline
May 3, 2009, 07:17 PM
Personal Sales Rating: ( 15)
Drives: evo8MR + subi RS +08 Lancer
those pistons look sooo pretty campared to my stock ones wen i took my head off
__________________
Lots o' bolt on's... suspension, brakes, motor
327awhp/304awtq est. DLL @ roughly 23psi
New time:
12.13@113_____stock block, head, turbo... 6speed
Offline
May 3, 2009, 07:23 PM
Silver Sponsor
Personal Sales Rating: ( 97)
very good man, looking ofward to the results of this combo GL
__________________
Buy AMSOIL directly from our web site or PM us for direct pricing:
http://www.lubedealer.com/order/
Get Your AMSOIL @
-AWDmotorsports in South Florida
-TTPengineering in Central Florida
-Fynetune Performance in South Florida
-Brevard Super Bikes in Melbourne Florida
-Henrry's Pit Stop in the Saucier City, MI
-Harrison complete auto service, in West Orange City, NJ
-Ultimate CC, in Peekskill NY
-Performance Specialties, in Tucson AZ
Offline
Tags
45, 89, bender, build, built, check, engine, ets, evo, evoloution, evolution, fender, hp, motor, set, small  |
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
HTML code is Off
