Go Back   evolutionm.net > Lancer Evolution 1-9 Forums > Evo Engine / Turbo / Drivetrain
Welcome to EvolutionM.net!
Welcome to EvolutionM.net.
Old Oct 6, 2009, 08:34 PM   #31
Personal Sales Rating: (17)
Drives: 2005 Evolution VIII
turned out to be a defective rod bearing...a huge chunk was ripped out of the #2 rod bearing. I should be back up and running by this friday
__________________
05 EVO VIII. 565whp/422 tq @ 33psi (new #'s soon)on E85...Powered by Headgames, Buschur, ETS, and MMS Performance!
Offline
Old Oct 10, 2009, 11:32 PM   #32
car is up and running strong with a new set of bearings...next problem is a slipping brand new spec super twin "ss trim" clutch. Not happy about this next problem at all...
__________________
Offline
Old Oct 10, 2009, 11:41 PM   #33
Silver Sponsor +1
Personal Sales Rating: (445)
TTP Engineering's Avatar
Drives: 2008 Evolution GSR SSS, 2005 Evolution MR, 2003 Evo GSR, 1995 TsiAWD, 1995 GST, 1995 Tsi 2wd, 1991 GVR4 WW, 1991 GVR4 NBM, 1993 TsiAWD, 1991 Tsi, 1995 RS N20
Send a message via AIM to TTP Engineering
Personally, I think you wasted your time. The stock motor will be reliable with good tuning on E85 and proven to 600whp+.
You are better off keeping the stock bottom end and maybe swapping rod bolts than you are honing an in car drop in build. Contamination from honing, clearances being correct, cylinder bore consistency, wrist pin fitment and getting a ring seal as good as the stock pistons had are areas of concern.
Furthermore you increased compression ratio to 9.0:1 pistons, then lowered it back down again with a thick Cosworth headgasket which was a waste.
__________________
2005 Evolution VIII MR
763whp/595tq HTA86
10.19 & 143.3mph stock ECU
Factory ECU Expert
2008 Evolution X GSR
12.0@113mph Full Wt+
In House Mustang Dyno AWD-500!
www.ttp-engineering.com
(407) 475-0010
AIM=TTPEngineering
MODIFYING THE 4G63 SINCE 1995, YES 14 YEARS!
TUNING EVO V - EVO X & 2009 RALLIART!
TTP's Myspace page!
Offline
Old Oct 10, 2009, 11:54 PM   #34
Silver Sponsor +1
Quote:
Originally Posted by E85evo8 View Post
may not be possible now as my machine shop built motor might be eating through a bearing as we found some metal in the oil filter and pan so hopefully know more later on today...I'm pissed!
Wow... I can't say that I am surprised.
I did not read the whole thread or get to the last page until my post showed up.
Basically what I wrote in the above post seems to have held true. You lost the engine shortly after the build.
What concerns me even more is that you believe that there was a "defective rod bearing". I don't believe that for a second. They don't just fall apart on their own.
Furthermore if you did not replace your oil cooler, your motor WILL fall apart again as the metal from the damaged bearing recirculate the oiling system and spread back throughout the engine again.
Lastly, it would be a RARE occurance to have bearing damage without CRANK JOURNAL damage so if you just replaced your rod bearings and put the engine back together, I am sure that we will see you posting a new update shortly that the same rod bearing spun again in the first 500 miles.
Sorry to be the bearer of bad news, but there is a reason we do NOT recommend drop in builds. They will never be setup for reliable use and there is A LOT that goes into building a PROPER engine build.
__________________
763whp/595tq HTA86
Factory ECU Expert
(407) 475-0010
AIM=TTPEngineering
TTP's Myspace page!
Offline
Old Oct 11, 2009, 10:05 AM   #35
Just to clarify, I should have said this earlier after much deliberation I decided to pull the balance shafts, have the clearances checked, rotating assembly balanced etc...this ISN'T a drop-in setup anymore despite the title of the thread. oil cooler, lifters, and entire head and block was replaced and/or hot tanked, flushed etc. The current motor has a brand new crank, bearings, etc.
The motor as it sits now was built by a competent machine shop that is very familiar with evo's or the 4g63 motor. It now has Eagle rods, Weisco 1400HD pistons, stock head gasket, Clevite bearings, ARP main studs, etc...
The last issue was something of a "freak" occurence that the machine shop has never seen before. The #3 rod bearing lost a chunk of material that apparently was due to a manufacturing defect. We picked it up before it got bad by cutting open the oil filters. It did not spin the bearing. There was a small divot in the bearing going down to the steel with the surrounding bearing surface undamaged, weird. Machine shop insisted that it is a defect. It did not damage the crank journal. As of now the motor is back up and running strong on 33psi and E85
__________________
Offline
Old Oct 16, 2009, 09:45 AM   #36
Update: almost 500 miles on her and still going like a raped ape!! I will keep updating this thread once I get some 1/4mile times
__________________
Offline
Tags
45, 89, bender, build, built, check, engine, ets, evo, evoloution, evolution, fender, hp, motor, set, small
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
