FP Red with only meth and TBE
Old Apr 8, 2009, 09:30 AM
lemmonhead's Avatar
How much power can be had if your mods are only full TBE and Meth/water injection with the FP red Turbo?
So far all the threads show guys with extra mods like cams, 02 housings...
Im around 360HP with the stock Turbo w/meth
is 420HP possible without more mods?
Old Apr 8, 2009, 09:53 AM
EvoM Moderator
scheides's Avatar
The problem is, you will be out of fuel, so your short list instantly becomes longer by the need to also do injectors and fuel pump.....then the fact that if you're gonna bolt on a turbo like that (I have a BBK) you should do a ported manifold and SS o2 housing as well. Go ahead and try it and report your results! I think this would be cool to see
Old Apr 8, 2009, 09:57 AM
justa4banger's Avatar
i would get all supporting mods first, build your way around so when you do get a red your at 550whp
Old Apr 8, 2009, 10:31 AM
deuce329's Avatar
Just add 02 housing $150 or less, Fuel Pump $80, 880cc Injectors $300, LICP $150, MBC $75 to the TBE and your good to go with a Tune
And Clutch bc the stock one will go fairly quick with that power level
You can use the stock intercooler and UICP but it is holding you back on power. Get all the supporting mods first b4 you put on the RED.
Old Apr 8, 2009, 11:07 AM
awdrivin's Avatar
personally, the FP Red is in a class all to itself...
with the Green and White, you can use stock parts to achieve your power goal. With the Red, you need fuel to support your power goals.. above 350whp or so, you're going to need fuel support to be on the safe side. If you want to be safe with the Red, like said above, fuel pump w/ 880's, FMiC w/ piping, and a 3 inch exhaust, you could achieve 400 whp easily.
Old Apr 8, 2009, 11:22 AM
Boltz.'s Avatar
Thats a nice and simple mod path. People will try to tell you to do all sorts of other bolt ons but the fact is, the car will be fast with a red, tbe and meth. Period.
420whp is VERY possible.
Old Apr 8, 2009, 11:40 AM
detroit pistins's Avatar
what are u planning on boosting at ?
and can u guys also mention what ur boosting #'s are just to get an idea of how much everyone is boosting to achieve those numbers above.
Thanks
Old Apr 8, 2009, 11:44 AM
BenJ's Avatar
I would at least through in a K&N drop in filter as well. So for the bare minimum to run a red, you will need a walbro 255, some bigger injectors, and an intake of some sorts, whether it be a kit or just a drop in. So that's what:
Red- $1800
K&N drop in- $40
Walbro 255- $80
750-880 Injectors- $350
Tune- $450
$2720
That's the basics
Add Meth and your looking at an additional $1000 on top of that, depending on the kit that you go with.
By running meth 50-50, you should be able to keep your IAT's lower, so that will help with the cooling, however on a stock intercooler you see some major heat soak after a pull or two.
Old Apr 8, 2009, 11:47 AM
Boltz.'s Avatar
Red- $1800
K&N drop in- $40
Walbro 255- $80
Tune- $450
$2720
That's the basics
Water/meth will greatly reduce the need for an upgraded intercooler.
Old Apr 8, 2009, 12:09 PM
BenJ's Avatar
I agree from first hand experience. However, still, with a red pushing 29psi + on meth, you are going to heat soak the stock IC very quickly, once again from personal experience. The stock IC starts to see heat soak very quickly even on the stock turbo after back to back pulls.
Old Apr 11, 2009, 09:31 PM
Screech's Avatar
So what size Injectors should he be running with supporting mods? cam, intercooler, meth and such. I was thinking 720 with a stock turbo. 880 on a gt35r. Some people I have been seeing with 1000cc. I searched and still searching for answers.
Edit: Ahhhh o.k found this link from another thread. For figuring the injector size required- http://rallyevo.com:8080/injectors.php
Old Apr 12, 2009, 06:01 AM
wiggam11's Avatar
i am doing the same thing alol my mods are in sig and ordered parts im getting 880's and epm o2 housing and ordered a fp red ported from buschur, might want to run head studs just ot be careful im shooting for 400whp or more
Old Apr 12, 2009, 07:29 AM
pls1968's Avatar
Just an FYI...... For all of us running the RED. FP after June will not be doing any warranty repairs on the turbos if you're not running the upgraded oil line. I've already got mine on order. So do yourself a favor and get. It's worth the investment.
Old Jun 8, 2009, 07:04 PM
lemmonhead's Avatar
why do you guys say upgrade the intercooler and adding fuel pump and injectors.Shoot at 27psi boost with meth I had to drop my fuel map by like 1 full point to get 11.8-12.0 a/f. so I cant see adding say 80HP i would need a fuel pump and injectors especially when im at around 70-80% IDC and we all know 110 IDC is starting to reach the limits. Shoot mellon as I recall was running 120IDC's with no problems.
Old Jun 8, 2009, 07:05 PM
lemmonhead's Avatar
I will however be ording the Neisi LICP. I already have a MBC.
Quick Reply: FP Red with only meth and TBE
