Can't boost past 10psi...wastegate and vacuum lines ok!!
Old May 23, 2010, 09:31 AM
  #46
casper980's Avatar
found my problem...see here
https://www.evolutionm.net/forums/au...rx6-turbo.html
Old May 23, 2010, 10:48 AM
  #47
EvoHung's Avatar
Guys, last night my car had problems boosting pass 10psi, it would aslo backfire. Today, I switched my spark plugs and it boosting at 21psi again.
Might not be the problem but easy enough to try first.
Old May 23, 2010, 09:28 PM
  #48
evolved0414's Avatar
What kind of plugs are you running?
Old May 25, 2010, 05:50 AM
  #49
EvoHung's Avatar
I was running the BPR7ES but I guess it was due for them to be changed out.
Old May 25, 2010, 02:33 PM
  #50
DrewPinoy85's Avatar
Yeah, I'm having similar issues, I'm maxing out at 15/16psi sometimes 17 pounds. No audible leaks, but I suppose a boost leak test is in order, although I have been having similar, albeit less drastic, symptoms as Scarface2jz..... slight rattling in the exhaust and I did hear a slight pop 2-3 weeks ago prior to it dropping in psi.
But the thing is it spools up just fine and reaches ~15psi no problem, just levels off there though.
Honestly I hope it is the exhaust, it'll just give me another excuse to replace the stock unit lol...
Any recommendations on pressure testers?
Old Mar 16, 2011, 07:10 PM
  #51
awdordie's Avatar
Bump for answers seems everyones having problems including me. Im hitting a massive 14psi and have checked everything. Only thing I found was a crack in my manifold however its been there since I got my evo so I doubt this is my problem.
Old Mar 16, 2011, 08:31 PM
  #52
05VIII's Avatar
are you guys running cat's? if so thats the first place to check. those things like to blow up and clog the exhaust causing symptoms like described.
Old Mar 16, 2011, 08:39 PM
  #53
Brsox10288's Avatar
Boost leak check, it could be ur Tb Shaft Seals... I lost 6 psi from a bad leak from there..
Old Mar 24, 2011, 02:48 PM
  #54
awdordie's Avatar
Unfortunately im catless running a test pipe. I found a crack in my manifold halfway around the #4 runner which is prob causing some of my problem. However I don't think its causing all my problem. I wont know for sure until I get it swapped back to the stock one.
Ekoy
13
Apr 12, 2016 05:32 PM
Raziel
11
Jun 13, 2014 02:44 PM
Adi489
22
Aug 14, 2013 02:18 AM
Jimbolion
Jan 16, 2012 05:56 PM
delongedoug
46
Sep 7, 2011 04:04 PM
Quick Reply: Can't boost past 10psi...wastegate and vacuum lines ok!!
