Forged Performance RE-Build
Old Mar 13, 2009, 02:50 PM
scorke's Avatar
Can't explain the circumstances regarding how the car got into it's current state other than it was the fault of somebody who is not a vendor/member on here, so no warnings that I can freely offer yet.
Anyway I will let the pictures do the talking. The car is was originally sent to Forged with a self-diagnosis of an oil leak and upon further inspection is going to need basically an entire re build of the engine from top to bottom
Something, there is supposed to be something in here but I can't quite...
There it is.
Ah, yes the engine, or what was left of it...
The competence level of the previous build allowed the head to at least stay partially attached to the block...
Parts longing for their final destination...
Sharif/Ryan/Dylan/Forged, thank you, it's going to be a helluva ride
Scorke
Old Mar 13, 2009, 03:22 PM
Joshs EVO's Avatar
Did you say what setup your doing. I may have skipped it. Good luck with the build.
Old Mar 13, 2009, 03:47 PM
06evors's Avatar
Lots of Z's I see. Good luck with your build mr scorke.
Old Mar 13, 2009, 03:49 PM
scorke's Avatar
Same as before, just properly. The shop that touched it last (again not a vendor/member on here) royally messed up the motor.
Oliver Rods, Eagle Crank, Wiseco pistons, Ferrerea Valves, are all the things that need to be fixed along with all the other engine hardware.
On top of that a HKS Fcon and EVC 6 will be getting installed.
Scorke
Old Mar 13, 2009, 07:03 PM
keevo54's Avatar
topspeed?
Old Mar 13, 2009, 07:09 PM
scorke's Avatar
Originally Posted by keevo54
topspeed?
No.
Scorke
Old Mar 13, 2009, 07:12 PM
justboosted02's Avatar
so what happened to your engine to require a full rebuild?
Old Mar 13, 2009, 07:30 PM
scorke's Avatar
Nothing catastrophic, car was running and driving and making 450whp in it's form when it went in. After doing some testing and inspecting Forged found a lot wrong , which led to more searching and more being found wrong.
Scorke
Old Mar 13, 2009, 07:34 PM
SparkTech's Avatar
Good luck with the build....keep us posted
Old Mar 13, 2009, 07:51 PM
Scorke
that sucks
good luck with your build
Old Mar 13, 2009, 07:57 PM
Boost3dxEvO's Avatar
Good luck with the rebuild Scorke.. its going to be one crazy machine when it gets finished entirely!
Old Mar 13, 2009, 07:58 PM
tripperfx3's Avatar
That sucks Scorke! Ryan and Dylan are good friends of mine (I've detailed Ryan's blue beast many times) and you are def. in good hands! Looking forward to seeing the end result!
Old Mar 13, 2009, 08:06 PM
scorke's Avatar
justboosted02/Boost3d/tripper fx 3-Thanks for the wishes/condolences... I was somewhere between shocked and distraught when I got the first round of errors diagnosed...
Kav/Craig- thanks for getting that unit out to them, guess time wasn't as sensitive as I initially thought, can't wait to see it on top of that white VC
In the end I have to tell my self that cars can be fixed, people sometimes can't, and now that I have gotten over that I am just happy this was all caught before I tracked it and something catastrophic happened.
Scorke
Old Mar 13, 2009, 08:36 PM
Kav@SparkTech's Avatar
j
Kav- thanks for getting that unit out to them, guess time wasn't as sensitive as I initially thought, can't wait to see it on top of that white VC
Scorke
Your Welcome...Please keep us updated with pics, we would like to add it to our showcase section on our site. That piece should look rather nice with the White VC
Old Mar 14, 2009, 06:13 AM
EvoM Moderator
scheides's Avatar
Well you won't say who it was, will you at least discuss what you found wrong, and why it led you to the decision of tearing the car apart (again)? Most owners of a 450whp car in running form won't be doing this unless they know what to look out for
Quick Reply: Forged Performance RE-Build
