Go Back   evolutionm.net > Lancer Evolution 1-9 Forums > Evo Engine / Turbo / Drivetrain
Welcome to EvolutionM.net!
Welcome to EvolutionM.net.
Old Mar 28, 2009, 10:59 AM   #16
Personal Sales Rating: (86)
snycros from picture
2nd=22546a
3rd=22547a
4th=22551a
5th=22596y
__________________
early evo nut rockin
evo1 and evo 4
Offline
Old Mar 31, 2009, 11:13 PM   #17
Personal Sales Rating: (0)
Drives: EvoIII
You positive now?
I dont wanna order the wrong ones :P
Offline
Old Apr 1, 2009, 07:26 AM   #18
yes I am positive. but best to use actual part numbers.
2nd syncro MD746435
3/4 are same MD747255
5th MD745892
I have built 200 transmissions.
__________________
evo1 and evo 4
Offline
Old Apr 1, 2009, 11:14 PM   #19
Drives: EvoIII
Do you know anyone that could get a hold of them part numbers for me?
Offline
Old Apr 2, 2009, 06:25 PM   #20
Drives: EvoIII
Nevermind, got a hold of someone.
BTW - Are these synchros for a GSR gearbox?
Offline
Old Apr 2, 2009, 07:07 PM   #21
there are no gear or gear ratio changes in the early 1-3 boxes. so RS and GSR came with same ratios. only difference was RS came standard with front LSD and GSR it was an option. It wasnt till evo 4 came out were there were gear ratio changes and rear end ratio options, even then the scyncros used would be same.
but to be sure post the number of your box to be sure you have evo3 box.r
W5M332_ _ _ _
I need the last four letter to tell you which box you have.
__________________
evo1 and evo 4
Offline
Old Apr 2, 2009, 07:25 PM   #22
runuts's Avatar
Drives: Evo 3
From memory, I believe the ratios in evo 1 box's are slightly different to evo 2/3. That said though, there are no differences between GSR and RS ratio's. The Evo 3 however, has a different crownwheel and shaft, hence requiring a different ratio transfer case to the evo 1/2
Offline
Old Apr 3, 2009, 06:00 AM   #23
Drives: EvoIII
My box is a evoIII GSR box for sure.
Just didn't know RS had the same gears..
Offline
Old Apr 6, 2009, 07:28 PM   #24
Drives: EvoIII
Anyone know the part number for the Evo 3 bell housing?
Offline
Old Apr 30, 2009, 09:51 PM   #25
Drives: EvoIII
Question: Does 5th gear and reverse use the same synchro??
Offline
Old May 1, 2009, 05:57 AM   #26
Drives: EvoIII
Bump.
Offline
Old May 3, 2009, 11:43 PM   #27
Drives: EvoIII
Bump..
Offline
Old May 4, 2009, 09:28 AM   #28
5th and reverse do not use same syncro.
they would be same for all boxes.
__________________
evo1 and evo 4
Offline
Old May 4, 2009, 02:04 PM   #29
Personal Sales Rating: (9)
WADADLIG_OZ's Avatar
Drives: US Lancer OZ sold, EVO II
SUbscribed just for the information.
WADAD
__________________
Back in the island of Antigua aka Wadadli
EVO II GSR
MODS
KN filter and adapter.(6inch)
3inch TBE
New suspension
13.991 @ 96.57mph
13.561 @ 101.12mph
13.384 @ 102.04mph NEW BEST 1.899 60foot :(
Man I'm slow!!!
Offline
Old May 15, 2009, 06:51 PM   #30
Drives: EvoIII
Does the eclipse use the same part numbers?
I've changed my synchro rings but still not totally satisfied with the way it feels, what else would be worn?
Is the hub/sleeve the thing that the synchro ring sits in?
Offline
Tags
2003, evo, hub, identify, iii, md745892, md746435, md746442, md747255, numbers, part, problem, sleeve, synchros, tampa
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
