Oct 23, 2009, 08:10 PM
#121
Personal Sales Rating: ( 3)
Drives: 06 EVO WW RS
I don't new about normal but mine does it too. From what I have seen Evo hook-ups are across the board. Some like it this way. Some that. Have to experiment and see what works best for your car.
Offline
Nov 6, 2009, 03:50 PM
#122
Personal Sales Rating: ( 0)
I just drove my car again and I noticed tons and tons of part-throttle flutter, but no flutter if I throttle over %50-ish. Sometimes the flutter in 6th is so bad the car almost has a tiny hiccup. Right now I am using both ports. I may try and block one, then swap and block the other and see how it works.
I am also hearing a tiny whistling sound? I dont know exactly how to describe it, almost whenever I am accelerating before I hit boost. The closer to boost the more I hear it. And when I shift there is no sound of the BOV releasing or anything like that.
__________________
ETS Black 3.5" FMIC, Nisei IC Piping, Walbro Pump, Perrin Intake, Buschur TBE, Swift Springs -- UNTUNED
Offline
Nov 6, 2009, 03:55 PM
#123
Personal Sales Rating: ( 4)
Drives: 2.slow Evo IX
so heres my little situation...
whats the deal...
When I got mine the C-port was capped off already (as shown in pic). I was in the impression that it was a Evo specific one and only added vacuum to the A and B ports...
Did any one else receive their BOV in this set-up or should I contact Synapse...
By the way this BOV far surpassed by expectations! The stock IX bov must've been leaking pretty bad because I picked up 5psi of boost before 4,000rpm. I still get flutter when I'm on partial throttle and havent had the time to play with it, one reason being that I dont know if the c-port should be capped...
Once I figure that out I'll start to problem shoot the flutter...
On with the pics...
__________________
-MattDennison-
TuningTechnologies ROBISPEC /// MISHIMOTO PROSPORTGAUGES MIL.SPEC SPYOPTICS+
2009 Redline Time Attack - Stock-AWD - Champion
ahh...ocean life
Offline
Nov 6, 2009, 09:51 PM
#124
Drives: 2004 WW Evo VIII RS
I have mine installed on the UICP and I havent had a single problem since I've had it....I think I bought it like 3 months ago, and I still havent had any flutter at all. My Evo is my DD and I'm def. glad I used Synapse
Offline
Nov 6, 2009, 10:35 PM
#125
Personal Sales Rating: ( 1)
Drives: Evo 6 Powered Mirage
Quote:
do you have C port to boost only?
Offline
Nov 7, 2009, 03:17 PM
#126
Anything on this??
__________________
Offline
Nov 7, 2009, 04:38 PM
#127
Personal Sales Rating: ( 17)
Drives: 2005 Evolution VIII
the C port is supposed to be hooked up to a "boost only" source as that keeps the bov shut and prevents it from leaking under boost. It uses the boost pressure to force the valve to remain closed...the more boost you are running the more force is applied to keep the bov shut. I don't have a stock turbo and have the C port hooked up. I'm not sure why yours is capped off.
__________________
05 EVO VIII. 565whp/422 tq @ 33psi (new #'s soon)on E85...Powered by Headgames, Buschur, ETS, and MMS Performance!
Offline
Nov 7, 2009, 04:57 PM
#128
Personal Sales Rating: ( 2)
Drives: 2005 EVO VIII
I'm pretty sure it's exactly opposite of what you said.
Port C is used for boost only to help open the BOV when running high boost pressures. A normal BOV usually just has the vacuum from the top ports to open, but the synapse also has port C for boost to help open it, for rapid response and easier opening at high boost.
Offline
Nov 7, 2009, 05:04 PM
#129
So has anybody recently purchased a Synapse BOV within the last week and recieved the same setup as mine...?
__________________
-MattDennison-
ahh...ocean life
Offline
Nov 7, 2009, 06:51 PM
#130
O-town, never heard of that. Call them.
__________________
Offline
Nov 8, 2009, 09:57 AM
#131
Drives: 2006 EVO IX MR, 2007 Porsche GT3, 2002 Ford Ranger with new tires.
Quote:
yo o-town, thats how all of the newer DV will be setup coming out of Synapse (according to Pete).
Back in Mar I took mine in to have them look at it, check on some flutter/ surge I was experiencing and one of the first things they did was to modify the "C" port (plugging it) and porting the chamber enternally, and in my case i had some serious Comp surge! (I had the FPRed w/o 80mm house/surge port). Since going with the Juiced FP Red w/80mm house absolutley NO comp surge!!! but i had experienced some minor flutter. Talked with Pete and he recommended connecting "B" only ... No issues!
They actually dont recommend messing with the spring adjustment, adjust by switching the port combination until it is resolved, if not then go to the spring for adjustment. This is without a doubt the best DV/BOV out there!
but the newer Valves will have no "C" port or it will be capped!
Oh yea (I hope I'm not misquoting), using only the "A" port is like using 60% of the surface area with in the chamber and port "B" is like 30-40%, with both "A&B" it would equate to 100%
__________________
FP Red // Cosworth // Skunk2 // Brain Crower // Buschur // Perrin // MIL SPEC // Spark Tech // GM // AMS // ETS // Synapse // Cobb // Invidia // ACT // ARP // JMF //PTE //E85
Reese Tuned
443whp/408tq @32psi MD500 euro
stock ecu
stock maf
stock block&head
Reason: update
Offline
Nov 8, 2009, 09:59 AM
#132
so now Synapse recommends capping and not using the C port?
__________________
Offline
Nov 8, 2009, 10:27 AM
#133
after re-reading synapse bov review on their website, I believe you are right and port C is for opening the bov so quickly after you shut the throttle..
__________________
Offline
Nov 8, 2009, 04:11 PM
#134
umm anyone have any info on what were supposed to be doing with port C now?
__________________
Offline
Nov 8, 2009, 06:49 PM
#135
Personal Sales Rating: ( 15)
Drives: 2006 WW Evolution MR
Ronitlancer, I have the same issues as you do with the part-throttle flutter, and it's getting annoying.
I have port-C connected to boost only source from the wastegate, and port-B to intake manifold.
This is the first I'm hearing about capping port-C. Is this the new recommendation from synapse? I might try that if it works.
__________________
Tuned by Kreonic at CBRD
ROBISPEC///
Offline
Tags
bov, evo, fast, fmic, forum, hook, importance, install, piping, ports, reaction, synaps, synapse, synapse bov, synapsebov, synapsis  |
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
HTML code is Off
