Turbo surge on FPGreen or 20Gs
Old Mar 25, 2009, 04:14 PM
racer135's Avatar
Are the people with FPGreen or 20G stock appearance turbos experiencing turbo surge when driving at high loads or boost while at low rpms (under4K) in high gears?
Old Mar 25, 2009, 05:55 PM
cfdfireman1's Avatar
No, but you may see bypass valve flutter depending on amount of boost and the type of valve you use.
Old Mar 26, 2009, 02:29 PM
TakaseEVOIXSE's Avatar
im getting big time surge w/ my FPgreen when i floor it at WOT on full boost at 25psi. It sounds like BOV flutter but constant while im in boost... then slightly goes away in the upper rpm range. Its an issue we HOPE to remedy tonight by cutting off my HKS BOV and welding on a vband TIAL bov.
Old Mar 26, 2009, 06:20 PM
racer135's Avatar
Thats what I though based on some flow maps I made using a 20G efficiency plot. This would be even worse on a stock cam evo due to volumetric efficiency. I will plot my maps later. After 4K RPMs it looks good (at around 22 psi) but from 3 to 4K it appears that it will surge if the turbine has enought time and flow to build high boost, which can be done while in load in high gears.
Old Mar 26, 2009, 06:24 PM
cosworthevo1133's Avatar
i have a fp white turbo and i run 24 psi and when i am in 4th or 5th gear at low rpms and i floor it to get around some one it surges, some one told me tht it might be my bov, i have the greddy type rs and heard it leaks
Old Mar 26, 2009, 06:26 PM
whoang40's Avatar
My green surges too at low rpm, high gear. I have a Works DV. I'm not sure if it's the DV or turbo.
Old Mar 26, 2009, 06:46 PM
SICK9's Avatar
When I first got my Green it did the same thing at low rpm, high gear acceleration.
At first, I just stepped on the gas more and it helped a bit, but not fully.
I found dropping a gear or two works much better.
It likes the higher rpm's much better. (4-6k rpm).
Just my .02..
It was more of driving style then anything else..
I will say, that now that i have the RED, it does not do it as much, but still does it, if i try to.
So I dont, I just drop a gear and BAM, gone.....
good luck...
Old Mar 26, 2009, 06:50 PM
racer135's Avatar
Based on the plots I made it should be the turbo. A weak DV will help too but the DV capacity is independent of rpms. Engine flow and it capacity to "swalow" the turbo airflow increases with rpms thats why you will not see it at high rpms unless you have a huge turbo.
whoang40's Avatar
It must me that the turbo is supply the engine with too much air instantaneously at high rpm. Or else the DV can't release it fast enough.
Old Mar 26, 2009, 08:04 PM
Boost3dxEvO's Avatar
Maybe you need to run a recirculated bov... since you are obviously on a pretty basic setup and not high boost... I don't know why you are running VTA bovs ..
Old Mar 26, 2009, 08:38 PM
dsmfan95's Avatar
I noticed a bit more surging with the EvoRed over the EvoGreen.
Old Mar 26, 2009, 10:15 PM
N33d4sp33d's Avatar
yeah i agree i'm guessing red holds mid range better than green
Old Mar 27, 2009, 03:50 AM
racer135's Avatar
That is expected. A stroker will also help with low rpms surge.
Old Mar 27, 2009, 05:14 AM
dsmfan95's Avatar
From what I've read, the stroker makes the surging worse.
Old Mar 27, 2009, 11:25 AM
my ECU has been able to run VTA for quite sometime. I have no issues when it releases, no stalls, in fact it runs better than my friends recirc'd evo as far as idle stability and AFRs are concerned so i havent bothered to touch it. Im using a wideband w/ datalogging capabilities as most of us do... and see no ill effects from it. i dont want to get into another VTA discussion... but the issue is when im WOT not when im off throttle. So the VTA/Recirc is irrelevant to this thread. The surging is happening when the BOV is closed and WOT accelerating full boost. It happens around 2500-4000rpms.
Now, that being said... just to make sure the HKS bov wasnt leaking, we TIG welded a new vband flange for a TIAL bov. Tested and works flawlessly... but the surging is still there. In fact i upgraded the bov for no reason...haha. After reading the above comments... im assuming then the FPGreen just has a tendency to surge at low rpms/high load gears. I just didnt expect it from a 20g... if this was a bigger turbo i would have dismissed it in the beginning, LOL... Anyone else have a green that surges?
Quick Reply: Turbo surge on FPGreen or 20Gs
