NGK spark plug evo 9...
Well... most of you know about the evo 9 the spark plug has the NKG ILFR7H my question is.. what can i use that is not iridium and one step colder (8) ?
Regards
Daniel
Regards
Daniel
I was looking all day yesterday for that specific info as I have all the specs on the plug... I am gonna research it some more today to see if I can find a copper core replacement for you guys... But the depth of the plug is what I am having a hard time with as most of the plugs with that depth are either iridium or platinum plugs...
HKS Part number: S40iL
OE NGK number: ILFR7H
Stock Plug= NGK ILFR7H Stock #5245 LINK
Step colder= NGK R7437-8 Stock #4901 LINK
2 Steps colder= NGK R7437-9 Stock #4654 LINK
3 Steps colder= NGK R7437-10 Stock #4655 LINK
NGK ILFR7H (OEM) Iridium
http://www.sparkplugs.com/more_info.asp?AAIA=&pid=20451
NGK LFR7AIX Iridium
http://www.sparkplugs.com/more_info.asp?AAIA=&pid=16602
NGK LFR7AIX Iridium
http://www.sparkplugs.com/results_cr...kh24&x=61&y=15
those are iridium plugs but they are only 11.99 and they are 1 step colder.
I could never find the copper plugs for the 9. some people say you dont even need 1 step colder for the 9 as they all ready run a cold plug. but the denso plugs are working great for me.
IKH24 is the part number
Joe
Joe
Just spoke with NGK tech, and Denso tech and they do not make a conventional copper plug in the stock or 1 step colder heat range yet... I am going to call Champion and Autolite and see what they say... Denso had a spec match but it was a 20 heat range (22 is stock). Champion had a spec match but a different heat range also... Autolite is a no go too...
NGK LFR7AIX Iridium
NGK LFR7AIX Iridium
thanks
Joe
Joe
kpt6
12
May 11, 2017 01:04 AM
kikiboi
12
Jul 6, 2007 12:49 PM
