Go Back   evolutionm.net > Lancer Evolution 1-9 Forums > Evo Engine / Turbo / Drivetrain
Welcome to EvolutionM.net!
Welcome to EvolutionM.net.
Old Mar 16, 2009, 10:33 AM   #1
Personal Sales Rating: (8)
sleeper3's Avatar
Drives: Evo IX RS
Competition Clutch Flywheel/Clutch Install on Evo IX RS
I have an Evo IX RS at 30,000 miles and just had a Competition Clutch flywheel (part STU ultralight) and clutch (stage 4 six puck) installed. We used the TO bearing included in the CC kit. I used factory Mitsubishi Diaqueen 75W85 for the tranny, and Mitsubishi LSD gear oil for the transfer case and rear diff. I paid $700 for all the parts and $500 labor.
CC Stage 4 clutch kit:
CC Clutch #STU:
I had an Evo tuner and BMW certified tech install everything at a local shop. Everything in my car is now broken in after a week and about 400 miles. At first there was more clutch chatter at idle and noticable vibration in the pedal, however, this gradually went away. Now after break in there is no vibration in the clutch pedal, and the clutch chatter at idle is back to normal. The car drives great, and shifts/engages better than stock.
However, there is one noise that I can't seem to explain.
In first gear there is a loud resonating whine when accelerating from a stop. It almost sounds like a low volume car horn, like a resonating metal sound that's smooth, not grinding. Here's the thing, if I do a light launch with revs at 3k and slip the clutch a bit, then the noise goes away for a while. However, it does return later, and usually happens on a cold start up too.
It almost seems like the clutch and flywheel are making that noise once they engage as I slip into 1st gear from a stop, maybe the flywheel still has uneven surfaces that need to be broken in. Or maybe this is something normal for an aftermarket clutch/flywheel setup?
Overall though, the tranny shifts great while accelerating easy/hard, engages very well when downshifting, and holds power great. It's just this odd noise that I was wondering if anyone else has experienced.
Offline
Old Mar 16, 2009, 12:31 PM   #2
Personal Sales Rating: (1)
Malik_EvoIX's Avatar
Drives: 2006 evo ix gsr Traded-> for 2009 Nissan Pathfinder SE
i just had a competition stage 4 6 puck clutch installed 2 weeks ago professionally by a well respected speed shop is this whats happening to your car? clutch job need help!! Click on video links
__________________
-06 Evo IX Sold
-09 Pathfinder SE Journey Edition DD
Offline
Old Mar 16, 2009, 01:00 PM   #3
bump
__________________
-06 Evo IX Sold
Offline
Old Mar 16, 2009, 01:26 PM   #4
sleeper3's Avatar
Drives: Evo IX RS
Quote:
Dude, I have the EXACT same noise. Sounds like an elephant moaning, like a resonance. Your second vid from inside the car sounds EXACTLY like mine does when starting in 1st gear.
Only happens when accelerating in 1st from a dead stop. It goes away if I do a mild launch with clutch slip, but returns later. Or if I slip the clutch quickly and at the right time it won't make the noise. Only difference from your setup is I also put in a Competition Clutch ultralight flywheel (part# STU) along with the stage 4 six puck clutch.
I called Competition Clutch directly a few hours ago and the tech said the sound was normal and I should break it in more. I have 400 miles and 8 days, I'll keep driving and see if it goes away. It makes me feel a bit better now that someone else has the same issue, I think it will go away with time.
It doesn't worry me as much because the noise does go away with a light launch/clutch slip, so it could be just engagement noise that comes with aftermarket parts or imperfections on the flywheel surface that need to smooth out. Plus the noise is more of a resonance and NOT grinding. Other than this noise in 1st gear, the car drives better than before, shifts great, engages great with the engagement point at the top of the clutch pedal travel, just like it was when stock.
I'll keep breaking the clutch in and will update this thread in the coming weeks.
Offline
Old Mar 16, 2009, 05:09 PM   #5
dude i got like 900 miles on it and still happens
__________________
-06 Evo IX Sold
Offline
Old Mar 16, 2009, 05:33 PM   #6
sleeper3's Avatar
Drives: Evo IX RS
Since we both had it installed by knowledgable techs, and because both of our cars are shifting/driving fine, I think we can chalk this up to being a symptom of having aftermarket parts.
Some researching has found that the stock components, like the springs on the clutch, are tuned by the factory to cancel out any harmonic vibrations that can be audible. By replacing it with an aftermarket clutch, I think we threw that out of balance a bit.
I also found two other users who experienced the same thing as we are but they used ACT components. Apparently the noise does not go away for quite a while, at least for one guy, and it only went away after 5000 miles and few trips to the drag strip.
I can pretty much avoid the noise by either applying very little throttle, or a lot. We'll see how it goes after a few weeks.
Offline
Old Mar 16, 2009, 05:48 PM   #7
when i give the car more gas slip the clutch my car stalls on me man i cant wait for my t-case fluids changed i am gonna beat the hell out of the clutch. yes were talking 2 steppin and full launch!!!
__________________
-06 Evo IX Sold
Offline
Old Mar 17, 2009, 07:36 AM   #8
sleeper3's Avatar
Drives: Evo IX RS
Hmm, if you car stalls then you may have other issues. How much wear was on the stock flywheel after you had it resurfaced?
I know this advice is too late for you, but I always replace the flywheel on a clutch job, especially considering how much abuse we put on those components with our cars.
You may have to have your idle rev raised to avoid the stalling.
For me, as of this morning the noise is starting to go away, I know it may come back but it seems to be lessening.
Now keep in mind that I replaced all components (clutch, cover, t/o bearing, flywheel) and as already mentioned in my previous post, put in fresh Mitsu Diaqueen 75W85 for the tranny. I also replaced the transfer case and rear differential with Mitsu LSD SAE 90 Gear Oil. I even did a fresh oil change and we had to put in new radiator fluid anyway. I wanted to make sure that the installers did as much as they could so that I had a fresh fluids since I'm at 30k miles and want this car to last.
So definitely put in fresh fluids for all of the drivetrain components and start breaking it in. I would still think about having your idle rev raised via an ecu flash because that may very well be the only solution for the stalling issue.
Offline
Old Mar 17, 2009, 01:55 PM   #9
i had the tob replaced trans flush etc.
__________________
-06 Evo IX Sold
Offline
Old May 15, 2009, 01:27 PM   #10
sleeper3's Avatar
Drives: Evo IX RS
Just wanted to update everyone, after a few thousand miles, the noise has all but gone away. In fact, I called the tech at Competition Clutch and he confirmed the noise was normal and would go away.
There has never been an issue with the actual performance of this Competition Clutch/Flywheel, the engagement is nice and crisp, and I can launch much much better than with the factory setup. I also noticed some nice benefits of having a lighter flywheel.
So anyone looking for a reasonably priced clutch/flywheel setup, definitely take a hard look at Competition Clutch, because I won't hesitate to get the same parts once these wear out down the road.
Offline
Old May 15, 2009, 03:29 PM   #11
Personal Sales Rating: (7)
krisdlm's Avatar
Drives: 2006 Mitsubishi Evolution IX
what was the clutch rated at for hp/tq
Offline
Old Jun 15, 2009, 01:20 PM   #12
Personal Sales Rating: (0)
Drives: GG IX
I have the same noise as well with the same clutch installed, I look forward to the quiet days ahead as it breaks in! --I think its rated to hold around 350whp officially
Offline
Old Jun 15, 2009, 03:59 PM   #13
NTEC Club Leader
Personal Sales Rating: (19)
Kracka's Avatar
Drives: WW IX GSR
Send a message via AIM to Kracka
It'll hold WAY more the 350whp though. I'm on the Stage 3 @ ~400whp and its holding great.
Offline
Old Jun 15, 2009, 05:38 PM   #14
Personal Sales Rating: (38)
BluEVOIX's Avatar
Drives: 06 Blue EVO IX
I just installed CCI stage 4 with RRE 10.8 lbs clutch. I got about 6 miles on it right now and no noises. But the clutch pedal did get stuck in the "pushed in" position a couple hours ago. I put my foot under the clutch pedal and it popped up and is currently working.
__________________
2006 Blue EVO IX
Buschur Magnaflow TBE w/hfc
TTP Swain o2 housing & Vibrant Cone filter
CCI Stage 3 clutch
Blox Motor Mount
ShepTrans [Evo8 (3-5) gears]
Offline
Old Jun 16, 2009, 07:08 AM   #15
Personal Sales Rating: (3)
2003 Mitsubishi Lancer Evolution
FX11's Avatar
Drives: Evo8
Quote:
bleed your slave cylinder or do a pedal adjustment
__________________
-405th Infantry Division-
-Tri-State Evo-
FOR SALE:
RSX - Silver, 34k miles MINT CONDITION! $7,900
EVO 8 TME - White, 48k miles MINT, non smoker, All around nearly perfect car! $19,500
Offline
Tags
aftermarket, case, chatter, clutch, competition, cover, evo, flywheel, install, lancer, making, mitsubishi, noise, rs, stock, transfer, vibrate, whine
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
