Evo Engine / Turbo / DrivetrainEverything from engine management to the best clutch and flywheel.
Sponsored by: World Racing
Welcome to EvolutionM.net!
Welcome to EvolutionM.net.
I took my car to AMS last fall. They were unable to tune or flash it because the cat was not flowing properly. They said I wouldn't have full power until I got a new exhaust. I could have it tuned at that time.
I drove from Chicago to Ann Arbor about three weeks later. The exhaust backed up back to the engine, turning my exhaust manifold bright orange and making something tick within the engine. I had no power from the turbo.
I had it hauled back to Chicago on a flatbed. The tow truck driver put his hand on the engine cover and he said I likely have a bent valve. He said he races a Camaro and he once had too narrow an exhaust installed and it did the same thing.
I will soon have the dough to pay for the repairs, but I wanted a ballpark on how much it might cost. I know a new AMS exhaust is $1000. How much does it cost to repair a bent valve? I don't want to waste AMS's time by having them give me an estimate and then say "see you in a couple months when I have the money". I don't plan to bring it until I know I have $$$ enough to get it fixed.
If you've had something like this repaired or you can give me a guess please give me your .02. Thanks!
__________________
I'm not speeding, I'm qualifying!
do a compression test before anything because it could be something else. if your compression is low in one or two cylinders then yea maybe bent valve...it cost me $1000 to fix two valves, check the head nd everything
__________________ MODS:
fully built 2.0
precision 3582
gsc s2
exedy twin HD
buschur race core
boomba 75mm tb
hks carbon ti catback
hks race BOV
1200cc fic injectors
sparktech cop
walbro 400 rewired
93oct KP Tuned
Bent valves are usually from over-revving. Burned valves can be from the circumstances you describe, though. You need to have a compression or better yet, a leak down test done. These tests will diagnose whether your valves are working normally. It could just be that you blew your turbo.
The car was not smoking. I was following another car pretty fast on I-94 then all of a sudden I couldn't go faster than 85, then 75, then 60 and then I exited. If I can get out of AMS with a new exhaust and the other stuff repaired for +/- $3000 total then I will be pleased. Thanks for the replies.
__________________
If it is a bent valve, then it should be 300-400 in labor for machining plus price for parts, assuming you pulled off the head yourself. Valves should be around 120 each valve.
__________________
11.80 @ 119 Stock turbo, block, head. Full Bolt ons, cams, and E85 @ 26 psi.
