Home Features Community Marketplace Registry Garage Store
Go Back   evolutionm.net > Lancer Evolution 1-9 Forums > Evo Engine / Turbo / Drivetrain
Sign in using an external account
Register Forgot Password?
Register Photos FAQ Members Calendar Search Today's Posts Mark Forums Read ExperienceUsed CarsGarageVendors TSB & Recalls
Search
Sponsored by: World Racing
Welcome to EvolutionM.net!
Welcome to EvolutionM.net.
Thread Tools Search this Thread
Old Feb 1, 2009, 11:17 PM   #1
Personal Sales Rating: (14)
Garage is empty, add now
justa4banger's Avatar
Drives: evo 8
Points: 3,354, Level: 36
Points: 3,354, Level: 36 Points: 3,354, Level: 36 Points: 3,354, Level: 36
Daily Activity: 0%
Daily Activity: 0% Daily Activity: 0% Daily Activity: 0%
turbonetics 60-1 hifi turbo
who has heard about the turbonetics 60-1 hifi turbo??
i know its a old turbo but who has had any experience with it on a stock block?
any input would be aprecciated
Offline
Old Feb 1, 2009, 11:53 PM   #2
Drives: evo 8
Daily Activity: 0%
anybody
Offline
Old Feb 2, 2009, 01:39 AM   #3
Personal Sales Rating: (1)
Drives: EVOLUTION IX
Points: 5,514, Level: 47
Points: 5,514, Level: 47 Points: 5,514, Level: 47 Points: 5,514, Level: 47
Daily Activity: 1.5%
Daily Activity: 1.5% Daily Activity: 1.5% Daily Activity: 1.5%
Which hotside?
T3 .63 with a stage 3 turbine wheel
or
T4 turbine section A/R: .68 Stage 5 (62mm) turbine wheel
The 60-1 is rated to flow 61lbs/min
So its in between the GT30R (52lbs/min) and GT35R (65lbs/min)
__________________
___________________________________________
#EVO IX; 2.3L Stroker; AMS HTA82 Turbo kit; Tomei Pro-cams; Cooling Mist Alky Inj; Spark Tech COP; (Haltech Platinum ECU)
Offline
Old Feb 2, 2009, 07:19 AM   #4
Drives: evo 8
Daily Activity: 0%
the T3 .63 with a stage 3 turbine wheel
Offline
Old Feb 2, 2009, 09:10 AM   #5
Personal Sales Rating: (109)
Points: 15,427, Level: 80
Points: 15,427, Level: 80 Points: 15,427, Level: 80 Points: 15,427, Level: 80
Daily Activity: 5.7%
Daily Activity: 5.7% Daily Activity: 5.7% Daily Activity: 5.7%
very old design compressor wheel. far better options exist.
__________________
early evo nut rockin
evo1 and evo 4
"torque=fun"
the faster you can make torque the more fun your car will be. lag is a dull boy.
"if the solution is simple, God is answering"
Offline
Old Feb 2, 2009, 09:51 AM   #6
Drives: evo 8
Daily Activity: 0%
like i said i know its old...but i wana hear some reviews about it
Offline
Old Feb 2, 2009, 11:20 AM   #7
Silver Sponsor
Personal Sales Rating: (30)
JohnBradley's Avatar
Drives: 06 Rally Red MR
Points: 28,776, Level: 99
Points: 28,776, Level: 99 Points: 28,776, Level: 99 Points: 28,776, Level: 99
Daily Activity: 23.7%
Daily Activity: 23.7% Daily Activity: 23.7% Daily Activity: 23.7%
Its laggy and doesnt make power. /review
The Hi-fi is not the cooler of the 2 60-1's its the small compressor housing so it doesnt flow as much as its big brother is rated. On the Hondas I tried this on I made a best of 375whp at 23psi on a 1.6. Keep in mind on a Honda thats alot of boost for that little amount of power.
__________________
We choose only GSC cams, ask about the new R2
Forced Performance Turbos
FIC Master Distributor
The only source for Competition Clutch
ER Evolander updates
HTA94 2.4 numbers- 831/630 @ 39.5psi E85
English Racing USDM Auto
I am because of what they are not
Extreme Turbo Systems
SparkTech The ignition of EnglishRacing
R2 camshaft sets now in stock
Offline
Old Feb 2, 2009, 11:24 AM   #8
Personal Sales Rating: (2)
Magnumpsi's Avatar
Points: 9,794, Level: 66
Points: 9,794, Level: 66 Points: 9,794, Level: 66 Points: 9,794, Level: 66
Daily Activity: 0.5%
Daily Activity: 0.5% Daily Activity: 0.5% Daily Activity: 0.5%
We used to use them on DSM's "back in the day" and they really did not perform all that well.
Mitch M
__________________
Mitch Mckee
Cobb Tuning
R&D Calibrator
Offline
Old Feb 2, 2009, 11:49 AM   #9
Personal Sales Rating: (6)
Drives: Evo VIII/SVO Mustang/BMW E30 M3
Points: 16,007, Level: 81
Points: 16,007, Level: 81 Points: 16,007, Level: 81 Points: 16,007, Level: 81
Daily Activity: 0.8%
Daily Activity: 0.8% Daily Activity: 0.8% Daily Activity: 0.8%
The 60-1 compressor appears best suited toward low boost applications - not exactly what one is typically seeking with a 2.0L engine and 3000+lb chassis.
__________________
Ted B. Spec JAM LR 2.0L - Headway Perf CNC Head - DI Int Man - 75mm Hypertune TB - HTA3582 TS 1.06 A/R T4 - Crane 272-280 - MPFab TS T4 Manifold, TBE, UICP, LICP - MPFab FMIC - TiAl 44mm WG - Skunk2 Pro Cam Gears - FIC Bluemax 1450cc - FullBlown Dual 255lph - Synchronic BPV - Spark Tech COP Ignition - TRE Trans - Shep TC + LSD - SPEC Super Twin P-Trim Clutch
93 oct - 595whp
Offline
Old Feb 2, 2009, 12:58 PM   #10
Drives: evo 8
Daily Activity: 0%
i will keep you guys posted on how it goes wit my setup
i will also post vids of the lag....
Offline
Old Feb 3, 2009, 03:20 AM   #11
Quote:
Originally Posted by justa4banger View Post
i will keep you guys posted on how it goes wit my setup i will also post vids of the lag....
On my 2.3L set-up it makes about 50HP more than my 3076 made on the same boost levels on the same size exhaust housing... Spool is about 500rpm later though...
50HP vs 500rpm later spool not sure if this is acceptable to you.
I chose it even though everyone said its old tech and the wheel design is not good for high boost etc, for a couple of reasons:
a.) I felt it would be a better pump gas Turbo
b.) I felt it would be better on lower boost levels
c.) I was not keen to run 30psi+
c.) felt that on my application it would spool like a 30R on a 2L
d.) wanted to create my own bb ver of a Red like capable Turbo
Wanted to make more power on less boost with 91Oct Fuel...
I have the T04S cover though with 4inch intake and 3inch boost pipes and a bigger FMIC...
Let me know what your results are like, am considering a TS GT3582R with a T4 1.06 housing as I believe the 60-1 offers similar lag but less power...
cheers
Sal
__________________
Offline
Old Feb 3, 2009, 04:47 AM   #12
heres some info on these old school turbos from one of the SRT vendors:
This is on a 4Cyl 2.4L Motor for the T3 .63 & Stg 3 Exhaust wheel combo:
50 trim: Good all around turbo. Spools fast, and will make great power. This turbo is perfect for those wanting to run lower boost, and those who run only pump gas. If you plan to run nothing but pump gas, and want a good street turbo, then this is your turbo. Full boost should be right around 3100-3200rpms with a .63 A/R turbine housing. On our test cars, we've pulled over 420whp on pump gas at 23psi. The maximum boost is around 31-32psi where we have seen 500whp. If these numbers are big enough for you, then look no further and order a 50 trim. Its a $300 option because it is a custom built turbo, but well worth it. Flows 49lbs/min...
57 Trim: The 57 trim is not a turbo we really recommend. Its basically a less efficient 50 trim. If you want something that spools faster than a 60, then get a 50 trim. If you want a bit more power, get a 60 trim. If you think you need a 57 trim because some other guy told you it was the best wheel out there, you can convince us to sell you one. (It would be the same price as the base kit.)
60 trim: Slightly larger than a 50 trim and will support another 10-25hp. The turbo is slightly laggier than the 50 trim so full boost is around 3200-3300. The turbo wiill make support a hair over 30psi and also a good street turbo. Below 20psi, at the same boost, a 50 trim will make more power, but at higher levels, the 60 trim has a slight edge. 50lbs/min...
60-1: Now were getting into the big turbos. A 60-1 will make upper 500whp, support well into the 30s, and be a nasty turbo. Full boost is around 3400-3500 in a .63 A/R turbine housing. This is a good in-between turbo. Not huge, but not small. Good blend of street and race. Flows 61lbs/min...
__________________
Offline
Old Feb 3, 2009, 08:05 AM   #13
Drives: evo 8
Daily Activity: 0%
thxs for the input....^^^^
so what does this spool at on a stock 2.0 like 4300-4500???
Offline
Old Feb 3, 2009, 11:39 AM   #14
yeah I think about 4500 would be about right depending on your setup, cams, etc...
...as one of the other members put it "all the lag of a GT35R without the power..."
I think yours will be good for about 550HP with full boost around 4500rpm.
cheers
Sal
__________________
Offline
Old Feb 13, 2009, 06:57 AM   #15
Drives: evo 8
Daily Activity: 0%
ok... bolted on this setup on my car yesterday, and all i can say is wow.....it feels fast on 25psi untuned (no knock) (on e85)..... full spool around 4400rpm...im sure itll spool faster when i get tuned...defenitily feels faster then my green...
Offline
EvolutionM
Mitsubishi Lancer
Paid Advertisement
Tags
23, 601, compressor, evo, hifi, housing, mustang, review, size, svo, t3t4, turbo, turbonetic, turbonetics, wheel
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
Powered by vBulletin® Version 3.8.7
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
Content Relevant URLs by vBSEO 3.5.2
All Passwords
