Feb 1, 2009, 01:01 PM
Personal Sales Rating: ( 0)
Bosch 1000cc injectors on an Evo
Looking for some feedback from folks who are actually running the "Injectordynamics.com" Bosch 1000cc/min injectors on an Evo. Honda guys have been running them for a while but haven't heard much about these on an Evo.
Any impressions regarding idle quality on gas, part throttle driveability?
Offline
Feb 2, 2009, 09:59 AM
Bump for super bowl hangovers...
Offline
Feb 2, 2009, 11:27 AM
Personal Sales Rating: ( 12)
Drives: Evolution Baby
those are good injectors.
__________________
2nd:RTA BUTTON WILLOW UNLIMITED CLASS 12/03/06
2nd:RTA BUTTON WILLOW MODIFIED CLASS 4/29/07
1st: RTA BUTTON WILLOW MODIFIED CLASS CHAMPION 3/30/08
1st: RTA GATEWAY INTERNATIONAL RACEWAY MODIFIED CLASS CHAMPION 4/20/08
1st: RTA CALIFORNIA SPEEDWAY MODIFIED CLASS CHAMPION 7/20/08
3rd: SUPERLAP FINAL BUTTON WILLOW LIMITED CLASS 11/12/2008
C-Spec Tuning : Robispec : Driven Innovation : Toyo Tires : Milspec : Motul : MAPerformance : Extreme Turbo Systems : Boomba Racing : ARK Performance
Offline
Feb 2, 2009, 09:04 PM
vboy, are you running them?
Offline
Feb 3, 2009, 06:57 AM
I have no personal experience with them yet (although tempted to try them). As you said honda/ acura turbo cars have been running them with great results thus far. From most of the feedback in those forums or some other forums where they have been tried, the first thing the tuners are saying is how nice they are to tune with.
More than a few well know and respected tuners with proven records in that market have posted saying its like tuning on a much smaller 600cc saturated, much better idle quality, very noticeable improvment driveability, battery comp values are supplied with them, sets are matched, better atomization/ droplet size you usually cannot get from a an injector this size, supplied with adapters/ injector clips, etc.
From Tony Palo of T1 Race Development:
" Here are some advantages:
High Impedance, no need for injector drivers or injector resistors
High pressure capability, All injectors will run comfortably at 100psi above 10v, flow will be increased by approximately 50% at 100psi
High duty cycle, with a recovery time of only 1ms, all injectors will run up to 92.5% duty cycle at 9k rpm and 95% duty cycle at 6k rpm while maintaining linearity within 1%
Excellent low pulsewidth response, linearity within 2% all the way down to 2ms, predictable response down to 1.5ms. Using a 3 dimensional battery comp table with Motec V3 software, low pulsewidth response can be linearized to practically zero flow.
Good atomization, Droplet size of the 1000cc injector is comparable to the Siemens Mototron 60lb injector, and is far better than the Multec 95lb, Standard Motor Products (RC) 1000cc and Siemens 72 and 83lb injectors.
Excellent consistency, no sets will require more than a 1% trim
Ruler flat response, unmatched linearity means easy tuning and accurate compensations. "
Offline
Feb 3, 2009, 01:27 PM
Personal Sales Rating: ( 2)
I am interested in purchasing these, does anyone know where to get them for Evos?
Dan
__________________
Professional Awesome Time Attack
2001 Mitsubishi Evolution VII
2nd Overall 2009 Redline Street AWD East Coast
www.ProfessionalAwesome.com
MA Performance
T1 Race Development
JRZ Suspension
Offline
Feb 3, 2009, 03:05 PM
Personal Sales Rating: ( 17)
Drives: K20 EJ1 68mm turbo, 03 EVO8
They wont work, because the stock evo has low impedence injectors. Its either the ecu can work with low impedence injectors or the evo has a stock resistor box on it. If the car has s stock resistor box then find a way to get rid of it and you can run these injectors.
Offline
Feb 4, 2009, 10:08 AM
less10, the Evo has a resistor pack that you bypass for running these saturated Bosch injectors with the stock ecu.
Offline
Feb 4, 2009, 03:22 PM
Then just bypass the resistor box. Turn up the fuel pressure (since they love love love high FP) and get the best spraying pattern injectors alive
Offline
Feb 4, 2009, 06:32 PM
Personal Sales Rating: ( 47)
Drives: 2003 Evo VIII
I think that Tony Palo (T1 Race Development) sells them for many applications, including the Evo.
Online
Feb 5, 2009, 07:54 PM
Personal Sales Rating: ( 3)
Drives: Evo
So do we know for sure if it has a resistor pack? If so, where is it?
Since I use to be a regular on Honda-Tech, I asked tony if he could post here for some info for us.
Offline
Feb 5, 2009, 08:10 PM
Personal Sales Rating: ( 1)
Drives: 07 Titan, 01 Integra
Hi guys,
For starters, these injectors will work on the evos. The stock injector resistor will need to be bypassed (very easy to do). The stock injector drivers are not peak and hold drivers, that's why there's a resistor used with the low impedance injectors.
Here's a pic installed on Forced Performance's EVO. Scott had nothing but good things to say about them and was also kind enough to share the necessary lower oring for a perfect fit on the EVO.
We've been using these for some time now and everybody has been blown away with the performance of them. We have quite a few big and well respected tuners in the industry who have been completely sold on them after tuning with them, including myself. I can promise you there's not another 1000cc injector on the market that compares.
Check out www.InjectorDynamics.com for some pretty detailed info about what goes into these injectors. The "questions answered" portion has some very interesting info as well. If you don't learn something from that site then you're either way too smart or too dumb to comprehend. lol
There's some more info, pics, dynos and a datalog on my site about these.
http://www.t1raceparts.com/1000cc_Bo...r_p/b1000s.htm
If anyone has any further questions, ask away.
-Tony
__________________
8.90 @ 169 in a fwd street Integra...
Offline
Feb 5, 2009, 08:20 PM
Drives: Evo
Thanks Tony!
Offline
Feb 7, 2009, 01:32 PM
Haha, yeah I think Scott from FP (grocmax?) is the only one running these injectors on an Evo so far. Would be great to read his impressions of them.
Offline
Feb 7, 2009, 02:16 PM
Drives: EVOLUTION 6
So does anyone know how to bypass the resistor box ?
Offline
Tags
1000cc, 2005, bosch, box, bypass, evo, evolution, fuel, honda, impedance, injector, injectors, low, pack, resister, resistor  |
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
HTML code is Off
