Feb 7, 2009, 03:19 PM
Personal Sales Rating: ( 1)
Drives: 07 Titan, 01 Integra
The EVO is no different than any other engine, the hundreds of other happy customers that have had excellent results with them should give you a pretty good idea.
__________________
8.90 @ 169 in a fwd street Integra...
Offline
Feb 7, 2009, 05:18 PM
Personal Sales Rating: ( 17)
Drives: K20 EJ1 68mm turbo, 03 EVO8
Do the stock injector plugs work?
Offline
Feb 7, 2009, 05:22 PM
Personal Sales Rating: ( 47)
Drives: 2003 Evo VIII
I think that they need an adapter plug on the injector side, which some of vendors have in stock. Then it matches your factory wiring without any cutting or changes.
Offline
Feb 7, 2009, 06:57 PM
If you get it with the adaptor pictured on the other page then it does.
http://www.t1raceparts.com/product_p...0to%20obd1.htm
The adaptors are $7/ea as an upgrade over the connectors that come with the injectors.
__________________
Offline
Feb 16, 2009, 12:55 AM
Personal Sales Rating: ( 9)
Drives: 06 WW IX, 95 chevy 1500 Truck and 1968 Chevy Nova (Drag Project)
Tony im interest to order all 4 Injectors for my Evo with New turbo upgrade.. so My tuner will open resister box something?
__________________
DEAFSPEC///
TUNED BY MIDGET///SPEC and English Racing..
Offline
Feb 16, 2009, 06:15 AM
Personal Sales Rating: ( 4)
Drives: Evo VIII/SVO Mustang/BMW E30 M3
A saturated injector can be used in place of a peak and hold type without risk of damaging the drivers, but not the other way around.
Whomever claimed that upping the fuel pressure was a good idea should be bent over and spanked. It is not a good idea, and that has nothing to do with the injectors. The best idea is always to maintain the manufacturer's specified injector pressure differential.
__________________
Ted B. Spec JAM Long Rod 2.0L - Headway Performance CNC Head & Valvetrain - DI Intake Manifold - 75mm Hypertune TB - HTA3582R Twin Scroll T4 - Machined 12mm lift Billet Cams - MPFab twinscroll T4 Manifold, TBE, UICP, LICP - MPFab Race FMIC - TiAl 44mm WG - Skunk2 Pro Cam Gears - FIC Bluemax 1250cc - FullBlown Dual 255lph - Synchronic BPV - Spark Tech COP Ignition - TRE Trans - Shep TC + LSD - SPEC Graphite Dual Disc
Offline
Feb 16, 2009, 07:08 AM
That was me, ask tony what his base fuel pressure is before he adds 50psi of boost :P
Offline
Feb 16, 2009, 07:26 AM
I suspect that is because Tony relies upon generating somewhere north of 900whp for his drag car, but has an injector rated at only 1000cc. He has no other alternative, except to use a different, larger injector.
Increasing fuel pressure for most here however tends to be a losing proposition for several reasons, some of which may not apply to Tony or other high hp drag setups.
__________________
Offline
Feb 21, 2009, 01:13 PM
Personal Sales Rating: ( 3)
I'm done helping. post deleted
Offline
Feb 21, 2009, 03:39 PM
Quote:
Originally Posted by dan l
You can run 100psi base ... Bosch rated these for 105psi base ...
There appears a communication gap here.
Bosch didn't rate the capacity of this injector at 105 psi of base pressure.
For 99+% of us here with in-tank Walbro pumps, raising base pressure is a losing proposition, for reasons which are well known at this point in time.
__________________
Offline
Feb 21, 2009, 06:03 PM
Offline
Feb 21, 2009, 06:23 PM
I'm not sure if you understand. The injector's rated capacity is specific to a particular pressure. It isn't 116 psi.
And regarding that Bosch pump, what happens to its volumetric capacity as it is asked to deliver greater pressure?
__________________
Offline
Feb 21, 2009, 06:32 PM
Offline
Feb 21, 2009, 06:44 PM
I'm not knocking the injectors. I haven't heard anything bad about them. I'm just stating in general that so long as injectors are properly sized, there is nothing to be gained from raising pressure, but there are potential drawbacks. If the injectors are undersized, such as these would be in my application, such drawbacks are inevitable if not considered.
__________________
Offline
Feb 21, 2009, 08:05 PM
Offline
Tags
1000cc, 2005, bosch, box, bypass, evo, evolution, fuel, honda, impedance, injector, injectors, low, pack, resister, resistor  |
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
HTML code is Off
