Jan 27, 2009, 07:33 PM
Personal Sales Rating: ( 5)
Drives: evo 8
just go wit a fp green
__________________
mods: Agency power turbo kit, GARRET dbb gt35r, Ap intake, custom licp , FORGE mbc, JGT catback, PERRIN test pipe, , AEM wideband, EXEDY stage 2 PP with ACT 6 puck, ACT streetlite FW , WALBRO fuel pump, FORGE bov, huge ebay front mount, HKS 280s, 1000cc injectors, ARP headstuds, AMS mini battery with ams battery tray, omni power coilovers, WingzPerformance tune
http://i188.photobucket.com/albums/z...e/e85ftw-1.jpg
best 1/4 mile time on e85 (8 turbo)
12.2 @ 116mph
Offline
Jan 27, 2009, 08:17 PM
Personal Sales Rating: ( 9)
Drives: apex silver evo 9
yeah just go with a bbk, or green you wont be disappointed in the results
Offline
Jan 27, 2009, 08:36 PM
Personal Sales Rating: ( 91)
Drives: ix mr
buy it and let us know...
Online
Jan 27, 2009, 09:48 PM
Personal Sales Rating: ( 1)
Drives: E8
I'm actually looking at the Tomei turbo. I saw this, and it seems cheap, so was interested to know if anyone has run it. Not interested in being the guinea pig!
Offline
Feb 17, 2009, 09:39 AM
Drives: 2004 EVO VIII
I will find out soon. It has the same turbine as the Green and a MHI 2nd generation 20G compressor. For the price it appears to be a good deal. About 1/2 the price of a green. Spooling may be a little slower than the green because the 20G is bigger than the billet 5 blade green. It also shoud flow more than the green but less than the red.
__________________
2004 Evo 8; Works TBE; Kamak TD06SL2R 20G; Ebay O2; Kelford 272 with GSC Beehives; Works Drop In Air Filter; Nisei LICP; Perrin FMIC; Evo IX DV; Walbro 255; GM 3 Port BCS; JDM 3 Bar MAP w/ PSI Based Boost Control; Self Tune @ 24 PSI
Offline
Feb 17, 2009, 09:43 AM
Drives: evo 8
keep us posted
__________________
12.2 @ 116mph
Offline
Feb 17, 2009, 10:35 AM
Personal Sales Rating: ( 2)
Drives: 03 EVO TB
Quote:
That's completely untrue. The 20g and Green have the same inducer size (about 52mm), but the Green has a larger exducer (68 vs 69.5mm I believe). The Green also has the advantage of a thinner hub area so it can flow more with a given inducer diameter, while saving rotational weight at the same time, which should help with spool.
Offline
Feb 17, 2009, 01:46 PM
Quote:
You are right and I said that the Green spools faster. Something is wrong with the specs. The Gruppe S site has the Green rated to 400 hp and the 20G to 450 hp.
I am sure the FP Green is a better turbo, I have no doubt about that. What I am trying to decide is if it is worth an additional $900 on top of the price of a 20G.
__________________
Offline
Feb 17, 2009, 03:02 PM
Personal Sales Rating: ( 12)
Drives: 2004 evo RS
probably a chinese knock off, I'd be weary of a turbo like that
Offline
Feb 26, 2009, 07:20 PM
Well I ordered it todat. It is an OEM 9 Turbo with modified turbine TD06sl2R (11 blades like the one in the FPGreen) and a MHI 20G compressor wheel. It comes with the Evo 9 install kit (All Mitsu OEM Parts). Lets see how is it. A lot of the Subaru guys in Australia have been using it for over 1 year with great results.
__________________
Offline
Mar 7, 2009, 03:28 PM
Personal Sales Rating: ( 28)
Drives: 2005 Evo VIII, 2004 Infiniti G35 coupe, 2007 Acura MDX Sport
Let us know the results. I just came across this turbo on ebay on my own today.
__________________
2005 Evo VIII: stock turbo, 24 psi with 3-port BCS, Buschur stg 3 head, HKS 264/272 cams, 750cc FI, Skunk2 catback, Perrin HFC/DP, PPI ported exhaust mani, Synapse BOV, ETS intake/IC pipes, Walbro 255 fuel pump, Megan coilovers, Hotchkis rear sway, Cusco front brace/trunk/rear strut bar, shifter bushings, Saikou Michi catch can, AGP motor mount, JDM MR taillights, 18x8 Rota Torque wheels, slotted rotors, SS clutch/brake lines, Hawk HPS, Spek gauges.
Offline
Mar 7, 2009, 04:00 PM
Drives: 2006 EVO IX
Quote:
Originally Posted by shadow1
let us know the results. I just came across this turbo on ebay on my own today.
+1
__________________
Subaru(STi) is a boys car, Mitsubishi(evo) is a man's car - Jeremy (Top Gear)
Blue EVO IX:
I have done enough that I'm worried of breaking stuff now!
On a nine turbo I made 366/369 on 91/Meth
New #'s on 11/07/2009 hoping for 450whp
Tuned by Me, Mayhem Tuning
Offline
Mar 7, 2009, 04:05 PM
Personal Sales Rating: ( 0)
1998 Mitsubishi Eclipse My Garage
Drives: '05 WW CT9A GSR SSL, '98 NW D32A
Quote:
Yeah but no, they put "AUTHENTIC ONLY – 100% NO FAKE ITEM" in the ad, so you know its good.
I'll say this, it doesn't carry a knock off item price. Good luck. I think I'd stick with a Green or Tomei.
__________________
Skeet
Driven to Thrill
Offline
Mar 7, 2009, 04:06 PM
Personal Sales Rating: ( 3)
1997 Mitsubishi Eclipse
Drives: 1997 Eclipse GSX
So its basically a real MHI turbo just modified by some company?
__________________
DSM>EVO
Offline
Tags
16g6, 20g, evo, fp, green, inducer, inlet, kinugawa, modifying, porting, size, turbine, turbo, turbocharger, turbochargers, wastegate  |
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
HTML code is Off
