Go Back   evolutionm.net > Lancer Evolution 1-9 Forums > Evo Engine / Turbo / Drivetrain
Welcome to EvolutionM.net!
Welcome to EvolutionM.net.
Old Mar 7, 2009, 04:16 PM   #16
Personal Sales Rating: (0)
1998 Mitsubishi Eclipse
My Garage
GPTourer's Avatar
Drives: '05 WW CT9A GSR SSL, '98 NW D32A
Send a message via AIM to GPTourer
Quote:
Originally Posted by JEFFREYCASTGSX View Post
So its basically a real MHI turbo just modified by some company?
Looks that way. They just open the case, intall a bigger wheel and go. But they're cheaper then we can get a stock new IX turbo here.
BTW, the "<" in your sig is backwards.
__________________
Skeet
Driven to Thrill
Offline
Old Mar 7, 2009, 06:17 PM   #17
Personal Sales Rating: (1)
Drives: 2004 EVO VIII
As I said I ordered it and have it with me. I will be buying some cams (GSC S1 or Kelford 272) and depending on the cams choice I will also need springs before I install it. Also I want to port the hotside and manifold before I install. If I get the cams I may do it on during Holy Week since I have a few days off work.
Here are a few pics of what I got. I got it for $840 shipped with the Evo 9 install kit (oil and coolant lines and gaskets). It also came with a 17 PSI actuator, kind of in the middle between the stock (~13PSI) and and high pressure (~22 PSI) actuator. I think I got a good deal. Like the OP says less than a brand new Evo 9 turbo. I think now the price went up to about $1100 plus shippping. This is what I got.
Hotside manifold side.
Compressor. MHI based 20G Wheel. This wheel has a smaller centre pillar than original MHI 20G which improves air-flow efficiency.
O2 housing side. I think this is the same turbine used in the FPGreen. It is bigger than the stocker Evo 9 and has 11 blades as opposed to the stock Evo 9 one which has 12 smaller blades. Hopefully this should help it spool like an FPGreen.
Compressor Close up. FPGreen is a custom 5 blade design. This one is a 20G based wheel which has 6 blades.
What do you guys think???
__________________
2004 Evo 8; Works TBE; Kamak TD06SL2R 20G; Ebay O2; Kelford 272 with GSC Beehives; Works Drop In Air Filter; Nisei LICP; Perrin FMIC; Evo IX DV; Walbro 255; GM 3 Port BCS; JDM 3 Bar MAP w/ PSI Based Boost Control; Self Tune @ 24 PSI
Offline
Old Mar 7, 2009, 06:58 PM   #18
4G63W8's Avatar
Nice,it looks very much like a green,identical i could say,keep us posted on the results,good price too
M.
Offline
Old Mar 7, 2009, 07:12 PM   #19
Personal Sales Rating: (2)
Steve93Talon's Avatar
Drives: 03 EVO TB
Send a message via AIM to Steve93Talon
Quote:
Originally Posted by racer135 View Post
ompressor. MHI Version 2 20G Wheel
FYI, MHI does not make a 20g wheel in reverse rotation.
Quote:
M.
Green has a 5 bladed billet wheel, far from identical.
Offline
Old Mar 7, 2009, 07:31 PM   #20
Personal Sales Rating: (86)
Its not genuine MHI. But the turbo does rock. I have standard rotation version on my evo 1 for five weeks now. converting fuel system to run e85 then I will have some numbers. this is same size turbo Tomie uses, just without the big compressor cover. Very close to green performance if not better. This 20g has the small hub and spools stupid fast. good luck with it.
__________________
early evo nut rockin
evo1 and evo 4
Offline
Old Mar 7, 2009, 07:33 PM   #21
4G63W8's Avatar
LOL,true,counted wrong,missed one
Offline
Old Mar 7, 2009, 10:54 PM   #22
Silver Sponsor
Personal Sales Rating: (17)
JohnBradley's Avatar
Drives: 06 Rally Red MR
Its also advertised as a TD06 and has TD05 stamped on it. I have tuned one and didnt see significant load change at a set boost level which typically indicates its not moving anymore air if there are no other changes.
That sales ad shows a really nasty casting line on the outside of the turbine which shows nothing of it is MHI. Then there is the fact it comes from Taiwan.
__________________
SparkTech The ignition of EnglishRacing
Extreme Turbo Systems Parts to go fast with
EnglishRacing contact us-sales@englishracing.net
Home of the 522whp stock turbo/no nitrous and 1117whp 2.0L turbo record.
My car- 574whp@29psi stock block, pumpgas, ETS and FP3586...for now.
Retailer of AMR Engineering Coilovers
MAGNUS Motorsport Cast Manifolds in stock, $1000 with ETS Magnus pipe, dual rail available also.
Proud retailer of GSC cams
FIC Master distributor
OmniPower USA Dealer
Offline
Old Mar 8, 2009, 07:07 AM   #23
Of course it has TD05 stamped since it is an Evo 9 housing. It has stamped TD05 and 16G6 but it is a TD06 and a 20G. Count the turbine blades. The TD05 has 12 blades this one has 11 and they are bigger. The turbine housing was bored to make it fit. The compressor housing was also bored to make the 20G fit the stock 9 turbo.
__________________
Offline
Old Mar 8, 2009, 10:06 AM   #24
Personal Sales Rating: (18)
pure_evo's Avatar
Drives: A Black Mamba in kill mode all day 'eh day as when I hit the gas she goes fast!
Subscribed. I'm not sure if any more threads of the Kinugawa exists but if you can post your results here, it would be greatly appreciated. Basically, what I'm able to gather this turbo falls as follows: stock IX, FP Green, and then Kinugawa, right?
__________________
--- Black Mamba tuned by the NTEC mad scientist with a bunch of "go fast" parts while diggin' in some V8 ass spittin' E85 venom! ---
Offline
Old Mar 8, 2009, 11:18 AM   #25
Personal Sales Rating: (12)
EVOIXreno's Avatar
Drives: 2006 EVO IX
Send a message via Yahoo to EVOIXreno
Quote:
it would most likely be evo 9, Kinugawa, then green!
__________________
Subaru(STi) is a boys car, Mitsubishi(evo) is a man's car - Jeremy (Top Gear)
Blue EVO IX:
I have done enough that I'm worried of breaking stuff now!
On a nine turbo I made 366/369 on 91/Meth
New #'s on 11/07/2009 hoping for 450whp
Tuned by Me, Mayhem Tuning
Online
Old Mar 8, 2009, 11:37 AM   #26
Quote:
Yes. Thats what I think. Evo 9, Kinugawa, Green, BBK Full
The real shocker for me is the price. Lets see how it performs.
__________________
Offline
Old Mar 8, 2009, 04:56 PM   #27
Silver Sponsor
TD06 is a compressor housing size. Your statement doesnt make sense therefore. I will say this right now that I have seen these lose power over stock. Possibly not this Kinugawa, but the chinese "20G TD06 Evo IX" turbocharger that has been sold in the past.
What is the inlet diameter of the compressor housing (ID) and the turbine outlet?
__________________
Offline
Old Mar 8, 2009, 06:42 PM   #28
Maybe I should have say TD06SL2R. That is the actual turbine wheel assembly. The hotside was bored to make the wheel fit. The turbine outlet diameter (where the turbine wheel is) is 55.6mm (2.189 in) and the compressor housing diameter is 54mm (2.126 in). Those are measured with a caliper so they are aprox figures.
Just out of curiosity. What is the rationale to have a bigger turbo loose power over a smaller turbo?
__________________
Offline
Old Mar 8, 2009, 09:51 PM   #29
Silver Sponsor
The aerodynamics of the compressor wheel. Swinging a 2x4 where you need a leading edge measured in thousandths will affect compressor efficiency and the given heat generated at any given pressure ratio. So if I have 30psi and have a post turbo temp of 300* versus an inefficient compressor and 450*, its obvious that no intercooler will make up that amount of difference and the larger turbo will be down on power.
There is still no MHI wheel that was engineered reverse in a TD06 as has been pointed out. It could say TD06SL2R-G6K 12.5T and it doesnt make it MHI. I am still curious to see if this is decent compared to the older Turbocharger.com TD06 20G Evo IX turbo that has been sold before. Just because its chinese doesnt mean its going to be crap.
__________________
Offline
Old Mar 8, 2009, 11:50 PM   #30
Drives: 2003 Evo
hmm... this looks interesting. Can't wait to see how this setup performs, best of luck to you
Offline
Tags
16g6, 20g, evo, fp, green, inducer, inlet, kinugawa, modifying, porting, size, turbine, turbo, turbocharger, turbochargers, wastegate
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
