Home Features Community Marketplace Registry Garage Store
Go Back   evolutionm.net > Lancer Evolution 1-9 Forums > Evo Engine / Turbo / Drivetrain
Sign in using an external account
Register Forgot Password?
Register Photos FAQ Members Calendar Search Today's Posts Mark Forums Read ExperienceUsed CarsGarageVendors TSB & Recalls
Search
Sponsored by: World Racing
Welcome to EvolutionM.net!
Welcome to EvolutionM.net.
Thread Tools Search this Thread
Old Jan 25, 2009, 02:39 PM   #1
Personal Sales Rating: (1)
Garage is empty, add now
Drives: IX FQ360
Points: 6,361, Level: 52
Points: 6,361, Level: 52 Points: 6,361, Level: 52 Points: 6,361, Level: 52
Daily Activity: 2.0%
Daily Activity: 2.0% Daily Activity: 2.0% Daily Activity: 2.0%
Fuel - Double pumper Vs Single inline
What are the advantages of the Double pumper over the single inline Bosch 044 fuel pump combined with a Walbro in-tank, or vise versa?
Offline
Old Jan 25, 2009, 02:42 PM   #2
EvoM Super Moderator
Personal Sales Rating: (149)
chaotichoax's Avatar
Drives: 2013 Subaru BRZ
Points: 31,941, Level: 100
Points: 31,941, Level: 100 Points: 31,941, Level: 100 Points: 31,941, Level: 100
Daily Activity: 0%
Daily Activity: 0% Daily Activity: 0% Daily Activity: 0%
the advantages are whether you need an additional fuel pump or not
if the walbro inline is enough then why go bigger
with e85 and race applications the need for a larger fuel system requires upgrading
Offline
Old Jan 25, 2009, 03:20 PM   #3
Drives: IX FQ360
needed to support gt35r.
Offline
Old Jan 25, 2009, 03:25 PM   #4
Personal Sales Rating: (10)
evoWWrs's Avatar
Drives: 2004 mitsubishi evolution RS
Points: 4,866, Level: 44
Points: 4,866, Level: 44 Points: 4,866, Level: 44 Points: 4,866, Level: 44
Daily Activity: 0%
depends on what injectors and with what gas your running and the power you are going for... im running 1600s with e85 so i would not need it, but im going to just in case, with 1600s and pump you need it for sure!!! if you are just running 1000s or 1200s you pry wont need it...
__________________
Quote:
Originally Posted by Rin Tin Tin View Post
WTH? Serious? At age 15, i had problems handling my penor. I wouldn't have ever been able to handle the raw power of an Evo. I would always try to be hiding it when walking around: putting books in front, walking sideways, trying to draw attention away from my crotch. And when they do see it, they look at me and say, "What the hell, Tin?" and I would respond, "I don't know man! It has a mind of its own.".
Offline
Old Jan 25, 2009, 03:31 PM   #5
Drives: IX FQ360
1000cc injectors.
I want to max out the 35r on pump fuel.
Offline
Old Jan 25, 2009, 03:38 PM   #6
Personal Sales Rating: (31)
Drives: the Blazin' Banana
Points: 4,788, Level: 44
Points: 4,788, Level: 44 Points: 4,788, Level: 44 Points: 4,788, Level: 44
Daily Activity: 12.9%
Daily Activity: 12.9% Daily Activity: 12.9% Daily Activity: 12.9%
Quote:
With e85 you will ABSOLUTELY need more fuel pump. I was easily maxing out a Walbro 255 and 1000cc injectors with e85 on my old gt35r setup. With e85 you need 30% more volume of fuel, which the 255 will have a very hard time delivering under high load/high boost applications.
As for the OP, you should be able to run pump gas to the limit of what pump gas will allow you with 1 Walbro.
__________________
English tuned, Soon to be English powered
old setup - 2.3/fp black - 11.7 @ 132.11 - 2.0 60', 29psi.
build in progress - 2.2/6466
I need driver mod.
Offline
Old Jan 25, 2009, 04:00 PM   #7
Personal Sales Rating: (150)
2005 Mitsubishi Lancer Evolution
jmelocik's Avatar
Location: BACK in the states!!! Until the next deployment!!!
Drives: 05 Evo VIII, 90 TSi AWD, 91 GSX, 91 GVR4, 02 Dodge Stratus, 73 VW Karmann Ghia, 89 Acura Integra LS, 08 WRX (wife and she loves it!) 06 Buell XB12R
Points: 530, Level: 10
Points: 530, Level: 10 Points: 530, Level: 10 Points: 530, Level: 10
Daily Activity: 1.6%
Daily Activity: 1.6% Daily Activity: 1.6% Daily Activity: 1.6%
Twin Walbro's in an in-tank setup will increase your volume but will not be able to increase your pressure more than a single Walbro can. A single Walbro followed by another high pressure pump such as the Bosch 044 can be used to increase the pressure well beyond what the stock pump or Walbro's can. The 044 is a great high pressure pump however it will not prime itself and to maintain max pressure you want it further up the line, closer to the fuel rail. This is why you would use a single Walbro in tank, to prime the 044 and since the load has been removed from the Walbro it can easily keep up with the volume demand of the 044. As stated earlier however, unless you are looking at alternative fuels you should be fine on the single Walbro for now.
Josh
__________________
Josh-
"Only two defining forces have ever offered to die for you; Jesus Christ and the American G. I. One died for your soul; the other for your freedom." author unknown
Offline
Old Jan 25, 2009, 04:20 PM   #8
Drives: IX FQ360
Why would it be needed further up the line, closer to the fuel rail?
Would it not be better closer to the walbro, less stress for the walbro?
Would this setup offer more fuel than a double pump?
Offline
EvolutionM
Mitsubishi Lancer
Paid Advertisement
Tags
044, benefit, bosch, double, dual, evo, fuel, inline, pump, pumper, single, specops, twin, vs, walbro
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
Powered by vBulletin® Version 3.8.7
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
Content Relevant URLs by vBSEO 3.5.2
All Passwords
