Go Back   evolutionm.net > Lancer Evolution 1-9 Forums > Evo Engine / Turbo / Drivetrain
Welcome to EvolutionM.net!
Welcome to EvolutionM.net.
Old Jan 9, 2009, 07:50 AM   #1
Personal Sales Rating: (9)
Unhappy Oil analysis HELP!
Ive been having intermittent knocking problems and I havent been able to figure out what it is. I had the top end checked out, a compression test and leak down test was perfect across the board. Im not consuming oil and the shop couldnt find anything wrong with my car besides the knocking. I decided to get an oil analysis. and here are the results.
The lead is VERY high but im not sure if its from the bearings or from something else. The oil had 3k miles on it and it was the oil used for all of the dyno runs while trying to troubleshoot the problem. There was a gallon of race gas that was run through the car and this might have contributed to the amount of lead in the oil. I have also run a few injector cleaners and "octane boosters through the car as well as seafoam just to give them a try.
My main question is could the high lead be from the race gas? Im sure the high amount of fuel that was in the oil is from me idling and warming up my car for about 10 to 15 minutes every morning so if there was that much fuel in the oil the lead surely would still be there correct?
Any input would be great.
thanks
__________________
Kelford 272 Cams
QTP Downpipe
Cobbs Exhaust
Test Pipe
Some sort of intake
Head Studs
ETS LICP
Walbro 255
Hallman MBC
Ivey Tuned
Offline
Old Jan 9, 2009, 08:48 AM   #2
Silver Sponsor
Personal Sales Rating: (97)
apagan01's Avatar
when you say knocking you mean it as a noise or as detonation ?
i am very sure if you told the analysis people what type of leaded fuel you are using they should be able to tell you from where its comming, they know the specs on the engine therefore thats how they can ID the problem. however its hard for them because you have 2 sources of lead bearings and race gas
__________________
Buy AMSOIL directly from our web site or PM us for direct pricing:
http://www.lubedealer.com/order/
Get Your AMSOIL @
-AWDmotorsports in South Florida
-TTPengineering in Central Florida
-Fynetune Performance in South Florida
-Brevard Super Bikes in Melbourne Florida
-Henrry's Pit Stop in the Saucier City, MI
-Harrison complete auto service, in West Orange City, NJ
-Ultimate CC, in Peekskill NY
-Performance Specialties, in Tucson AZ
Offline
Old Jan 9, 2009, 08:55 AM   #3
Silver Sponsor
apagan01's Avatar
another tip Brian, seafoam has Chlorinate solvents which contaminate the oil with silicone, it breaks down the oil very quick by contaminating it.
thats why @ Wynn's fuel system cleaners we dont use any CS at all, our MSDS states clearly no chlorinate solvents, i would stop using octane boosters and seafoam.
Try our 3 stage which will help you to get rid off all the carbon deposites inside the top end and you pistons and also your injectors get cleanned.
and use some good AMSOIL 100% synthetic.
__________________
Get Your AMSOIL @
Offline
Old Jan 9, 2009, 09:28 AM   #4
Thank you for the reply. I stocked using any sort of octane boosters since they dont work. I have emailed blackstone and told them what i used and ill see what they say. I want to get in another oil analysis before i tear off the oil pan to look at the bearings. Ill let you know of any updates
I just switched to amsoil for my tranny and love it I get back to you on the fuel system cleaner though!
__________________
Kelford 272 Cams
QTP Downpipe
Cobbs Exhaust
Test Pipe
Some sort of intake
Head Studs
ETS LICP
Walbro 255
Hallman MBC
Ivey Tuned
Offline
Old Jan 9, 2009, 09:29 AM   #5
Personal Sales Rating: (13)
dsmbruno's Avatar
Drives: an evo, duh...
Whats up? Give it a fresh oil change and drive it for a bit and then re-send it to get another analysis done. It could be all of the stuff you added may have altered the oil. If not, just sell me your R6 and go with a 2.3 stroker
__________________
"... I still don't know any better, I just don't have a mushroom haircut..."
WWW.IVEYTUNE.COM
AMSautowerks
Offline
Old Jan 9, 2009, 09:30 AM   #6
Silver Sponsor
apagan01's Avatar
Quote:
agreed^^^^
__________________
Get Your AMSOIL @
Offline
Old Jan 9, 2009, 09:59 AM   #7
Personal Sales Rating: (42)
Jeff_Jeske's Avatar
Drives: the racing line
Did the knock go away with race gas?
Stop using all those additives and simply change your oil with Mobile 1 every 3k miles. Call it a day.
If the knock doesn't go away with the race gas then its mechanical. If it does its your tune.
__________________
TARMAC BLACK 2006 EVOLUTION 9 SPECIAL EDITION
OHLINS DFV /// ETS FMIC /// ZEITRONIX WB & MAP /// JDM REAR /// PERRIN REAR SWAY BAR
JEFFJESKE@JEFFJESKE.COM
Offline
Old Jan 9, 2009, 10:06 AM   #8
It seemed like it did but i wasnt able to get on it as hard as i normally would because of the weather so i have to pick up some more gas and see. I want to try to get another 3k miles on the care before i add race gas and get another analysis done. Then ill give that a try again.
__________________
Kelford 272 Cams
QTP Downpipe
Cobbs Exhaust
Test Pipe
Some sort of intake
Head Studs
ETS LICP
Walbro 255
Hallman MBC
Ivey Tuned
Offline
Old Jan 9, 2009, 10:30 AM   #9
dsmbruno's Avatar
I really really really doubt its the tune.
__________________
WWW.IVEYTUNE.COM
AMSautowerks
Offline
Old Jan 9, 2009, 10:56 AM   #10
as do i! Ivey had it on the dyno about 100 times playing with the tune
__________________
Kelford 272 Cams
QTP Downpipe
Cobbs Exhaust
Test Pipe
Some sort of intake
Head Studs
ETS LICP
Walbro 255
Hallman MBC
Ivey Tuned
Offline
Old Jan 9, 2009, 11:44 AM   #11
Personal Sales Rating: (0)
lemmonhead's Avatar
Drives: evo 9, 4g Eclipse
my car is prone to knock up top also. I would increase MIVEC alot up top and see if it goes away. I know my car loves more MIVEC uptop then most evos where usually they zero it out completely or close to it.
1st do a fresh oil change and get it analysed.
Offline
Old Jan 9, 2009, 12:03 PM   #12
Silver Sponsor
Sean@Iveytune's Avatar
Drives: Ford F150HD Supercharged, R35 GTR 2010, 9 sec Fullweight evo8.
This car is more knock prone than others I have seen.
We add race fuel, octane goes up knocking goes away.
I am sure with time we could find what was wrong, there may be something in the motor causing it who knows.
Sean
__________________
WWW.IVEYTUNE.COM
DYNOJET AWD ON PREMISES!!!
2003 EVO8 9.17@159.6 MPH 3055 lb NO NITROUS! Full street!
1992 Talon AWD 9.41@151MPH (Oct 2005) Full exhaust, full glass 3122lb
1993.5 Supra 9.6@148 (Stock Auto, drag radials) 9.73@153mph 6 Speed!
Brandon's 1993.5 Supra 8.78@157.17 Slicks and BL400
HKS PRO DEALER!
Cobb Protuner "Live Data!"
Ecutek dealer, reflashes available for all yrs of evos.
Factory Trained Tuner FCON V-PRO, AEM EMS
, Haltech, Motec, Autronic.
Online
Old Jan 10, 2009, 03:09 PM   #13
Personal Sales Rating: (33)
Sean
LOOK AT YOUR FUEL DILUTION...
It is showing 3% which is 50% above Maximum allowable limits.
Your oil has also sheared to a 20 wgt which is common with Royal Purple.
Those two elements alone add up to no Film Strength.
You definitely need a tune if there is no mechanical issue such as a bad Injector.
I would recommend Trying AMSOIL PI Fuel treatment and change oil... AMSOIL RD-30 Racing Dominator would be an excellent choice. Information on these products can be found on this page http://www.bestoil4you.com/Evo.html
AMSOIL@bestoil4you.com
Doc
Offline
Old Jan 28, 2009, 07:07 PM   #14
AlwaysinBoost's Avatar
Drives: Prepared by evo8dad Wrecked by Oakes Detailing
so what did Blackstone say about the use of leaded fuel and your sample?
__________________
04 Weightless White GSR w/SSL
3" TBE - Ebay O2 - MBC - K&N - ECUFlash
12.06 @ 113.11 w/1.71 60' - 22psi/93oct
Disregard Females. Acquire Currency.
Offline
Tags
110, 2009, amsoil, analysis, dilute, eclipse, evolution, gas, ix, leaded, mandrel, mitsubishi, msds, oil, post, race, rd30, results
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
