Home Features Community Marketplace Registry Garage Store
Go Back   evolutionm.net > Lancer Evolution 1-9 Forums > Evo Engine / Turbo / Drivetrain
Sign in using an external account
Register Forgot Password?
Register Photos FAQ Members Calendar Search Today's Posts Mark Forums Read Used CarsGarageVendor Directory
Search
Sponsored by: World Racing
Welcome to EvolutionM.net!
Welcome to EvolutionM.net.
Thread Tools Search this Thread
Old Dec 30, 2008, 06:00 AM   #1
Personal Sales Rating: (0)
Garage is empty, add now
Drives: 2003 EVO VIII Tarmac Black
Send a message via AIM to SteveThePirate Send a message via Yahoo to SteveThePirate
Unhappy Car wants to stall in 1st gear and reverse. Need help!
Hey guys tried everything i can think of, and my car keeps acting weird. It acts like its gonna stall when slowing down and its still in 1st gear and the clutch is in. also when in reverse and the clutch is in. i just replaced my forge BOV with the OEM evo 9 BOV. Could this have an effect on the idle or be causing it to wanna stall? I checked and rechecked all my vacuum lines. and there all intact and zip tied also. I found a kink in the one from my BOV and replaced it last night. Seemed to be running fine for a while and then the same problem came back. I got a mail in flash a while ago and it seemed to fix a lot of problems i was having with idle issues. Could putting an OEM BOV on cause this? could really use some help. ive exhausted every possibility i can think of...
Offline
Old Dec 30, 2008, 06:06 AM   #2
Personal Sales Rating: (19)
Drives: mitsubishi evo 8
any codes from the ecu?
__________________
04 E55 AMG
05 GSR
Tuned by Mellon
|455WHP 415 WTQ 93 Pump 27psi, VD 1.1.3 ( 65 degrees outside|
|Built 2.0 Shortblock Stock Compression Stock Head BC Springs and Retainers|
|Power Mods|
|HTA FP Green 84mm Cover 25psi WGA|
|"Custom" Ebay TBE Added 18 Inch Resonator and Quiet Muffler|
|APS DV|Joe P MBC|
|FP 4R Cams and Intake Pipe|
|Buschur; SS o2, Cone Filter,|
|Stock Exhaust Manifold Jet Coated|
|FIC 1050's|Walbro 255|
|ETS 3.5 FMIC, LICP v2 |Stock UICP|
Offline
Old Dec 30, 2008, 06:08 AM   #3
Personal Sales Rating: (18)
getsideways's Avatar
If it started happening when you put your 9 bov in what changed ????? did your previous one vent to atmosphere versus thisone recurculating if so and your tuner tried to compensate for your old one thats where some of your trouble could be. also is your airbox/intake lose .... might have to make a list of your mods as this could help,,,, on a hugecammed large injector flimsy airbox evo i would say this is almost normal and usually the stock BV will help this not hurt it....
Offline
Old Dec 30, 2008, 06:17 AM   #4
havent hooked up to the ecu for any codes. no check engine light though. and the Forge one i had didnt vent to atmosphere either. just couldnt get it to work right even with changing out the springs. so i just went OEM finally. heres what ive done to my car:
O2 housing
downpipe
cat-back (factory cat still on there)
walboro 255 fuel pump
k&n intake
forge bov/evo 9 oem bov
aem tru boost controller (which i just completely disconnected the other day)
Offline
Old Dec 30, 2008, 06:27 AM   #5
I had a little trouble with my aem intake you might swap it out for the stock one go run around and see what you think of the difference see if it goes away,,, also you might need to bump your idle up to 1050ish if thats what the problem is.... most you reported having this issue think it was linked to the factory MAF getting harsh reading because of the cone filter.... hope this helps
Offline
Old Dec 30, 2008, 06:31 AM   #6
right on ill try that. just weird that it starting acting up the other day. has been fine for a while. so most likely theres no problem with the BOV its that stupid intake?
Offline
Old Dec 30, 2008, 06:36 AM   #7
One more thing if your running copper spark plugs as some use because they want to go a step colder copper plugs foul very easily when i was using them i had to change them every oil change,,, might be worth pulling at least one just to make sure .
Offline
Old Dec 30, 2008, 06:47 AM   #8
no i havent changed my spark plugs. there still OEM. last time i had her in for a check up was like 2 weeks ago and everything was a ok. but i actually just thought about that. if i have a bag plug it would cause something like this wouldnt it?
Offline
Old Dec 30, 2008, 07:12 AM   #9
Personal Sales Rating: (9)
ExplosEvo's Avatar
Drives: 03 Evo VIII
I have similar issues. I have the metal 9 BOV, and the AEM intake and sometimes when I am slowing to a stop and push in the clutch the car will stall. Its mildly annoying, but not that big of a deal. I was hoping its something that a tune will fix one day when I get around to getting said tune.
Offline
Old Dec 30, 2008, 07:20 AM   #10
Yes to both of the above tune will help and plugs could cause it
Offline
Old Dec 30, 2008, 08:38 AM   #11
Personal Sales Rating: (10)
S6devil's Avatar
Drives: '14 E350 sedan; '13 C250 coupe; '12 Cayenne hybrid; '96 4Runner 5sp.; and of course Evo IX MR :)
Quote:
i have the same exact problem. started to occur few weeks ago, after my clutch started to slip. so i think its cause of the clutch. perhaps it doesnt grab fully (while u r barely rolling in 1st gear) so thats why the car kinda almost stalls... and it doesnt occur in 2nd gear cause by then u r moving faster, and your rpm is above idle - so no stalling
same would occur if imagine, u are on a normal car with a manual trans., u try to start moving from a standstill by just letting go of the clutch pedal slowly, without giving any gas. u know the car will barely start moving, while almost stalling.... and eventually just start moving....
i guess i will wait till i replace the clutch next month, and see if that fixes it.
P.S. btw, this doesnt happen while the car is cold (cause the rpm is higher). but once the car is warmed up, and idle rpm is back down to like 700rpm, then this thing that u r describing happens....
__________________
Quote:
Originally Posted by HobieKopek
I actually like S6. :lol: He's not worthy of OT prominence yet, but his heart's in the right place.
Offline
Old Apr 15, 2010, 11:18 AM   #12
Personal Sales Rating: (1)
ravnos04's Avatar
Drives: 2010 PB X
same here with it not stalling when it is cold, but when the engine is optimum temp it will do that. I also did a test just now with having the car not in gear and revving to max RPM and just releasing the gas....went to norm idle no prob. Did the same thing in 1st gear, but the clutch pedal in (disengaged) and revvd all the way to the limiter. Let off and went to normal. Only when the clutch is engaged and the car moving forward/revers does the stalling issue come into play.
__________________
2.2L Overbore / Darton Sleeves / Jack's Transmission / Built & Ported Head / AGP / Competition / Injector Dynamics / Buschur / GSC
675hp / 520tq @ 5000ft
Offline
Old Apr 15, 2010, 11:49 AM   #13
ravnos04's Avatar
Drives: 2010 PB X
also just to add...my idle is at like 1000-1050 with AFR at like 15.4-15.6.
__________________
Offline
EvolutionM
Mitsubishi Lancer
Paid Advertisement
Tags
1st, car, clutch, engine, evo, forward, gear, idle, moving, reverse, rolling, slowing, stall, stalling, stalls
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
Powered by vBulletin® Version 3.8.7
Copyright ©2000 - 2014, Jelsoft Enterprises Ltd.
Content Relevant URLs by vBSEO 3.5.2
All Passwords
