Duel fuel rail setup
I have a Magnus V5 (see pic) and have dual rails on it. I need to get them hooked up now and was wondering that is the best way to do this.
I do have larger feed & return lines all the way from the tank to the engine bay and I need to go from the one line to two lines for both feed & return.
I know Buschur has a kit but I don't want to pay the $250 bucks for it. If you have pictures of this that would be a huge help.
Actually it's because the part that David sells the Y are made out of plastic and I don't feel comforatable using them. Go on his site and look at them.
The part that APM racing suggested will work fine and is made out of metal and since I am running e85 all the time I don't want anything to happen to them. There was a thread in here of a guy that had a DP from Buschur and when he romeved it from his tank it was brown from sitting in E85. Since the DP is made out of plastic also I don't want there to be any issues since I don't drive my car in the winter so it's sits there all year long without moving or being started. I don't want the integrity of the plastic to break over time.
I have thrown enough money into this car to save a few bucks here and there.
Also since none of you have ever tuned in Colorado where the air is thinner you suck more fuel. I already maxxed out at 110 latencey some 1600cc Precsion injectors.
Same thing happened with a different tuner on my old 35R setup. I ran out of fuel, so since I want to push this car hard like 45 psi I don't want to run into the problem again of running out of fuel. I wquld rather have more fuel than less and have to do things over again.
Besides I got these parts for a steal and didn't turn it down.
I agree there is no point in running dual rails if you run one fuel like E-85. Its smarter to run FIC2150 in one rail and keep it simple.
Now if you want the ultimate setup. Run two rails with different fuels in each.
primary can be 560 evo injectors = low octane fuel available everywhere. perfect drivability maintained.
secondary rail comes live under boost. secondary fuel can be e99, vp import, or any other fancy fuel that is only being used during boost. This setup offers too many advantages to list.
But as I stated in another thread and it's on FIC's website you can't run race gas on the 2150
So why put myself in that postition? Why put myself in the postition to run of gas again only to remove everything again and send it off to get customized after the fact.
Even if I don't need the second rail I got these parts for such a good deal I can deal with the few dollars I spent on them. Please look at my signature to why I got good deals on some of the parts.
Now since the last time I touched this car my financial situation has changed drastically. So rather than have you guys cut me down why don't you all help me with this by inputting valuable information and then I can get some solid numbers.
