Go Back   evolutionm.net > Lancer Evolution 1-9 Forums > Evo Engine / Turbo / Drivetrain
Welcome to EvolutionM.net!
Welcome to EvolutionM.net.
Old Dec 31, 2008, 07:30 AM   #16
Personal Sales Rating: (2)
rose0529's Avatar
Drives: 2006 Lancer Evolution IX SE
Glad you got it all fixed up, I'm gonna have to get this taken care of next time my car is over at your place for an install!
Offline
Old Dec 31, 2008, 07:35 AM   #17
Personal Sales Rating: (56)
tvieira24's Avatar
Drives: 04 EVO VIII, 06 Audi A4
Send a message via AIM to tvieira24
Seems to be a pretty common occurance.
On the other hand I bought my EVO with a flood title and I've checked all the connections on the harness and they are all as right as rain.
I sealed up mine anyway just in case. It seems like the damaged is caused while the car is operating.
Offline
Old Dec 31, 2008, 08:05 AM   #18
Steve93Talon's Avatar
Drives: 03 EVO TB
Send a message via AIM to Steve93Talon
You're begging for another failure with those crimp connectors. Solder those wires!
Offline
Old Dec 31, 2008, 08:15 AM   #19
Personal Sales Rating: (6)
scheides's Avatar
Drives: 05 Evo8 SSL
Quote:
I was not about to solder every last wire w/o sticking them all together and testing. Furthermore, It's so cold out my soldering iron will not hardly get hot enough to melt the flux. I'll be soldering them when it gets warm enough (um....as stated in original post )
Offline
Old Dec 31, 2008, 01:51 PM   #20
Personal Sales Rating: (26)
Evolessfornow's Avatar
Drives: '08 GG X & '05 Civic R.I.P '05 WW Evo 8
Send a message via AIM to Evolessfornow Send a message via Yahoo to Evolessfornow
I don't see a screwdriver pointing to any seal in the pics.
__________________
"This won't increase my ability to mate?!?"
Offline
Old Dec 31, 2008, 03:48 PM   #21
Personal Sales Rating: (20)
DaveK's Avatar
Drives: Evo IX rally car
FWIW, look at the Evo wiring harness...you won't see many soldered connections in there. Leave the crimp connectors, but if possible, heat shrink them down so there isn't vibration at the crimps. Soldered connections will vibrate and crack over time.
Dave
Offline
Old Dec 31, 2008, 03:53 PM   #22
Personal Sales Rating: (28)
Drives: 2003 apex silver EVO VIII
I really hope you go back and solder all of those.
Offline
Old Dec 31, 2008, 04:42 PM   #23
Drives: 03 EVO TB
Quote:
Dave
You can't really compare an OEM machine made harness (many times with vibration and liquid resistant connectors) to a butt connector. Over 10 years working in car audio, I've seen countless crimp connectors fail, and maybe 2 cold solder joints.
Offline
Old Dec 31, 2008, 04:51 PM   #24
DaveK's Avatar
Fair enough, but you also can't assume that everyone can solder like a pro. My background is in rally cars, and those cars get vibrated around soo much that soldered connections aren't the way to go. I use crimp connectors that have the heat shrink on them which spreads the stress on the connection out and I've yet to have one of those fail. I've seen other rally cars have wiring issues, and many of those come back to cracked or partially cracked solder connections.
FWIW, only ~1/2 of those are the heat shrink kind of connectors used in the OP's pics.
Dave
Offline
Old Jan 1, 2009, 10:31 AM   #25
Personal Sales Rating: (1)
whitey4d's Avatar
Drives: 04 white EVO,93 awd TSi
Im a certified toyota tech. I hate to tell everyone that the same stuff happens to all makes of cars. If you were to see all the TSBs out on newer toyotas you wouldnt think that they are the "best car made today"
Nissans are even worse I cant tell you how many recalls and problems people complain about with them. I bought my sentra brand new as a beater so I dont have to drive my EVO in the winter and hog it all up. I had a IPDM take a dump in less then 2K mi. and a window bind and break inside the door at 5K.
I guess what Im getting at is that its a15K car with a 15K powertrain. Even 40+ K cars that are top rated still have issues cause they are made by machines that made by us- Humans.
__________________
Buschur Built: JE/Crower,stg 3 head, BF272s, 1K PTEs double pumper, tubular 82mm HTA with a.63 housing, newly installed BR Race Core.
480whp unfiltered BR MD Dyno, 544 whp Dynojet STD correction, 3rd gear, 31 psi, Stock ECU and MAF. Straight Shell 93 pump.
Currently running 94170015 V5.10 with SD Patch(Omni 4BAR) 531 whp 406 tq 4th gear, 519 386 3rd, CBRDs MD 33 psi straight pump Shell 93 Self Tuned
Offline
Old Jan 3, 2009, 08:49 AM   #26
2005 Mitsubishi Lancer Evolution
gear head's Avatar
Drives: 05 evo
Quote:
Butane soldering torch is the only way to go.....problem solved
__________________
damn the man
Never underestimate the power of stupid people, they can accomplish many.....many stupid things.
Offline
Old Jan 3, 2009, 02:37 PM   #27
scheides's Avatar
Drives: 05 Evo8 SSL
Quote:
It doesn't solve the problem of my fingers freezing off or my knees aching like a mofo on the cold-ass garage floor. Bring your torch over and solder it for me if you're so confident
I used those heat-shrink crimp connectors on about half the harness, that's all I had on hand. I've found them to go the distance. ...should I say it again? I'll probably re-do it this spring..
I dare someone else to tell me that I had better solder those connections.....seriously wtf! If you wanna post that, come and help me do it....if not, kthxbye, no comments needed. I posted this thread to spread information about this problem, not get berated or even open a damn discussion on soldering vs crimping, there is no contest that soldering is the way to go.
Offline
Old Jan 3, 2009, 05:19 PM   #28
2003 Mitsubishi Lancer Evolution
Slo_crx1's Avatar
Drives: '03 Evo 8, '04 WRX, 89 Honda Civic
This is a pretty common problem, myself and at least 3 others near me that I know with Evo's have had to do this already. It seems that in Mitsubishi's almighty wisdom they put the windshield vent drain tube right over top of the rubber boot that the harness comes in through.
__________________
10+ years of tuning and boost drove me to drink
EcuFlash tuned by me @ 28psi with Speed Density conversion, no spike w/open dump mod on 93oct and no knock with all the bolt-on's...Holset/top mount/2.3 coming soon...
Offline
Old Jan 3, 2009, 06:16 PM   #29
EvoM Moderator
Personal Sales Rating: (12)
MR Turco's Avatar
Drives: WW Evo IX w/ SSL/SE, 2000 Sentra SE w/ SR20
I actually had this grommet pop out when running some wires so i decided to address this issue early. From what i could tell there is definitely an opening where water could sneak in. I ran silicone around the entire grommet, around the stock wiring harness and around the wires i ran through it. I checked my sunroof drain and it definitely was no where near the grommet so i dont suspect i would contribute to the problem but if water got past the well cover i could see it wreaking havok.
__________________
-Mike
The Rules - love them
TephraMOD V7 - now serving 25x30 fuel and timing maps and Gear Dependent Boost Control
Quote:
Originally Posted by beavis820 View Post
turco is a damn fine mechanic without me
Offline
Old Nov 1, 2009, 07:33 PM   #30
scheides's Avatar
Drives: 05 Evo8 SSL
Bump! Check this NOW if you haven't already.
Offline
Tags
common, dsm, dsms, e85, evo, freeze, mileage, plug, plugs, pump, rtv, size, things, water
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
