Go Back   evolutionm.net > Lancer Evolution 1-9 Forums > Evo Engine / Turbo / Drivetrain
Welcome to EvolutionM.net!
Welcome to EvolutionM.net.
Old Sep 30, 2009, 01:37 PM   #166
Personal Sales Rating: (5)
Drives: Evo VIII/SVO Mustang/BMW E30 M3
I was prepared to switch to the Boomba' but that involves removing the manifold and sending it off to be reflanged. I did my best to avoid that. I've been through enough already.
All Hypertune had to do was send me a working part. They chose to abandon me, but fortunately, it looks like I was able to cobble one good TB from two unusable ones. This situation speaks for itself. I need not add anything further to it.
Caveat emptor!
__________________
Ted B. Spec JAM LR 2.0L - Headway Perf CNC Head - DI Int Man - 75mm Hypertune TB - HTA3582 TS 1.06 A/R T4 - 12mm lift Billet Cams - MPFab TS T4 Manifold, TBE, UICP, LICP - MPFab FMIC - TiAl 44mm WG - Skunk2 Pro Cam Gears - FIC Bluemax 1250cc - FullBlown Dual 255lph - Synchronic BPV - Spark Tech COP Ignition - TRE Trans - Shep TC + LSD - SPEC Super Twin P-Trim Clutch
Offline
Old Sep 30, 2009, 05:24 PM   #167
Personal Sales Rating: (0)
JC evo1's Avatar
Drives: EVO1
Quote:
Originally Posted by MOREPSiTEHBETT4 View Post
sounds like hypertune ftL in the customer service/sattisfaction department. Good luck with the rest of the build, sad to see such a cheap part cause such a huge issue.
yeah my experiences with them were pretty bad as well, i waited 4 weeks for my intake manifold that was suposed to be on the shelf. They make some pretty good products but there service lets them down big time. Anyway glad you've finally got it sorted Ted.
Offline
Old Oct 19, 2009, 07:29 PM   #168
Personal Sales Rating: (4)
Drives: 03 EVOLUTION
heard your car is running and wanted to finally see some results hahah
Offline
Old Oct 19, 2009, 08:00 PM   #169
I'm working on it. Everything's ok save for two issues:
(1) A missfire issue that suddenly arose - actually, it feels more like boost cut, and I'm trying to find the cause.
(2) A starting issue that so far, isn't the starter, solenoid, starter relay, or clutch switch. We think it may be the switch in the steering column. Go figure.
When I can finally get everything working at the same time, I'll provide an update. The stupid issues I've endured with this car seem to never end.
__________________
Offline
Old Oct 19, 2009, 09:28 PM   #170
sounds like i lol. lookin forward 2 resuls
Offline
Old Oct 24, 2009, 05:39 PM   #171
NitrousOxide's Avatar
Drives: 2006 EVO IX GSR
What is ur HP/TQ now?? Pump?
Do you have any graph??
__________________
-Waleed
Quote:
Originally Posted by n2oiroc View Post
i bought my evo with the ssqv on it. god is it horrible! sounds like a crow stuck in a meat grinder.
Offline
Old Oct 24, 2009, 07:32 PM   #172
JC evo1's Avatar
Drives: EVO1
I had a similar problem, tracked it down to the (new) set of custom leads, sent them back and got some apparently even better ones made up and they did the exact same thing, put my ****ty old high resistance magnecores on and it ran perfectly. No idea what the issue was but the MSD cdi did not like the low resistance leads one bit. Anyway my point is sometimes the part you least expect to cause problems does feck up.
Offline
Old Oct 24, 2009, 08:11 PM   #173
The ignition worked fine before this last go-round. I can't see the fault, but Craig of Sparktech is on top of it.
Anyway, while we're getting that sorted, I am installing the Omni 4-bar MAP sensor, so I'll be able to provide boost logs with the power graphs.
__________________
Offline
Old Dec 20, 2009, 08:09 AM   #174
Personal Sales Rating: (2)
miragevo's Avatar
Drives: 2006 Evolution IX MR, 2008 BMW X-3, 2009 Honda Fit Sport
Still waiting for results......
Offline
Old Dec 20, 2009, 08:34 AM   #175
If you're awaitng results from my car, you could be waiting awhile. All aggravations are fixed now, but I am still tuning the 93 octane base map in between business trips. It's already well over 500whp though (according to VDR anyway), and I haven't yet tuned the ignition map.
__________________
Offline
Old Dec 20, 2009, 11:22 AM   #176
R/TErnie's Avatar
Drives: TB Evo IX
Send a message via AIM to R/TErnie
Ted,
check your plugs and your gap. I had a misfire (felt like the car farted fuel) turned out my spark plug gap had opened up. I put in some new Denso plugs gapped at .018" and I was good to 40psi on the Red
check the coil dwell thread on ecuflash (if that's relevant) it may also help.
__________________
FOR SALE
http://forums.evolutionm.net/sale-en...l-flanges.html
Quote:
Originally Posted by My boss
If you wait until the last minute to do something, it will only take minute.
Offline
Old Dec 20, 2009, 06:32 PM   #177
Personal Sales Rating: (1)
Drives: 2006 EVO IX, RB26DET'd 1995 240SX, 1991 Acura NSX
Quote:
Originally Posted by R/TErnie View Post
Ted,
I also had a buddy local with an MR IX that was doing weird things. I drove his car and around 14psi the car would hit a wall and not make any more boost. I thought it was perhaps a boost leak, but it was not. He took it to the local dealership and saw a code of misfire on #3 cylinder. A piece of the porcelain had broken off the spark plug and caused the issue.
__________________
1991 Acura NSX
1994 RB26 240SX
2006 EVO IX
Offline
Old Dec 20, 2009, 08:19 PM   #178
I've resolved the misfire and all other issues as far as I can tell. No more misfire, leaky compressor covers, leaky TBs with the incorrect springs, leaky ICs, and other bizarre aggravations. The engine runs cleanly. On my base 93 octane tune, it's already showing around 430 load and 3100+Hz with knock count at virtually zero. The TS HTA3582R is amazing to drive, and never feels dead.
__________________
Offline
Old Dec 20, 2009, 10:21 PM   #179
R/TErnie's Avatar
Drives: TB Evo IX
Dyno ted.... Dyno!
__________________
FOR SALE
Offline
Old Dec 21, 2009, 06:31 AM   #180
nice project....
Offline
Tags
911, eclipse, ej1, gt35r, gt37, hotside, hta3582, hta3586, kit, manifold, project, scroll, t3, ted, turbo, twin, twinscroll
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
