Dec 19, 2008, 03:42 PM
Personal Sales Rating: ( 0)
HTA 3582 & 3586 LBS airflow?
Anyone know the airflow #'s on the HTA 3582 and 3586?
Offline
Dec 19, 2008, 04:37 PM
Drives: EB ExoIX
Hta86 is over 75lbs/min
Offline
Dec 19, 2008, 07:39 PM
Personal Sales Rating: ( 1)
The 3582 ~70 lb/min, 86 is ~75-80 lb/min. Specs that FP gave me.
Offline
Dec 19, 2008, 08:09 PM
Personal Sales Rating: ( 3)
Drives: 2005 Lancer Evolution IX Wagon
Quote:
thats a whole lot!
Offline
Dec 19, 2008, 09:30 PM
Personal Sales Rating: ( 2)
Drives: EVO IX GSR, 09 FX35, Jag X-Type
how much lag difference these turbos have again?
Offline
Dec 19, 2008, 11:48 PM
Quote:
Probably nothing noticeable, the 86 has a larger compressor exducer and thats the only change.
Offline
Dec 20, 2008, 01:06 AM
Personal Sales Rating: ( 8)
Anyone know what the HTA T4Z flows.
__________________
Chris-
95 Z28M6-383ci T-76 w/Air2WaterIC
90 TSi (AWD) Stuff@20psi
03 EVO 8-11.6@123 old 30R setup
97 Mitsu Galant (gas saver aka A to B ride aka workhorse)
"I hope you're thirsty, because you're ugly and stupid, and I can do something about thirsty" -Advent Rising
Offline
Dec 20, 2008, 01:11 AM
Drives: 2003 evo8 gsr
Quote:
__________________
jam stage 4 2.3l short block ,jam stage 3 cilender head ,
full race turbo kit wid t4z88hta ,bf272 cams ,fidenza cam gears ,greddy type s bov ,injen hard pipe kit ,ets 4" fmic ,apexi power fc d jetro ,aem 3.5bar map sensor,apexi avcr,greddy evo2 exaust system,1200 injecters ,full blown double pumper,ams vsr,
quarter master twin disc ,apexi turbo timer ,defi gauges complete set ,hks fan temp controller hks 4"intake,spark tech cdi cop ....
Offline
Dec 20, 2008, 01:42 AM
Silver Sponsor
Personal Sales Rating: ( 17)
Drives: 06 Rally Red MR
82 lbs/min?
Offline
Dec 20, 2008, 05:37 AM
I believe LT1runner is refering to the HTA88.
Offline
Dec 20, 2008, 07:37 AM
Probably ~80 lb/min. Normal T67/37R is 75 lb/min.
Offline
Dec 20, 2008, 06:46 PM
Personal Sales Rating: ( 6)
what rpm difference would the spool characteristics be for a gt35r- hta35r- hta3586? i was told that you should see increase 150rpm difference in spool going to a hta35 from a gt35r. and you would see a delayed 300 rpm spool difference from a gt35r to a hta3586.
was also told that with a hta35 you would see an average of 15-20 hp difference across the whole rpm range. is the info correct?
Offline
Dec 20, 2008, 06:57 PM
Personal Sales Rating: ( 4)
Drives: Evo VIII/SVO Mustang/BMW E30 M3
An HTA3582 appears to spool about 300rpm quicker than a standard 35R, and it is capable of around 10% greater whp and torque. It's a win-win situation vs. a standard 35R.
IIRC, the HTA3586 spools slightly slower than a 35R, and is good for more power than an HTA3582. If this is accurate, that equates to probably ~500rpm or so difference between both of the 35R variant HTAs.
Both HTA3582 and HTA3586 are 700+whp capable turbos.
__________________
Ted B. Spec JAM Long Rod 2.0L - Headway Performance CNC Head & Valvetrain - DI Intake Manifold - 75mm Hypertune TB - HTA3582R Twin Scroll T4 - Machined 12mm lift Billet Cams - MPFab twinscroll T4 Manifold, TBE, UICP, LICP - MPFab Race FMIC - TiAl 44mm WG - Skunk2 Pro Cam Gears - FIC Bluemax 1250cc - FullBlown Dual 255lph - Synchronic BPV - Spark Tech COP Ignition - TRE Trans - Shep TC + LSD - SPEC Graphite Dual Disc
Offline
Dec 20, 2008, 07:28 PM
Personal Sales Rating: ( 23)
Drives: 03 Evo VIII, 96 Beretta
IMO, the HTA86 spools the same as a standard 35r
__________________
Buschur Racing Powered / HTA86
576 whp / 432 trq (DLL Dyno) Stock Block/Head/ECU/Tom Klemann tuned
http://www.buschurracing.com
Offline
Dec 20, 2008, 07:43 PM
Ted b thanks for the info
at what rpm does your turbo come on and at what rpm are you seeing full boost psphinx81?
Offline
Tags
3582, 3582hta, 3586, 3586hta, 35r, 86, airflow, fp, gt35r, hta, hta3586, lbsmin, results, t4z, turbo  |
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
HTML code is Off
