It's hard to ask where 'full boost' comes about simply because full boost means 22 psi for one person and 40 psi for someone else.
If any back-to-back test exists, I haven't run into it. What I did is compare AWDMike's dynochart with Buschur's posted on the FP website. Taking into account a 12-15% difference between those two dynos (and that is being conservative), I looked at the points where each crosses 300whp. The difference looks to be about 500rpm.
I'm seeing 20psi between 3900-4000rpm in 3rd gear with the HTA82R, but I have a twinscroll setup, so that may not be typical. I'll stop short of pushing things past 700whp, so the quicker spool time works for me.
__________________
Ted B. Spec JAM Long Rod 2.0L - Headway Performance CNC Head & Valvetrain - DI Intake Manifold - 75mm Hypertune TB - HTA3582R Twin Scroll T4 - Machined 12mm lift Billet Cams - MPFab twinscroll T4 Manifold, TBE, UICP, LICP - MPFab Race FMIC - TiAl 44mm WG - Skunk2 Pro Cam Gears - FIC Bluemax 1250cc - FullBlown Dual 255lph - Synchronic BPV - Spark Tech COP Ignition - TRE Trans - Shep TC + LSD - SPEC Graphite Dual Disc
