Dec 5, 2008, 02:57 PM
Gold Sponsor
Personal Sales Rating: ( 44)
BR ported intake/65mm throttle body pictures
I just wanted to post to let everyone see some pictures of the before and after intake manifolds/throttle bodies we do here.
Typically the intakes come in pretty filthy. Dirty, nasty and the ports are full of oil. This of course is from the valve cover breather being routed back into the turbo inlet, the PCV and the EGR valve. They make a mess of the inside of the intake manifold.
Here is a picture of the runners on a typical intake manifold we get in:
Here is a picture of the throttle body inlet on a typical intake manifold we get in:
After the intakes are received we clean them so we can start the porting process. The intake manifolds are marked at the cylinder head and throttle body openings so they will match our 65 mm throttle body and match the ports on the cylinder head.
The runners are ported as deep as our porting tools will allow. It isn't just a simple gasket matching that extends in an inch. The shape of the port is changed and the port work extends into the runners approximately 4 full inches.
Here is a picture of the runners after porting on the intake manifold:
The throttle body end is critical to getting the performance increase from your 65mm throttle body. If you don't increase this area properly you may as well skip the upgraded throttle body.
Here is a picture of the throttle body end after porting:
The throttle bodies also come in pretty dirty. These are cleaned and glass beaded to give them a new appearance.
Here's a picture of how a typical throttle body comes in:
The throttle bodies are opened up for our larger brass throttle plate. The throttle shaft seals are all replaced during the process of re-assembly.
Here is a picture of the throttle body after cleaning, glass beading, boring/porting, new throttle plate, new seals and assembly:
On a 300 whp build you can expect to see SOLID gains of 15 whp+. These gains will start in the 3,000 rpm range and continue throughout the entire operating range. As the horsepower of the car increases the increase from the ported intake and throttle body also increases. Gains of 30+ whp and 30+ ft lbs have been seen on 600+ whp EVO's.
We do go the extra mile on our port work and throttle bodies. This shows in the 12, 9 second EVO's we built using this, this year.
Also, as a side note. To those of you running stand alone's that no longer need the nipples on top of the throttle body or are running our catch can and no longer need the nipple on the side of the intake manifold, we can remove those pieces for you and plug them. The throttle bodies have the holes welded shut on the top and the intake manifolds are plugged with a soft plug. Just another option at a small additional charge for anyone wanting them modified like that.
__________________
David Buschur
www.buschurracing.com
www.highboostforum.com
First 4g63 in the 12's, 11's, 10's, 9's, 8's and 7's.
WORLD'S FIRST EVO8 IN THE 8'S
WORLD'S FASTEST EVO8, 172.74 MPH.
WORLD's First EVO in the 9's on pump gas.
STOCK ECU's:
BR EVO X, pump gas, 11.71@124.01 mph
Project White, E85, 10.35@138.53 mph
Offline
Dec 5, 2008, 03:02 PM
Personal Sales Rating: ( 17)
Drives: 04 evo vlll
Great shots there David.
Top notch product out of the Buschur camp is a sure shot!!!!!
__________________
PROJECT 1320
OLD SETUP 11.18 @ 124.72 MPH W/30R
BUSCHUR RACING STAGE3 E85 BUILD COMPLETE!!!!!
650 WHP / 561 FT.LB.
CHECK OUT OUR WEBSITE FOR ALL OF YOUR HVAC NEEDS!!!
WWW.RGNICELY.COM
Offline
Dec 5, 2008, 03:08 PM
Personal Sales Rating: ( 25)
Drives: 2005 GTO 525RWHP- and still missing the Evo.
I can vouch for the Intake mani look as sexy as it does. I purchased 1 second hand and it was identical to that. Great work!
__________________
Quote:
Originally Posted by moreryce
My car owes me money...
Quote:
Originally Posted by vboy425
Understeer is when you hit the wall with the front of the car and oversteer is when you hit the wall with the rear of the car. Horsepower is how fast you hit the wall, torque is how far you take the wall with you.
Quote:
Originally Posted by monsta
...If youve got a turbo that sucks children off the sidewalk when you drive past- get a vendor CDI COP
Quote:
Originally Posted by meckert
Hmmmm...Kind of Like the old Audis..that use to accelerate into walls when in park..
Offline
Dec 5, 2008, 03:40 PM
Personal Sales Rating: ( 2)
Drives: my wife nuts and my son to the track.
David, I take offense to your 600 whp cars. How about us 700+ whp cars that run the same 65mm TB?
__________________
FP-BLACK 9.53@148.43 & 149.58 MPH
Worlds FASTEST FP-RED Turbo 9.57 & 145.16
Worlds FASTEST OLD FP-GREEN Turbo 133.70 mph
Thanks to our Sponsors
FORCED PERFORMANCE
WILSON MANIFOLDS
SWIFT SPRINGS, USA
IMPACT RACE PRODUCTS
SPARKTECH IGNITIONS
MAPerformance
Offline
Dec 5, 2008, 05:42 PM
Gold Sponsor
Yes, Tom there are a few of those too  I was trying to keep the intakes/tb's together and wasn't including those of us using the Wilson Manifolds.
__________________
David Buschur
STOCK ECU's:
Offline
Dec 5, 2008, 05:48 PM
Personal Sales Rating: ( 136)
Drives: 2005 Evo RS.. 1st Street Evo in the 8's!!
I made 712whp on the Buschur Manifold and TB.. so yes i feel forgotten as well.. LOL
These 2 parts are some of the best bang for the buck mods for the EVO.. We installed 1 set today on a customer car that we will be dynoing on E-85 soon.. I expect 500whp no problem..
Mike
__________________
The #1 Buschur Racing Dealer in the US
Tel. 954-753-6006
AIM= mikeatawd
www.AwdMotorsports.com
- 2003 Black Evo GSR - 8.75@163mph (US Quickest 4g63 Evo )
- World's Quickest Evo 8 Street Car - 8.98@156mph
- World's Quickest / Fastest Stock Turbo Evo - 10.21@133mph ( Most-Wanted )
- World's Quickest Mivec Evo 9.05@157mph( Most-Wanted )
- Florida's Quickest Evo IX Street Car - 9.75@143mph ( Shaun's )
Offline
Dec 5, 2008, 06:33 PM
Personal Sales Rating: ( 26)
Drives: 03 TB VIII
Do you recommened to customers the use of an IM Spacer gasket to go between the IM and Head such as Hondata makes??
I'll be sending mine in soon for treatment
__________________
4WS TUNING + ETS GOODIES = 1 FAST 100K MILE EVO
Quote:
Originally Posted by Evoryder
Its' the turbo punching out for the day
Offline
Dec 5, 2008, 07:37 PM
Personal Sales Rating: ( 7)
Drives: 2006 IX
I love my BR intake manifold/throttle body combo!
Installation only took my about 2 hours start to finish.
__________________
2006 Evolution IX - 10.14 @ 136.75 mph -
(FP-Black / BR2.0 / AEM EMS / E85)
550 whp / 529 ft/lbs
Buschur Racing / Bushwacker Transmissions / Forced Performance
Online
Dec 5, 2008, 07:45 PM
Personal Sales Rating: ( 9)
Drives: 06 9 GSR
super bad intake mani and TB i love mine, i only had it a few hours but i love it already. props david as always
__________________
FASTCHEAPRELIABLE you can only have 2 of the 3
FORMER US ARMY SOLDIER CURRENT ARMY RESERVIST
3/03-3/04- OIF1...11/04-11/05-OIF3... 4/07-8/08-OIF5
SUPPORT THE TROOPS,EVEN IF U DONT SUPPORT THE WAR!
WWW.AWDMOTORSPORTS.COM
514whp 500wtq stock block, stock head, stock frame turbo, E85
Offline
Dec 5, 2008, 07:53 PM
Personal Sales Rating: ( 6)
Drives: 05 Evo8 SSL
I got mine last winter with some xmas money. I was planning on waiting until spring to install it, but I was so excited, I tore right into the car and put the two in!
Feb in MN it's -10' F or so and I had a teensy arse heater in my garage (I have since rectified this!). It took 3-4 hours to get the old one off, and about the same to put the new one in.
It's awesome getting a nice fresh clean manifold and TB in your car. It really freshens up the engine bay!
Lastly, I would never have done this if it wasn't for the testing Dave has done with it. Others offer similar services but few prove the power gains from THEIR work. Definitely a good mod to do for any car!
Online
Dec 5, 2008, 09:02 PM
Personal Sales Rating: ( 3)
Drives: VERY FAST EVO 8
Im Sending My Mine Real Soon
Offline
Dec 5, 2008, 09:20 PM
Personal Sales Rating: ( 1)
Drives: evo 8
3-4 hour to remove the intake manifold? common,is not that hard.you are really slow.i remove the head and pistons in less than that time.
__________________
628hp @35psi,Precision GT35R,AEM EMS built & tuned by Mandy
Offline
Dec 5, 2008, 09:53 PM
Personal Sales Rating: ( 65)
Drives: TURBO cars only !!!!!
It was a no brainer for my build! Awesome combo!
__________________
Oz
2003 Tarmac Black Evo 8 (A.K.A Mr. Clean)
My Evo
Powered by Buschur Racing!
Reese Tuning- FP BLACK on the way!
ROBISPEC ///
"The boost-induced adrenaline rush that is an aggressively tuned TURBO
car pulling at the reigns in anger is profoundly tempting. Evan Griffey TM"
Offline
Dec 5, 2008, 10:06 PM
Personal Sales Rating: ( 37)
Drives: a ~500 AWHP 05 LY EVO 8 like a grandma
For some reason, I was under the impression that the BR T-bodies didn't receive new throttle body shaft seals, as when I did a boost leak test I sensed some leakage coming from the T-body.
I sent the t-body out to have the upgraded milspec shaft seals put in, have the TPS set, and have the t-body reassembled.
Additionally, I had to port match the opening on the intake manifold a bit more to take full advantage of the 65mm T-body opening. It just simply too me about 1/2 hour of dremel work to grind the opening wider...
After all this I managed to make some nice gains on the dyno as can be seen in my signature.
Offline
Dec 5, 2008, 10:17 PM
2003 Mitsubishi Lancer Evolution
Drives: an 03 Hennessy Evo... McTuned.
Quote:
Since when does it get to -10F in Puerto Rico???  Your fingers go numb working in a cold garage in winter here in the north, so to simulate the effect in your tropical paradise, try doing your head and piston work using only your elbows and see what your time is.
__________________
EJ - SM AX'er and HPDE enthusiast
My sites:
www.EJEvo.com
ABsolute Puppies Racing
In a perfect world, everyone with a hot girl avatar would have to have a link to the full size pic.
Offline
Tags
body, br, evo, forum, fp, intake, manifold, pic, pictures, ppi, red, replaces, results, seal, throttle, throttlebody, turbo, whistle  |
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
HTML code is Off
