heres the situation:
I put on a 3 inch downpipe and also a 3 inch test pipe with a QTP cutout welded in. Also with the install i used a mechanical CEL fix for the rear o2 sensor...
well right after the install my CEL wasn't on....
after about 5 days the CEL came on....
codes were: P0136 Oxygen Sensor Circuit Malfunction (Bank 1 Sensor 2) and P0139 Oxygen Sensor Circuit Slow Response (Bank 1 Sensor 2)
So i installed Scan Tech Tool so i can read my CEl's and clear them on my own and i cleared these codes pry 2 times bc the CEL is annoying...
And it was really cold and rainy out one day and i started my car and no CEL? i was confused it just went off on its own...
then about 2 days later it came back on and this time i got the P0138 code for high voltage...
I tried clearing this code but it comes back as soon as you start the car the next time...
So the other day i got under my car to look and see if the wires were exposed or anything...
The wires were fine but the sensor was rubbing against my frame so i didn't know if that was shorting it out or what? so i wraped the sensor heavily in electrical tape and restarted my battery and there was no cel....
but the next time i started my car it was on...of couse
but then the next morning i get in my car and was driving around then i realized the CEL was off! whoa i thought i fixed it and it has stayed off for 5 days until today and its back on!
i have no clue what the deal is but it works some days and the others it don't
im really confused!!!
so what are my options? is there some kind of patch i could put on my ecu so it never reads from the rear o2 sensor bc all the rear sensor is there for is to let you know if your cat is working properly....obviously the mechanical fix isn't working that well....maybe a o2 simulator?
give me your opinions and suggestions! CEL is really annoying
