One for the turbo tech's which turbo's for compound please.
Old Jun 28, 2010, 12:38 PM
J7OKR's Avatar
Hello everyone, I've just registered...well last night but waited for activation.
I have a vauxhall Astra mk2 gte with c20let conversion. Which I am re-mounting into the rear end thus being mid-engined, RWD once completed.
I've been looking into compound turbo set-ups, And as I know most standard replacement TD turbo's are cheap as chips.
My question is.....I want to know if anyone here knows which 2 turbo's would suite for the job. Alot of people have gone for the twin-scroll TD05 16g for the c20let set-ups, But as I want to go compound set up, Can anyone tell me which 2 turbo's would be suited well?
I've looked at the turbo specs on another thread on here, For example if nobody is sure what i mean how would these 2 turbos go together?
(Small turbo) TDO4-9B-6CM2 265 CFM
(Big Turbo) TDO6H-20G-14CM2 650 CFM
Anymore info would be most appreciated.
Joker
Old Jun 29, 2010, 11:02 AM
icantdrive75's Avatar
The only reason I know of for doing a compound setup is to achieve incredible pressure levels out of small turbos. For example, those two turbos you just listed would be capable of well over 50 lbs of boost. I know nothing of the motor you have in there, but you'll need a very strong bottom end, and a very good intercooler. How much power are you trying to make? Give me some more info on the engine.
Why did you post this in a mitsu forum?
Old Jun 29, 2010, 01:26 PM
J7OKR's Avatar
well for starters, I am only trying to acheive a good stable bhp figure nothing over 400bhp. Compound turbo set ups are used to achieive big pressure yes, But that isn't what I'm after I want a strong wide power range with out lag, i.e small turbo boosts early then big turbo takes over. Both turbo's would run at mid-range but have more power with out the hard use of either resulting in reliablity and it will last, and be very smooth.
I am using a c20let, which is out of the calibra turbo's. I am posting on a mitsu forum because people use the td range of turbo's for the c20let engine as replacement turbos from the kkk16 which are getting rare, my question is which 2 turbos would be best suited from the td range.
I'm looking for a small turbo and a big one for maximum range of torque power (wider band of power, smoother, reducing lag)
I thought being a mitsu forum, someone with good knowledge of these turbo's could point me in the right direction as to which turbos would go well together.
Joker
boomtown
83
Feb 2, 2022 03:58 PM
MDJammin
Dec 14, 2014 08:20 PM
MR.Maxwell
Jun 28, 2013 08:41 PM
twista
10
Oct 25, 2010 06:23 AM
Appauldd
Apr 3, 2010 06:12 AM
Quick Reply: One for the turbo tech's which turbo's for compound please.
