Home Features Community Marketplace Registry Garage Store
Go Back   evolutionm.net > Lancer Evolution 1-9 Forums > Evo Engine / Turbo / Drivetrain
Sign in using an external account
Register Forgot Password?
Register Photos FAQ Members Calendar Search Today's Posts Mark Forums Read Used CarsGarageVendor Directory TSB & Recalls
Search
Sponsored by: World Racing
Welcome to EvolutionM.net!
Welcome to EvolutionM.net.
Thread Tools Search this Thread
Old Oct 16, 2008, 11:55 AM   #1
Personal Sales Rating: (0)
Garage is empty, add now
Drives: Evo IX RS
Pistons rings clearance
Hello,
What piston rings to the cylinder wall gap/clearance do you have when you built your motor with forged pistons?
0.50?
0.40?
0.30?
etc etc
I am trying to built my EVO 9 motor and I need to know this information.
Will a big gap like 0.40 leave oil pass through the ring to the chamber?
Does you motor burn any amount of oil?
Which ring is for oil control top or the second ring?
Cause Total Seal told me that " top ring gap has nothing to do with oil control. It is the 2nd ring and oil rings job to control oil. Top ring is a compression seal."
Offline
Old Oct 16, 2008, 12:40 PM   #2
Personal Sales Rating: (5)
2005 Mitsubishi Lancer Evolution
EVO8_PR's Avatar
Drives: 2005 Electric Blue EVO 8, 2005 Honda Odyssey, 2012 Toyota Prius C
Quote:
Originally Posted by konstantinosIX View Post
Hello,
0.50?
0.40?
0.30?
etc etc
Just to correct your question, those measurements should be 0.0xx"
__________________
PT6262 equipped Electric Blue EvoVIII
OEM Yokohama's 10.84@135
M/T Motorcycle Slicks 10.24@136
VR4 Tuning Videos
Quote:
Originally Posted by EVOgasmIX View Post
Maybe the 4G63 was over built by accident and not on purpose. Seriously, why would anyone design a 2.0 L block that could handle 900+ hp 25 years ago?
Offline
Old Oct 16, 2008, 12:50 PM   #3
Drives: Evo IX RS
I think that the numbers Cosworth and Total Seal said to me are on mm
Offline
Old Oct 16, 2008, 12:56 PM   #4
Personal Sales Rating: (1)
Planglie's Avatar
Drives: 2006 TB IX SE, 1970 Camaro drag car, 2001 Ford Super Duty tow vehicle
Are you asking about piston to cylinder wall clearance or ring end gap clearance? Two totally different things.
Piston to wall is set by the machine shop that is boring/honing the block and the piston manufacturers recommended clearance.
Your piston rings may be a "file to fit" set in which case you need to follow the manufacturers suggestions (or a trustworthy engine shop) and using a ring grinder you would need to set the compression ring (top) and the 2nd ring gaps by fitting them squarely into the bore and measuring the gap w/a feeler gauge.
A time consuming but extremely important part of setting up an engine.
Paul
Offline
Old Oct 16, 2008, 01:03 PM   #5
Drives: Evo IX RS
I am asking about the piston ring end gap.
Does anyone knows about the gap of his built engine?
Hope some vendors/engine builders answer us.
Offline
Old Oct 16, 2008, 01:06 PM   #6
EVO8_PR's Avatar
I can't recall exactly but my engine had somewhere in the 0.016"-0.019" gap
__________________
VR4 Tuning Videos
Offline
Old Oct 16, 2008, 01:11 PM   #7
Drives: Evo IX RS
Quote:
Does your engine burning oil or not?
I think that is .40 to .48 cosworth/TotalSeal numbers.
Offline
Old Oct 16, 2008, 01:27 PM   #8
Personal Sales Rating: (8)
03whitegsr's Avatar
Drives: EVO 8
Common units would be good in this thread, I beleive you are talking metric/SI units where the rest here are thinking imperial.
0.3mm = 0.0118"
0.4mm = 0.0157"
0.5mm = 0.0197"
Different builders have different opinions on what is a good ring gap. Two things are for sure.
1. You want a little more gap on the second ring then the top ring to prevent ring flutter.
2. You want to make sure you run enough end gap to prevent the ends from touching under high temps. The gap closes and lots of bad things happen.
Offline
Old Oct 16, 2008, 01:30 PM   #9
EVO8_PR's Avatar
no problem whatsoever.
__________________
VR4 Tuning Videos
Offline
Old Oct 16, 2008, 02:21 PM   #10
Drives: Evo IX RS
Any pro EVO engine builders ref?
Offline
Old Oct 16, 2008, 03:49 PM   #11
Personal Sales Rating: (116)
94AWDcoupe's Avatar
I have built many 4g63 engines over the years with forged pistons. You have to remember the piston ring expands quite a bit. The gap gets much smaller when the ring is at operating temp. You also have to keep in mind that the ring seal is accomplished by pressure behind the ring that pushes it up against the cylinder wall. The pressure comes from cylinder compression that passes through the gap to behind the ring. Running tight gaps is asking for trouble. There will not be enough gap left to sufficiently pressurize the backside of ring. This is what leads to ring blow by. Most people who run tight gaps have ring seal problems. Loose gaps make for good ring seal. I recommend top ring at .020-.024 and second ring at .024-.028. I have run .028 top/.030 sec with good results. I have seen blow by issues with gaps of .016 and under. Hope that helps.
__________________
early evo nut
evo 1 and evo 4
http://forums.evolutionm.net/evo-sho...int-tweak.html
Offline
Old Oct 16, 2008, 08:23 PM   #12
Drives: Evo IX RS
Does anyone else has different opinion???
Offline
Old Oct 16, 2008, 08:35 PM   #13
Personal Sales Rating: (7)
Drives: 2006 Mitsubishi EVO IX
Who's pistons and rings are you using? What material is the top/second rings?
The top ring end gap is generally around .020" (.50mm), but may be different depending on your application. The second ring is generally a little larger. What are you doing with this engine? Drag only? Road race? How much boost? Since your ring end gap is directly related to heat, this informaton helps decide what will work best.
Offline
Old Oct 16, 2008, 11:26 PM   #14
Drives: Evo IX RS
Quote:
Cosworth Information and reference said the opposite.
Top Piston Ring gap 0.40-0.46
Sec Piston Ring gap 0.36-0.41
Oil Piston Ring gap 0.20-0.70
Bad things like....
Offline
Old Oct 16, 2008, 11:33 PM   #15
Drives: Evo IX RS
I use cosworth piston and rings.
The gap that leaves the second as I told before is 0.36-0.41.
The gap of the secong ring is smaller that the top ring end gap 0.40-0.46
My mechanic told me that we have to fit a new top ring to make the top's ring end gap 0.30mm-0.35mm
Offline
EvolutionM
Mitsubishi Lancer
Paid Advertisement
Tags
03, 030, 4g63, end, evo, gap, gt, machine, mustang, oil, piston, ring, rings, rs, total
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
Powered by vBulletin® Version 3.8.7
Copyright ©2000 - 2014, Jelsoft Enterprises Ltd.
Content Relevant URLs by vBSEO 3.5.2
All Passwords
