Hi, guys. Your help needed. EVO8 390 whp burned 2 coils
I have installed DLI2 with NGK BPR9ES with 0.023 gap. Ecuflashed.
After 2 days running, parked the car and started it after 6 hours.
It worked fine only 5 sec, then missfires occured.
5 min took for parking. Saw that right coil burnt and flowed.
I took out DLI2, changed spark plugs for stock, BPR8ES, coils, burnt new coil again (right one) second time. Gasoline on sparkplugs from 1st and 4th cyl.
I have not change stock long wire between coil and spark.
Any advice would be appreciated
hmmm..had this problem a few years back when I had a greddy E-manage installed...burned a few coils well
after about 4 pairs of coils I found out that the Emanage could've been causing it....
took it out and that's it..no more burnt coils.
I was thinking it would've been the DLI but if you said you took it out then I'm not sure
Could the burned coil destroy spark or other way round?
Guys, what do you think about different resistance values on left and right coil connectors? Left = 1.395 kOhm; right = 0.665-0.679 kOhm. What should I repaire in ECU?
http://www.photofile.ru/users/nk198/3641915/80964727
http://www.photofile.ru/users/nk198/3641915/80964730
http://www.photofile.ru/users/nk198/3641915/80964733
http://www.photofile.ru/users/nk198/3641915/80964737
i run my plugs lower than .023.
Your DLI very well could have fried both coil packs. Or you got a bad one.
When smokedmustang's DLI fried his coil packs the DLI also went bad. We tried it on my car and it made my car miss. Removing just the DLI fixed it. I wouldn't use the DLI thats for sure.
1 Post
Cyl #1 and #4 run off of the same coil pack ( waste spark ignition).
If the transistor receives voltage from ecu for too long it burns up. Unless you have two bad coils in a row, I believe you need an ecu.
