Oct 1, 2008, 10:33 AM
Personal Sales Rating: ( 0)
Drives: '05 VIII
Engine Oil Analysis
Gurus,
This is my first experience with used oil analysis. Please let me know what you guys think about this report.
A little extra info on my Evo: I have cams, exhaust, and run higher boost (24 psi) as part of the custom tune (dyno'd about 75 extra hp over stock) I had done using a SMART EXEDE. I have been using TORCO race fuel additive recently.
My main concern is the high lead in this first sample (33). My mileage on the oil is ~3400 and 6 months and I have ~37,000 miles on the car.
BLACKSTONE LABS COMMENTS:
Lead was well above average in the first sample from your Mitsubishi. This shows excess wear at the bearings. Fuel dilution was found at 1.3% but this isn't a problem level and normally wouldn't cause any excess wear. No other harmful contaminants were found. If you do any racing that may explain the high lead. The TBN is plenty strong at 6.6 so this oil has lots of life (active additive) left in it. 1.0 is low. Universal averages are based on an oil run of 3,500 miles. Suggest leaving this oil in use and check back in 2,000-3,000 miles for another look.
Elements detected(ppm):
Aluminum 3
Iron 6
Copper 3
Lead 33
Tin 1
Molybdenum 90
Manganese 138
Potassium 2
Boron 51
Silicon 4
Sodium 8
Calcium 2309
Magnesium 13
Phosphorus 669
Zinc 802
Properties:
SUS Visc @ 210 C = 55.3
cSt Visc @ 100 C = 8.86
Flashpoint = 340 F
Fuel % 1.3
Antifreeze % and Water % = 0.0
Insolubles % 0.3
TBN 6.6
http://www.bobistheoilguy.com/forums...247395&fpart=1
What do yall think about the oil guys comments about lugging around town and needing a heavier weight oil?
Thanks!
Adam
Offline
Oct 1, 2008, 10:53 AM
Personal Sales Rating: ( 4)
Drives: Evo IX
what brand and weight of oil?
Offline
Oct 1, 2008, 11:42 AM
Personal Sales Rating: ( 26)
Drives: '08 GG X & '05 Civic R.I.P '05 WW Evo 8
The BITOG link says the oil is 5w30 M1. Why are you using 5w30? Does the Torco additive contain lead?
__________________
"This won't increase my ability to mate?!?"
Offline
Oct 1, 2008, 04:41 PM
Drives: '05 VIII
Mobil 1 5W-30 is what the manual recommends I believe... I believe Torco says their product does NOT contain lead, but I'll double check.
Has anyone run a 0W40 or 5W40 on their EVO? Comments, suggestions?
Offline
Oct 1, 2008, 05:10 PM
Personal Sales Rating: ( 2)
Drives: '06 WW IX MR
10w-30 is what the manual recommends, unless it's different on the VIII.
-Jalal
__________________
TeamXXXRacing|Northeast Motorsports Club|Online Store
TriStateEvo|http://forums.tristateevo.com/index.php
XBOX Live Gamer Tag: MJ23FE
THE WANT LIST
POWER
Full Re-Tune
BRAKES
SmikeEvo Pad Combo
Performance Friction 2-piece Front Rotors
SUSPENSION/CHASSIS
Whiteline Sway Bar Set - 26mm Fixed Front/24mm Adjustable Rear
Perrin Stout Mounts
Perrin Positive Steering Response System
Offline
Oct 1, 2008, 05:25 PM
My 8 has 10w30 recommended for it.
__________________
Offline
Oct 1, 2008, 05:43 PM
Personal Sales Rating: ( 128)
Drives: MR
Quote:
+1
Offline
Oct 1, 2008, 05:54 PM
Personal Sales Rating: ( 40)
Drives: '05 apex silver evo 8
I use M1 10w30 but will be switching to M1 15w50 for my own personal reasons.
__________________
Ported IX Turbo/Buddy Club 272/280/Magnus Street SMIM/Muse exhaust manifold/ETS Short Route UICP/LICP/4" MAFless intake/ETS 3.5" Exhaust/ETS 3" widetank fmic/Walbro 255/ACT HD/GM 3 port BCS/Speed Density on stock ECU
MidgetSpec&English Racing
ETS
EDRCrew
Offline
Oct 1, 2008, 06:17 PM
Silver Sponsor
Personal Sales Rating: ( 74)
Drives: Evo MR
That 33ppm seems high for the lead content.
I was at 2ppm, then it went up to 6ppm on the 3rd analysis and on the 4th it "skyrocketed" to 15ppm in lead. THe last 2 were 14ppm and 13ppm, so it's been going down slightly.
__________________
GO HERE TO SEND US A TB: http://forums.evolutionm.net/showpos...&postcount=158
GET 100 cell race cats: http://forums.evolutionm.net/evo-sal...available.html
GET MIL.SPEC TB'S HERE:
AMS CHICAGO, IL
CBRD YORK, PA
ENGLISH RACING CAMAS, WA
GST HAYWARD, CA
MAP PLYMOUTH, MN
MFQ BURBANK, CA
SPEED ELEMENT FREMONT, CA
REESE TUNING SANTEE, CA
TTP ORLANDO, FL
TUNING TECH COLTON, CA
Offline
Oct 1, 2008, 06:24 PM
Personal Sales Rating: ( 1)
Why are you not changing your oil every 3 months or 3000 miles? It's really cheap insurance for your engine.
The main reason to change the oil is to get rid of all the contaminates (fuel that is leaked passed the rings and so on) and also the byproduct of combustion.
Offline
Oct 1, 2008, 08:33 PM
Drives: EVO1
try a better oil like a HDEO, Delvac 5w 40
__________________
built 2L - GSCS2 - Hypertune intake - GT3582.....
490whp pump gas 27psi dynamics 1.0CF
Offline
Oct 8, 2008, 04:17 PM
2005 Mitsubishi Lancer Evolution
Drives: 05 EVO VIII
The flash point on your oil appears to be low also... At least low in comparision to my past 5 analysises... Although that might be in direct relation to the percentage of fuel in your oil... I have yet to get anything but a <.5% for fuel %. I am averaging 411 degree flashpoint...
__________________
GSC S1//Warblo//5Zigen//Big Sticker//Tune By 20psiMR// 91 & E85 Tune RRE//Buschur FIMC//RC1000 injectors//high flow cat//Toot Toot Mod//dented body panels//Dirt//
Offline
Oct 9, 2008, 08:46 AM
Drives: '05 VIII
What could cause a high % fuel in the oil? Could these be related to extended use time?
Offline
Oct 9, 2008, 09:27 AM
Personal Sales Rating: ( 11)
Drives: AS EVO X MR
Adam, here are the results from my latest oil analysis. For comparison, I have a VIII MR with 53.5k miles on the ticker and 6,500 miles on this oil sample (yes, sixty-five hundred miles on the oil). The lead in this sample spiked from a previous high of 2ppm in the previous sample (w/ 6k miles).
You didn't mention if you had a previous sample, but seeing Pb at 33ppm (as they point out) suggests to me that you have a bearing going bad. (If you have a previous sample, can you post up those results as well?) You really should get it checked out ASAP; if the bearing goes out while you're driving it'll be a very expensive repair.
Quote:
Originally Posted by adam5743
Elements detected(ppm) [My numbers]:
Aluminum 3 [5]
Iron 6 [10]
Copper 3 [4]
Lead 33 [5]
Tin 1 [1]
Molybdenum 90 [80]
Manganese 138 [0]
Potassium 2 [0]
Boron 51 [43]
Silicon 4 [10] - yeah, needed to clean the 'ole K&N
Sodium 8 [6]
Calcium 2309 [2506]
Magnesium 13 [15]
Phosphorus 669 [654]
Zinc 802 [764]
Properties:
SUS Visc @ 210 C = 55.3 [55.4]
cSt Visc @ 100 C = 8.86 [8.90]
Flashpoint = 340 F [395 F]
Fuel % 1.3 [<0.5]
Antifreeze % and Water % = 0.0 [0.0]
Insolubles % 0.3 [0.3]
TBN 6.6
Online
Oct 9, 2008, 10:49 AM
Silver Sponsor
Personal Sales Rating: ( 6)
The most obvious reason is the cliche "safe rich toon" that gets dealt out in lots of cases. I have seen oil inside turbos that is so full of fuel that you smell it as soon as you open up the turbo. Fuel diluted oil is bad, mkay?
Offline
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
HTML code is Off
