Aug 28, 2003, 05:18 PM
Personal Sales Rating: ( 2)
Drives: 2008 Lancer Evolution X - Graphite Grey
cam swap tips
I'm going to be swapping out my stock cams with HKS 264/272 's this weekend with a buddy who has a lot of experience with 1st gen DSM's.
He indicated that I should ask for any tips, tricks, pitfalls to avoid, etc. in terms of swapping out the cams in the Evo VIII engine. I searched the How To section and there was only a link to a walkthough for 1st gen DSM's.
Please, if you have any advice, particularly about removing / reinstalling the front cover, let me know. I'm going to try and get a lot of pics and take notes so I can benefit everyone with a clear walkthrough.
Thanks!
Offline
Aug 28, 2003, 06:25 PM
Personal Sales Rating: ( 6)
Drives: 2003 EVO 11.50 @ 121 - Still #1 in the US!
Basic directions
1 - remove rocker cover
2 - put engine just before TDC
3- ZIP tie belt to pulleys
4 - Apply cam tensioner tool - its a rod you screw in to release the pulley on the belt
5 - change out one can at a time - hanging it on the other wheel to keep it up and the belt on
6 - make sure to put the cam pos trigger back on in the right direction
7 - trq caps to 17 ft lbs
8 - use lock tight on the pulley bolts - 65 ft lbs
9 - relase the tool
10 - spin engine and verify timing is still on
Takes me about 3 hours - good luck
__________________
"Dyno time for baseline and Mod adjustment (who cares what type or what make Dyno you use. Just make it the same Dyno each time)
The fine tuning comes on road (preferably a track) adjustment." user - ishi
Offline
Aug 28, 2003, 08:38 PM
Personal Sales Rating: ( 7)
Drives: '71 Datsun 240, Evo MR
Just what Al said, except I bled my lifters down before installing the cams. Not bleedind down the lifters can cause a very bad idle since the lifters are set for the original cams and would need to readjust themselves to the new cams. Although this practice is done by very few techs, it is what I did with my cams. Oh, another thing is that this job takes me 1 1/2 hours
__________________
Gil-superz
WickedWhite MR- Stock for now.
Offline
Aug 28, 2003, 10:30 PM
haha - I feel a little stupid asking, but I can't resist:
What does bleeding the lifters down mean?
Offline
Aug 28, 2003, 10:46 PM
Silver VendorEvoM Guru
Personal Sales Rating: ( 65)
Drives: Old Man with a 03' EVO VIII, 05' Subaru 2.5GT Limited, 06' Kawa Z1000, 02' Kawa ZR-7s, 07' GSXR 1000 (babysitting lil' brother's ride while he's in the sand box), 00' Integra Type R SOLD
Quote:
interesting...
Offline
Aug 28, 2003, 11:26 PM
you bleed the lifters down by removing them from the head (very easy once the cams are out), inserting a paperclip (or something thin and long) into the center hole on top of the lifter. You will manually squeeze the lifter at the same time you are inserting the paperclip into the hole, you will feel the lifter compress easily when you have opened the internal valve. At that point the lifter will squeeze out some oil and you're done. It actually sounds harder than it is, it only takes 5 to 10 seconds per lifter.
The problem with not doing this is that the lifter for the original cam may not ever bleed down on its own and will not cause any noticable performance loss except at idle. My idle is as good as it gets with cams (272 hks), my vacuum doesnt go below 17" (stock was 21") . Of course you can hear a cam idle but it sure isn't what alot of these guys complained about.
__________________
Gil-superz
Offline
Aug 29, 2003, 07:38 AM
So how many rotations does it take for the lifter to reprime? Sounds like it would allow a lot of extra play for a couple of revolutions which couldn't be good for the surfaces...
Offline
Aug 29, 2003, 09:25 AM
Personal Sales Rating: ( 5)
Drives: EVOLUTION VIII - project car
I know there are two different cam styles that are out, which would you use for the best performance ... What size in the intake what size in the exhaust side...
__________________
Ruben Arcila
Offline
Aug 29, 2003, 10:48 AM
To reprime the lifters you should crank the engine over without starting. You can find the ecu relay and disconnect it. Crank it for a good 15-20 seconds. Like I said before, this is my practice, alot of people can just slap the cams in and it might run perfect (although it may not).
I used 272' HkS on both the intake and exhaust cams. I dont have a problem with idle, no CEL, and my fuel economy on the highway at 70-80mph (at no boost) is 26mpg. Can't complain. Tuning for light throttle-off boost is the key! On the roadcourse I got like 6mpg!!!
__________________
Gil-superz
Offline
Aug 18, 2004, 11:33 AM
Drives: 03 SRT-4(traded in),03 BBY EVO(SOLD), now 94 TT Supra BPU+
I want to know more about this cam bleed technique!
__________________
WhO's SaYiNg HaIm?
Offline
Aug 18, 2004, 12:35 PM
Silver Sponsor
Personal Sales Rating: ( 99)
Drives: Dirty EVO VIII
Get a wobbly 12mm socket for the cam sensor bolt. Other than that, its pretty straight forward. Oh yeah, get a 6 pack of your favorite beer for afterwards!
Offline
Aug 18, 2004, 12:36 PM
haha thanks, but I dont drink. Im sure i could use a few cherry cokes though.
__________________
WhO's SaYiNg HaIm?
Offline
Jun 27, 2009, 03:41 PM
Personal Sales Rating: ( 25)
Drives: tb ix gsr ssl
Quote:
Originally Posted by Alfriedesq
Basic directions
9 - relase the tool
sorry for the newb question but can someone comment on point #2 with regards to the tdc.
Thanks
Offline
Jun 27, 2009, 03:59 PM
Personal Sales Rating: ( 8)
Drives: evo 8
date of thread 2003
Offline
Jun 27, 2009, 04:06 PM
^welcome to the power of search
Offline
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
HTML code is Off
