Go Back   evolutionm.net > Lancer Evolution 1-9 Forums > Evo Engine / Turbo / Drivetrain
Welcome to EvolutionM.net!
Welcome to EvolutionM.net.
Old Jun 27, 2009, 04:13 PM   #16
Personal Sales Rating: (8)
Drives: evo 8
haha tru i usually find stuff in 04 seems to be the most popular
Offline
Old Jun 27, 2009, 04:28 PM   #17
Personal Sales Rating: (2)
bbyevo8u's Avatar
Drives: *9 MR SE* ivey tuned.........sold: k7 gixxer 600, 03 350z stock, 04 evo8 cbe, 05 evo8 cbe, 06 sti cobb stg2 300whp
get cam seals!
__________________
PERRIN TBE W/TEST >< BUSCHUR CONE FILTER >< ETS INTERCOOLER KIT >< HALLMAN PRO MBC >< WALBRO 255 PUMP >< KELFORD 272's >< BEEHIVE SPRINGS >< INVIDIA EXHAUST MANIFOLD >< INVIDIA 02 HOUSING >< HDSS W/ACT STREETLITE FLYWHEEL >< FLUIDAMPR CRANK PULLEY >< ARP HEAD STUDS >< STIFF SHIFTER BUSHINGS >< SS CLUTCH LINE >< DUNLOP TIRES >< AEM WIDEBAND >< AUTOMETER BOOST GAUGE >< KOYO RAD >< KEVLAR BELTS >< ///IVEY TUNED - 350whp 352whq///
Offline
Old Jun 27, 2009, 05:38 PM   #18
Personal Sales Rating: (1)
Drives: 2004 EVO VIII
Any other stuff beside cam seals and silicone?
I think I will reuse the valve cover gasket and grommets. They have only 20K.
__________________
2004 Evo 8; Works TBE; Kamak TD06SL2R 20G; Ebay O2; Kelford 272 with GSC Beehives; Works Drop In Air Filter; Nisei LICP; Perrin FMIC; Evo IX DV; Walbro 255; GM 3 Port BCS; JDM 3 Bar MAP w/ PSI Based Boost Control; Self Tune @ 24 PSI
Offline
Old Jun 27, 2009, 07:17 PM   #19
Personal Sales Rating: (10)
2003 Mitsubishi Lancer Evolution
huevosrancheros's Avatar
Drives: 03 Banana EVO VIII
this is for an evo 8 but maybel it'll give you a clue
http://evomoto.com/tech_info.php?tPa...75fbaffcfc7b78
buy the manufacture's manual.
__________________
You have never lived life, until you have choked someone out!
PS3 ID: Kinikuchunks, Add ME for some Street fighter 4 and Killzone 2 action!
KUNiiiZZZEEE Dial-IN
Offline
Old Jun 27, 2009, 08:53 PM   #20
Personal Sales Rating: (0)
Drives: GG evo 9
I think this is a great video that shows you how to install cams on an evo 8
http://videos.streetfire.net/video/H...-on_138721.htm
Offline
Old Jun 27, 2009, 09:44 PM   #21
Personal Sales Rating: (24)
detroit pistins's Avatar
Drives: tb ix gsr ssl
that;s an amazing vid man. thanks alot.
Online
Old Jun 27, 2009, 10:25 PM   #22
Quote:
Yeah werd, that video is pretty ill. Is there any difference when you install a MIVEC cam on a IX?
Offline
Old Jun 27, 2009, 10:31 PM   #23
^ good question!
Online
Old Jun 27, 2009, 10:37 PM   #24
Drives: Evo IX, 240 SX, Nissan Titan
Quote:
only difference is tat the mivec came has a 14mm allen
Offline
Old Jun 27, 2009, 10:39 PM   #25
Quote:
OH NOOOOOOOOO!!!!!!!!!!!!!!
Good looks lol.
Offline
Old Jun 27, 2009, 10:41 PM   #26
bbyevo8u's Avatar
silicone for what??
i would replace the valve cover gasket!
__________________
Offline
Old Jun 27, 2009, 10:42 PM   #27
Personal Sales Rating: (3)
k20toEVO's Avatar
Drives: EVO VIII
I know this is old thread, but damn 3 hours? i bled my lifters too and it took me 40 mins to swap everything to firing it up.. slow boy just make sure it done right so take ur time ..
Quote:
Originally Posted by Alfriedesq View Post
Basic directions
1 - remove rocker cover
2 - put engine just before TDC
3- ZIP tie belt to pulleys
4 - Apply cam tensioner tool - its a rod you screw in to release the pulley on the belt
5 - change out one can at a time - hanging it on the other wheel to keep it up and the belt on
6 - make sure to put the cam pos trigger back on in the right direction
7 - trq caps to 17 ft lbs
8 - use lock tight on the pulley bolts - 65 ft lbs
9 - relase the tool
10 - spin engine and verify timing is still on
Takes me about 3 hours - good luck
Online
Old Jun 28, 2009, 02:20 AM   #28
Fathouse's Avatar
Drives: WWevo9rs
Send a message via AIM to Fathouse
I put the cams in the oringial posters first evo. Man that was a while ago.
Fathouse
__________________
2006 Evo9 RS
Stock Engine/head/ecu/maf
Magnus v5, Shep racing, QM clutch, FP cams, Fatfab 35r turbo kit, BFF Racing, Snake Tunning, and CORN Fed
Best times to date.
6.757/10.362
108.55/136.94
http://www.youtube.com/watch?v=0qh0DPNNlJw
Offline
Old Jun 29, 2009, 09:14 AM   #29
sk8terdude929's Avatar
Drives: 03 evo
sorry for the newb question but can someone comment on point #2 with regards to the tdc.
Thanks
TDC- means Top dead center, when the piston is at top dead center
Offline
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
