Go Back   evolutionm.net > Lancer Evolution 1-9 Forums > Evo Engine / Turbo / Drivetrain
Welcome to EvolutionM.net!
Welcome to EvolutionM.net.
Old Sep 5, 2008, 08:39 AM   #1
Personal Sales Rating: (17)
deegaw11's Avatar
Drives: 06 TB IX MR
Send a message via AIM to deegaw11
clutch pedal vibrates when not warmed up
my clutch pedal vibrates when it isnt warmed up, i put in an ACT HDss about 1500 miles ago. once i drive the car for a lil while till it warms up then it goes away. is this normal? i dont have any lock out issues.
Offline
Old Sep 5, 2008, 08:43 AM   #2
Personal Sales Rating: (3)
Duh Panda's Avatar
Drives: 2003 Mitsubishi Lancer Evolution
Send a message via AIM to Duh Panda
ACT clutches suck... shouldve gone with at least an Exedy..
throw out bearing? not properly aligned? or maybe your still breaking the clutch in...
__________________
Quote:
Originally Posted by TTP Engineering View Post
A drain plug cannot pop out from boost.
I might change your location from Mechanicsburg, PA to Failburg, PA in your profile.
Offline
Old Sep 5, 2008, 11:48 AM   #3
Personal Sales Rating: (5)
EVIL MR's Avatar
Drives: 2003 GSR,2005 GSR sold... 2005 GALANT GTS, IX GSR.
Mine now does the same thing cold or hot + all the lockout you need. ACT is very ****y clutches for evos.
__________________
TAKE NO B.S. Go to WWW.Jestrtuning.com.................................................. ..................................................Private discounts at Zales Jewelers....
Offline
Old Sep 5, 2008, 11:50 AM   #4
Personal Sales Rating: (12)
EVOIXreno's Avatar
Drives: 2006 EVO IX
Send a message via Yahoo to EVOIXreno
Quote:
that's he truth. Had a street disk from act and went to exedy a couple weeks later!!
__________________
Subaru(STi) is a boys car, Mitsubishi(evo) is a man's car - Jeremy (Top Gear)
Blue EVO IX:
I have done enough that I'm worried of breaking stuff now!
On a nine turbo I made 366/369 on 91/Meth
New #'s on 11/07/2009 hoping for 450whp
Tuned by Me, Mayhem Tuning
Offline
Old Sep 5, 2008, 11:37 PM   #5
Gold Sponsor
Personal Sales Rating: (0)
Sales@ACT's Avatar
Drives: AWD Turbo Cars
Quote:
Since the clutch has no idea whether your car is warmed up or not, the vibration has nothing to do with the clutch.
__________________
Advanced Clutch Technology Inc
www.advancedclutch.com
email:info@advancedclutch.com
Sponsors of the quickest and fastest 4G63's
Brent Rau 2007 NHRA Modified Champion
John Shepherd 7.701 @ 191.32
Offline
Old Sep 5, 2008, 11:43 PM   #6
Personal Sales Rating: (15)
bluebanana23's Avatar
Drives: blue shopping cart
^ I'm no clutch expert or even a novice but we all know metal expands when heated...If it's any constellation, my stock exedy engages a little funny until it warms up. No, it's not slipping.
__________________
Power is useless without control is impossible without grip.
http://img127.imageshack.us/img127/2926/banjv4.png
Offline
Old Sep 5, 2008, 11:58 PM   #7
Gold Sponsor
Sales@ACT's Avatar
Quote:
Yes metal expands when it is heated up, that was never in question here. The OP inferred that after his car (engine) was warm the pedal stopped vibrating. So we are not talking about the same thing here.
His engine may have a vaccum leak that may cause the engine to vibrate on cold start and cause vibration through the clutch pedal but I'm certain it's not directly related to the actual clutch. Possibly the installation.
Both the stock clutch and any of the ones that we manufacture do not require a certain amount of heat to reach optimal clamp load or performance since that is determined by the diaphargm on the pressure plate. Carbon on carbon clutches work that way, and get better as they are heated up. The only time where heat becomes a factor on a organic or puck style clutch is if it is heated past a certain point (either the pressure plate casting or the friction material) where the material warps and the clutch slips.
__________________
Offline
Old Sep 5, 2008, 11:59 PM   #8
Personal Sales Rating: (86)
This is not normal. It is same as having warped brake rotors. Brakes are smooth when cold. Brake pedal "pulses" when rotors are hot. The pulse comes from the rotor wobbling under the brake pads. If a clutch pedal has a vibration or a pulse its because the fingers on the pressure plate are "warped" this causes the throw out bearing to wobble. The problem could be any one of the clutch components. fly, disc, pressure plate, or throw out bearing.
And I disagree with above statement by the act man. no way would a rough idle be felt at clutch pedal. engine moving around does not cause clucth pedal to move around. fluid beling puched backwards causes the pedal to move. and that happens only when the TOB is not spinning true.
__________________
early evo nut rockin
evo1 and evo 4
Online
Old Sep 6, 2008, 12:08 AM   #9
[quote=Sales@ACT;6086104]Yes metal expands when it is heated up, that was never in question here. The OP inferred that after his car (engine) was warm the pedal stopped vibrating. So we are not talking about the same thing here.
Not trying to be a dick but there's ambiguity here and my logic is not exactly flawed. Yes, the OP did state after he drove the car awhile the vibration is gone but you cannot expect him not to use the clutch while driving. So therefore the clutch "warms up" to operating temperature. But, of course, your advice and insight is much more of value since you actually sell the clutch.
__________________
Offline
Old Sep 6, 2008, 12:09 AM   #10
Personal Sales Rating: (4)
razorlab's Avatar
Drives: a laptop connected to your ECU.
Which constellation would that be? Andromeda? Aquarius? Orion?
__________________
Bryan - 05 MR - E85 and FPgreen powered
E85 Army
Offline
Old Sep 6, 2008, 12:11 AM   #11
Personal Sales Rating: (8)
Drives: A die grinder in your hotside.
Lmao!!!
Offline
Old Sep 6, 2008, 12:12 AM   #12
Gold Sponsor
Sales@ACT's Avatar
Quote:
To achieve greater clamp load our pressure plate diaphragm is heat treated in an oven then aneeled and sees greater tempratures than it will ever see bolted to a flywheel. In addition the diaphram fingers do NOT make contact with the friction surface like a brake pad does with a rotor. That is the job of the pressure plate casting.
If the fingers on the diaphram were bent it would stay bent and based on your theory it should cause vibration through the pedal at all times since it is not possible for it to bend and return to it's proper state after cooling. The same goes for the disc and the flywheel. In fact from the OP's statement the problem goes away after the car is warm so it has even less to to with the warped brake rotor rationale.
__________________
Offline
Old Sep 6, 2008, 12:16 AM   #13
lol, I meant consolation. Wow, past my bedtime!
__________________
Offline
Old Sep 6, 2008, 12:19 AM   #14
Gold Sponsor
Sales@ACT's Avatar
Yeah that was pretty funny but I wasn't going to call you on that.
__________________
Offline
Old Sep 6, 2008, 06:49 AM   #15
deegaw11's Avatar
Drives: 06 TB IX MR
im guessing the vibration goes away after the clutch warms up because my car idles smooth as hell so it has nothing to do with the engine i think, also is it normal that sometimes my engagement is smooth as hell with the ACT but sometimes it would chatter extremely bad??
Offline
Tags
brent, clutch, engagement, evo, home, pedal, point, pulses, rau, smooth, state, throw, vibration, vibrations, warms
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
