Aug 14, 2008, 12:01 AM
Personal Sales Rating: ( 48)
2003 Mitsubishi Lancer Evolution
Drives: 03 EVO VIII White
2.3L GT3076Build
Well after having a little oil leak from my head for the past 2 years (ARP head stud install without removing the head - FTL!), I'm pulling the head to fix that and decided why not just redo everything. The car has about 100K miles on it right now as it's been my daily driver with a nearly 100 mile commute. I do strictly road racing type of stuff with my car, no drag racing, so I'm looking for lots of torque, good spool-up and I'm not planning on revving past around 7800 RPM. I've always wanted to do a 2.3L and considered a stock-based turbo like a green, but they are super expensive, hard to get and I'm afraid run out of top end on a stroker. So a GT3076 seemed like a perfect fit. We'll see I guess. I got a great deal on one from somebody here.
So I've been ordering parts for a few months and procrastinating doing any actual work. Well last weekend I finally got started.
Ready to DO WORK, hood off and lots of stuff to unscrew.
White Trash temporary parts storage area. I should water my lawn more!
Pretty much everything disconnected from the engine. Just need to unbolt the AC compressor and power steering pump. Unhook the T-Case and pull that thing out. Should have the motor out this weekend and start stripping it down to go to the machine shop.
I'll be interested to see the inside of the motor after 100K and see the stock clutch as well.
Here's my pile of parts. Whenever I think I'm just about there I realize I still need something. Like the ARP main bolts I remembered I still need to order today  I'm piecing together the turbo kit myself and still need a waste gate, oil lines, and parts to fab an O2 housing. I'm also looking at doing a side-by-side radiator and vertical flow intercooler, all of which I'll fab myself with uber short IC piping.
I think I have enough stickers to cover a butt-rocker nova station wagon with a 454 in it
__________________
jid2 Built: Now featuring E85 super fuel
2.3L - GT3076R .63A/R, ETS equal length, Kelford 272's, BC valve springs, 1mm O/S valves, FIC BM 1450's, Full-Blown dual Walbros, Buschur IC, jid2 intake, airbox, IC pipes, APS BOV, TBE, ACT HDSS, Stock ECU, 28 psi 466hp/420 ft-lb...
Build Thread
Binary Lowered Recaro Seats, Girodisc 2-Piece, brake ducting, ST43's, SS lines and ATE Superblue, KW V3's 8K/10K, jid2 flat-bottom, adjustable splitter and aero, 18x9.5 +40 NT03's 265/18/35 BFG R1's
Offline
Aug 14, 2008, 12:09 AM
Personal Sales Rating: ( 13)
Drives: Evo VIII/SRT/ZX10R
GL with the build man. Compression will be?
__________________
Rice Police.
(VTECLOL)
Offline
Aug 14, 2008, 02:16 AM
Personal Sales Rating: ( 4)
Drives: Evolution IX , Lumina SS coupe 2003
GL my firend, and keep us posted with your build
__________________
Powered By BUSCHUR RACING
Tuned By 4 WHEEL SLIDE
Offline
Aug 14, 2008, 02:24 AM
Personal Sales Rating: ( 52)
Drives: RR IX
so many stickers
__________________
RR EVO IX GSR/SSL-Greddy Ti/Hallman/A Spec/Defi/Walbro/DC/Apexi/Zaklee/Titan Motorsports/ETS/EPM 02/selftuned
UT law start 2011
Go big or go home
Myspace.com/Importxpresions
Jdm Amber tail light vinyl
NTEC
Offline
Aug 14, 2008, 02:27 AM
Personal Sales Rating: ( 16)
Drives: Around Crowds watching street racers
the 30R will run out on top end on the stroker just like the green.
its still a very very sweet setup for daily driving having the tq always there is really a nice feeling, enjoy and good luck.
You can expect 500/500 out of it on race gas and high boost, 400/350 or so on pump gas.
Scorke
__________________
Pressure exploits either the greatest strengths, or the slightest weakness in human or machine; whether that pressure stems from forced atmospheric induction, or is psychological in nature. The result is that human, or machine, becomes legendary either for their increased strength under pressure, or for fracturing as a result of the stress. The most important modification is the driver.
Offline
Aug 14, 2008, 07:15 AM
Personal Sales Rating: ( 25)
Drives: 2003 EVO-2002 WRX-2003 R6 (sold) :(
you have virtually the same set up as me, down to the turbo kit
__________________
Rally Red Evolution 8
Offline
Aug 14, 2008, 07:26 AM
Personal Sales Rating: ( 23)
Drives: Lots o' cars
Good luck and keep us posted!
Online
Aug 14, 2008, 07:30 AM
Personal Sales Rating: ( 1)
Drives: 2006 Evo IX MR
If you got the Eagle stroker kit that came with clevite main bearings, make sure they are the correct bearings. Eagle sent me 1g main bearings instead of Evo bearings. When I called and asked them to send me the correct bearings, they said that they didn't have any and didn't realize there was a difference between the 2. I ended up having to get cosworth bearings instead. Good luck!
Offline
Aug 14, 2008, 08:36 AM
Personal Sales Rating: ( 21)
Drives: Louts Exige (547rwhp shell 93oct) & 87 coupe
Looks like a great build. I like your work very simple and right to the point.
Offline
Aug 14, 2008, 08:37 AM
Personal Sales Rating: ( 12)
Drives: 03 Evo
What manifold is that? I take it you are removing the balance shafts?
__________________
Uuri
Offline
Aug 14, 2008, 08:38 AM
Quote:
Yeah I saw some posts you made a while back and said to myself "we are doing about the same build". The best part is the picture for your avatar.... I have the same one, I took this about 2 months ago when the turbo and pistons showed up UPS at work!
How far along are you? Are you done?
__________________
Build Thread
Offline
Aug 14, 2008, 08:41 AM
Personal Sales Rating: ( 24)
Drives: the Stig to school..
Looks like fun
GL with the build and keep us updated with pictures!!!
Offline
Aug 14, 2008, 09:05 AM
Quote:
I pieced everything together myself, I ordered everything as 7-bolt EVO specific but I haven't even got around to test fitting the bearings on the rods and crank yet. Bearings are ACL.
Compression is standard 9:1.
Manifold is a RNR ramhorn that I scored on e-bizzle for $200.
I'm going to remove the stubby balance shaft and I'm going to turn down the large one for clearance on a lathe. I'll basically be doing what AMS sells as their race motor balance shaft, or what JAM does in their strokers. I actually asked JAM to sell me their stroker specific balance shafts because I feel they are the correct solution, but they wouldn't. Maybe I'll offer them myself once I finish mine!
__________________
Build Thread
Offline
Aug 14, 2008, 09:09 AM
im very very close, im actually done with the breakin and it should be tuned next week
im gonna make a post about my build after its done
__________________
Offline
Aug 14, 2008, 09:15 AM
Drives: 2005 GTO 525RWHP- and still missing the Evo.
I LOVE my setup. I am running a similar setup like yours and Scorke's. A lil other mod's in addition to. Im hoping on race (or meth) to break the 500/500 mark. Are you building the head too?
__________________
Quote:
Originally Posted by moreryce
My car owes me money...
Quote:
Originally Posted by vboy425
Understeer is when you hit the wall with the front of the car and oversteer is when you hit the wall with the rear of the car. Horsepower is how fast you hit the wall, torque is how far you take the wall with you.
Quote:
Originally Posted by monsta
...If youve got a turbo that sucks children off the sidewalk when you drive past- get a vendor CDI COP
Quote:
Originally Posted by meckert
Hmmmm...Kind of Like the old Audis..that use to accelerate into walls when in park..
Offline
Tags
23, 68mm, binary, body, build, buschur, dyno, evo, evo9mr, intake, magnus, manifold, oil, rebildingengine, squirters, throttle  |
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
HTML code is Off
