Sep 5, 2008, 09:06 AM
#61
Personal Sales Rating: ( 3)
Drives: 2003 Mitsubishi Lancer Evolution
THAT ACT clutch isnt going to be able to hang with you bro  sorrry to say
sell it and put it in towards a twin disk
__________________
Quote:
Originally Posted by TTP Engineering
A drain plug cannot pop out from boost.
I might change your location from Mechanicsburg, PA to Failburg, PA in your profile.
Offline
Sep 5, 2008, 09:28 AM
#62
Personal Sales Rating: ( 48)
Drives: 03 EVO VIII White
The clutch is rated for about 570 ft-lbs of torque. As great as it would be to make that much torque I don't think it will be happening. As you can see by the pictures of my stock clutch with 100K miles on it I'm not hard on clutches.
__________________
jid2 Built: Now featuring E85 super fuel
2.3L - GT3076R .63A/R, ETS equal length, Kelford 272's, BC valve springs, 1mm O/S valves, FIC BM 1450's, Full-Blown dual Walbros, Buschur IC, jid2 intake, airbox, IC pipes, APS BOV, TBE, ACT HDSS, Stock ECU, 28 psi 466hp/420 ft-lb...
Build Thread
Binary Lowered Recaro Seats, Girodisc 2-Piece, brake ducting, ST43's, SS lines and ATE Superblue, KW V3's 8K/10K, jid2 flat-bottom, adjustable splitter and aero, 18x9.5 +40 NT03's 265/18/35 BFG R1's
Offline
Sep 5, 2008, 09:36 AM
#63
Personal Sales Rating: ( 25)
Drives: 2005 GTO 525RWHP- and still missing the Evo.
I would do the twin. Several people went ahead and went from the single to the twin when they went with a 2.3l
__________________
Quote:
Originally Posted by moreryce
My car owes me money...
Quote:
Originally Posted by vboy425
Understeer is when you hit the wall with the front of the car and oversteer is when you hit the wall with the rear of the car. Horsepower is how fast you hit the wall, torque is how far you take the wall with you.
Quote:
Originally Posted by monsta
...If youve got a turbo that sucks children off the sidewalk when you drive past- get a vendor CDI COP
Quote:
Originally Posted by meckert
Hmmmm...Kind of Like the old Audis..that use to accelerate into walls when in park..
Offline
Sep 5, 2008, 09:38 AM
#64
Personal Sales Rating: ( 16)
Drives: Around Crowds watching street racers
Quote:
Oh yeah ?
Binary, listen to this man, the 30R on race gas will make close to 500ft lbs of tq, it will murder the HDSS I assure you.
Scorke
__________________
Pressure exploits either the greatest strengths, or the slightest weakness in human or machine; whether that pressure stems from forced atmospheric induction, or is psychological in nature. The result is that human, or machine, becomes legendary either for their increased strength under pressure, or for fracturing as a result of the stress. The most important modification is the driver.
Offline
Sep 5, 2008, 09:53 AM
#65
It's a XTSS, but I could swap out the street disk for the 6 puck race disk which is good for 726 ft-lbs.
I really don't like twin disks. I had lots of friends with them when I was in Utah and they always had problems with them.
Thanks for the input, I like to hear what you guys think. I'll make a few calls and see what my options are.
__________________
Build Thread
Offline
Sep 5, 2008, 10:26 AM
#66
Personal Sales Rating: ( 40)
Drives: '05 apex silver evo 8
I have the ACTHD w/ sprung 6 puck, I would def recommend getting it over the SS disk. I have had friends who have had it and while its a better driving disk I dont think it will last long even w/ your setup. The HD w/ sprung 6 puck isnt a very friendly clutch though.
__________________
Ported IX Turbo/Buddy Club 272/280/Magnus Street SMIM/Muse exhaust manifold/ETS Short Route UICP/LICP/4" MAFless intake/ETS 3.5" Exhaust/ETS 3" widetank fmic/Walbro 255/ACT HD/GM 3 port BCS/Speed Density on stock ECU
MidgetSpec&English Racing
ETS
EDRCrew
Offline
Sep 5, 2008, 11:54 PM
#67
Personal Sales Rating: ( 5)
Drives: His Hot Wife Insane!!!
^i got the same clutch as you do and you are right.........its not a friendly clutch.
Offline
Sep 6, 2008, 01:26 AM
#68
^  True dat! It holds everything you throw at it though, thats for sure.
__________________
ETS
EDRCrew
Offline
Sep 6, 2008, 11:10 AM
#69
__________________
Build Thread
Offline
Sep 6, 2008, 12:02 PM
#70
itll hold but for about a month or two... lol
bite the bullet and invest in a twin disk... why would you put that much money into the motor and cheap out on the transmission?...
__________________
Offline
Sep 7, 2008, 10:00 AM
#71
Quote:
yup pretty much....i have friends with evos who has the same clutch who put down over 420wtq and no problems with this clutch.
Offline
Sep 7, 2008, 12:16 PM
#72
Down to the block now and ready to hand it over to the machine shop on Monday. Here the mess off final parts tossed about the garage.
Looking at the stock bearings I found something a little scary. This is the main closest to the flywheel. Not sweet.
__________________
Build Thread
Offline
Sep 7, 2008, 01:09 PM
#73
Drives: women crazy
Yeesh. Do any of the other bearings look that bad?
Offline
Sep 9, 2008, 09:44 AM
#74
The other bearings are fine.
So I dropped a bunch of stuff off at the machine shop. I'm using a local shop that did the machine work on Cascade Autosports EVO rally car motors. They're not a cheap machine shop, and they want to build everything like a full-blown race motor - but I'm not made of money. They want to inspect everything, re-size everything, polish everything, and assemble everything - and charge for everything. I had to literally grab the work order and start crossing things off because I seriously couldn't afford it all. I wanted them to do "machine work", I'd check everything during assembly and if I found problems I could bring them in for fixing. But they keep saying "we should check that up front- we do better work than your able to do etc."
Anyway the guy at the desk was trying to up-sell me to death and I felt like I was getting hosed. I had to call back later after I had originally left and talk to the actual owner/machinist to be clear on what we were doing and what the cost was.
After going through all this I can say there is comfort to be had from simply buying a built short block from a good shop like Buschur, AMS, or JAM. I am still stressed over this and wondering if I'll regret skipping some of the 10 billion steps the machine shop wanted to go through. But in the end I'll be into the stroker shortblock about $2200, where buying one costs $3500.
The reason I didn't buy a built shortblock was because I've always wanted to build an engine. This will be my first, and as nerve racking as it is you don't get experience until you do it. So well see how things go.
__________________
Build Thread
Offline
Sep 9, 2008, 11:23 AM
#75
$1300 is still $1300  Experience is everything. I would love to build mine, but prob wont for my first motor.
__________________
ETS
EDRCrew
Offline
Tags
23, 68mm, binary, body, build, buschur, dyno, evo, evo9mr, intake, magnus, manifold, oil, rebildingengine, squirters, throttle  |
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
HTML code is Off
