Jun 5, 2009, 02:38 AM
#76
Personal Sales Rating: ( 3)
Drives: TB EVO IX SE
To stroke or not to stroke....
__________________
A bunch of parts to go super fast...
DTMotorsports
Offline
Jun 10, 2009, 11:29 PM
#77
Personal Sales Rating: ( 6)
Drives: Evo 8.5
Quote:
Originally Posted by 9sectalon
Love my 2.3l with the GT35R. ENJOY!
Are you stroked? If so what kind of hp are you throwing down? In the process of stroking the engine right now and looking for a good turbo to throw on...
Offline
Jun 10, 2009, 11:37 PM
#78
Drives: Lancer Evolution VIII
I run a HTA 3586R with a 2.3 liter, numbers should be coming soon!!!
Offline
Jun 10, 2009, 11:42 PM
#79
Drives: Evo 8.5
Nice, I'll be interested to see what kind of numbers you pull. Let me know...
Offline
Jun 12, 2009, 03:57 PM
#80
Personal Sales Rating: ( 4)
Drives: ww 03 Evo 8
Great info!!!!!..
Ps im looking for a 03 T-case
Offline
Jul 12, 2009, 09:36 PM
#81
Personal Sales Rating: ( 1)
Drives: 06' Evo GSR 92' civic hatch
stroke it dont beat it!! but good info
Offline
Jul 25, 2009, 11:04 AM
#82
Drives: 06 Evo MR
I had my eclipse stroked. it was nice on the street with a 50 trim, but if I were to do it again I would of done a built 2.0
Offline
Aug 25, 2009, 11:29 AM
#83
Personal Sales Rating: ( 0)
Drives: G35
Stroke it brooooooooooooo
Offline
Aug 26, 2009, 08:47 PM
#84
Drives: 04 BBY SSL - 2.3L
Quote:
I bought my Evo with a 2.3L and bb 50 trim. If you are going stroker, don't waste your time on anything smaller than a 54 lb/min turbo. I personally will upgrade to at least 65 lb/min. This 50 trim with .63 housing makes 356 tq at 4700 and 351 hp at 5700 on a mustang dyno. HP drops to 320 at 7200. The car has stock head with HKS 264/272 cams. The turbo just can't keep up with the 2.3 and you can feel it.
Offline
Aug 27, 2009, 08:39 AM
#85
Personal Sales Rating: ( 2)
Drives: eclipse 2003
4g64 2.5l strocker
Offline
Sep 12, 2009, 09:20 AM
#86
Drives: 350Z TT
great info
Offline
Oct 8, 2009, 04:56 PM
#87
Drives: evo 8
very informative.
Offline
Oct 15, 2009, 02:40 PM
#88
Drives: 2003 EVO
stroke it 2.3L rocks
Offline
Nov 16, 2009, 01:49 AM
#89
Drives: 2005 EVO RS
Quote:
Originally Posted by JohnBradley
I also do not believe nitrous helps spool, it only helps off spool power which means it gets to where the turbo would normally spool faster than without.
Old thread found while searching I know, but for the sake of the archives... Nitrous definitely does help spool. I agree with your reasoning above for increases in CR, but remember that nitrous is more air and more fuel burned at that same rpm, which results in more exhaust product, which results in a lower boost threshold. It's the same thing as increasing displacement, more exhaust product per rpm level. In fact I think one could make the arguement that if you add 20% of your power with nitrous the effect on boost threshold is the same as a 20% increase in displacement. I used this theory to calculate the increase in fuel requirements with a dry system on my car and it worked out to within the accuracy of my horsepower measurement at low rpm.
On the automatic the benfit is two fold since the added torque also gets you higher up on the converter making more boost, but that conversion is unlikely to interest anyone here.
__________________
Kevin Jewer
92 Talon RWD, compound turbos - 8.98 @ 156
Offline
Tags
156mm, 21, 23, 4g63, cons, destroked, dsm, evo, jai, magnus, pros, s300sx, stroker, subaru, weight  |
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
HTML code is Off
