Need info on NGK LFR6A-11 for evo 9...
Old Jul 18, 2008, 12:06 PM
StevenStarke's Avatar
Hey guys, Does anyone know what heat range LFR6A-11 is for an evo 9?
-Steve
Old Jul 18, 2008, 12:15 PM
DynoFlash's Avatar
Those spark plugs are OEM for a Yamaha F115 outboard
Old Jul 18, 2008, 12:35 PM
highhats's Avatar
They were garbage in my car. I went back to IKH24 Denso. Next try will be IKH27
S
Old Jul 18, 2008, 12:55 PM
I first got them from MASTER BUSCHUR
Old Jul 18, 2008, 02:21 PM
EVIL MR's Avatar
They are hotter then stock and will not fire properly.
Old Jul 18, 2008, 02:22 PM
EVIL MR's Avatar
This what NGK told me. "The LFR6A-11 is indeed one heat range hotter and will NOT burn colder
than the stock ILFR7H. The other problem is that the set gap of the
LFR6A-11 is at .044" (1.1mm) which is too large for this application and
will not fire correctly if gapped down to .030", as the gap should not
be changed more than .008" from where it is factory set.
To go colder we currently only offer iridium race plugs which are part
numbers R7437-8 (projected tip, street use) or the non-projected, fine
wire, low angle ground electrode version R7438-8 (race use only or high
boost, may foul on street) Hope this helps clear things up. Thank you.
Best regards,
Brandon Peeler
Technical Support Representative
Old Aug 7, 2008, 01:29 PM
gamebred26's Avatar
do the R7437-8 come pre-gapped?
Old Aug 7, 2008, 01:55 PM
these plug work well on the 9, i've used them before. Buschur has used them numerous times
Old Aug 7, 2008, 02:14 PM
PATRICK B.'s Avatar
Old Jun 11, 2009, 04:43 PM
silex's Avatar
anymore info on these plugs or if there are colder ones available?
Old Jun 11, 2009, 07:12 PM
dsevo's Avatar
BR8EIX is one step colder Iridium, and BR8ES is one step colder and standard. I am going to try the BR8EIX on my new build since buschur said Iridiums cleaned up the dyno graph on his Project White on the stock ignition.
Old Jun 17, 2009, 12:19 PM
silex's Avatar
^ This thread is about the copper variations, LFR6A-11, for the Evo9. Evo8 and 9 plugs are not interchangeable!
Old Sep 11, 2009, 05:35 PM
PlanoEvo's Avatar
S
well 800hp on them is too much but DG have used them up to 650hp on IX's ...https://www.evolutionm.net/forums/7377421-post129.html why don't you call them out as well as Dave Buschur as far as gapping more than .008 there might be an issue with some plugs but I gapped mine to .022 and it works just fine
617APEXCT9A
Jan 18, 2017 08:50 AM
foxbat
Jul 26, 2016 01:10 PM
leoni101
Jul 23, 2016 08:23 PM
sketchy mark
Jan 3, 2016 07:34 AM
Done
210
Apr 4, 2015 10:47 PM
Quick Reply: Need info on NGK LFR6A-11 for evo 9...
