Jul 5, 2008, 04:27 PM
Personal Sales Rating: ( 4)
Drives: Evo VIII/SVO Mustang/BMW E30 M3
Quote:
Originally Posted by PharmEcis
We haven't necessarily experienced overrun with the Full Blown setup as we were able to control base FP just fine w/ a Fuel Lab unit and stock lines.
Check your FP on the dyno and at full load. I say this because if you find it possible to dial out the increased idle pressure with an adjustable FP in an attempt to compensate at idle, you just may set yourself up for less than a rising rate of 1:1 under load. And of course, there is no way to know this unless one can view the FP with respect to boost pressure under load.
Quote:
Originally Posted by Ev0cRaZy
I run a Dual Walboro Full Blown setup with stock wiring with no issues at all.
None that you can see anyway. If you check things with a meter against the voltage in your charging system, you'll find that you are not getting full voltage to the pumps. Getting full voltage to the pumps requires a better power feed, and a better ground as well.
__________________
Ted B. Spec JAM Long Rod 2.0L - Headway Performance CNC Head & Valvetrain - DI Intake Manifold - 75mm Hypertune TB - HTA3582R Twin Scroll T4 - Machined 12mm lift Billet Cams - MPFab twinscroll T4 Manifold, TBE, UICP, LICP - MPFab Race FMIC - TiAl 44mm WG - Skunk2 Pro Cam Gears - FIC Bluemax 1250cc - FullBlown Dual 255lph - Synchronic BPV - Spark Tech COP Ignition - TRE Trans - Shep TC + LSD - SPEC Graphite Dual Disc
Offline
Jul 5, 2008, 04:59 PM
Personal Sales Rating: ( 3)
Drives: WW evo X & blue + black drag evo8
if you call full blown they will tell you that they had a recall with there sending units
Offline
Jul 5, 2008, 06:51 PM
Personal Sales Rating: ( 0)
Drives: 03 VIII - Jenna
Quote:
Don't worry. I've had to stand in front of a car many times watching the FPR's gauge while it makes a pass on the dyno. Something I'm quite used to doing. I just wish more people had electronic ones that can log instead of the mechanical ones.
__________________
Greg
2008 Redline Time Attack Summit Point 3rd Place Unlimited FWD In a Stratus!
I haven't blown up ONE Mitsu, but I've built hundreds of fast ones in every size, shape and color!
My cars? Every performance Mitsubishi ever made!
RIP Dave... May we never forget.
Offline
Jul 5, 2008, 07:07 PM
Drives: 05' Evo, 00' BMW 323 Wagon, 94' Nissan Truck
Quote:
Originally Posted by 9sec240
Curious how you have the pumps wired up. Possible voltage drop issue if both pumps are being powered by the factory wiring. IMO, factory wiring is not adequate for two pumps. I run dual relays and use the factory power and ground to trigger the relays. I am also curious if your pumps are the HP version or the regular 255L pumps.
Factory wiring is used only to trigger the relay that powers up the pumps. We're running 8ga. wire from the battery, in the trunk, to the relay and then 12ga to the pumps. We made a quik-disconnect using a a trailer light harness  Pumps are GSS342's.
I would have thought it impossible that fuel could flow in reverse through another pump but for whatever reason it was the case on this car.
Offline
Jul 7, 2008, 02:40 PM
Personal Sales Rating: ( 7)
Quote:
Where did you find that info? We never had a recall on our stuff. The problem with the fuel pressure was dued to the factory siphon be restrictive. We just never had an oppertunity to test drilling out the factory siphon. So we reccomend guys run a hobbs switch or AEM to trigger the second pump. Buschurs kit has the same problem because of the factory siphon. If im correct, I think he uses a hobbs switch as well. I talked to Ted on the phone and he offered to do the testing for us  to TedB. I need to revise the install instructions thanks to TedB. LJ
Offline
Jul 7, 2008, 08:00 PM
Gold Sponsor
Drives: 97 240sx 95 240sx KA 92 Talon
Use extreme caution when drilling the siphon tube. You need to drill straight as an arrow and make sure to remove all the chips from it when your done. If you break through the side of the internal siphon, it will not work and you will end up loading the opposite side of the saddle tank with fuel. Chips not cleaned out completely will also do this.
Offline
Jul 7, 2008, 08:30 PM
Personal Sales Rating: ( 44)
We have NO problems with our double pumpers, thank you very much. This is in response to Full Blowns comment.
Yes, we use a Hobb switch, actually of course we use a Hobb switch. Some cars with AEM's we use the AEM to trigger the pump. I sell atleast 2 double pumpers a week, some weeks up to 5 of them. I have not had a single switch fail, I'd say the worries of a switch failure is pretty low. Running both pumps all the time to me is dumb.
Offline
Jul 7, 2008, 09:28 PM
Dan, i think you read it wrong. I was not referring to the problem of a failed switch. I was referring to the problem of base pressure not being able to go below 60psi due to the siphon. Im not here trying to bash on anyone, just simply stating that we use a hobbs switch to overcome the problem of the fuel pressure being too high because of the stock siphon. LJ
Offline
Jul 7, 2008, 09:41 PM
Please lets not turn this into a negative thread. I just wanted to state why the hobbs switch was used and the fact that it is used in buschurs kit as well. My intentions were not about his double pumper having issues. LJ
Offline
Jul 9, 2008, 08:31 AM
Personal Sales Rating: ( 1)
Drives: Evo IX
I have both pumps running all the time as well and drilling out the siphon + using a -6AN return dropped the idle fuel pressure like a charm...thanks Ted for the tip!
__________________
Current hardware :
EvoRed turbo with BB conversion
2.2L stage 4 shortblock + stage 3 head
Kelford 272 cams
3.5" Bar and Plate FMIC
Motec M800 fully optioned
Ohlins Flag L with Swift springs
Swift swaybars
18" RE30 and 265/35R18 semi slicks
Alcon BBK
Coming soon :
Dual denso supra pumps in custom fuel surge tank
HFS-5 meth kit
CF driveshaft
Titanium catback exhaust system
Offline
Jul 9, 2008, 05:01 PM
So far, so good in my case. Everything is working just fine - no Hobbs switch, no additional wiring, no pressure lines, and noticeably less noise during normal driving than a single pump. I am 100% satisfied.
__________________
Offline
Jul 12, 2008, 10:40 AM
Personal Sales Rating: ( 72)
Drives: 07 4 runner/08 EVO GSR
I had a similar issue with a buschur setup that came with 1 defective pump. Dave replaced it without blinking. but I didnt want to use the hobbs switch he supplied, I wanted both pumps on all the time. So I installed an Aeromotive regulator and rail. That solved my problem
__________________
05 evo-sold
06 g35 coupe-sold/06 gsxr 600-sold
06 evo-sold
05 evo-sold
03 evo-sold
08 evo-sold/06 gsxr 1000-sold
Current-07 4 runner LTD V8/08 cbr 1000rr
C6 Z06 next!!!
Offline
Jul 12, 2008, 04:13 PM
Personal Sales Rating: ( 9)
Drives: 03 evo
Quote:
aeromotive a1000 reg, ams rail, and -8feed -6return here. Can't get below 60psi base with both pumps on.
Therfore, I just use the EMS to switch the second pump.
__________________
03 Rally Red
600whp sold and gone :(
03 Apex Silver
370ish whp sold and gone :(
Offline
Jul 12, 2008, 04:28 PM
I would be more concerned if you could get less than 60psi. That would seem to indicate that there isn't enough fuel to overrun the factory return restrictor.
With a standalone, running an electronic trigger is certainly an option, and IMO preferrable to a Hobbs switch. For those without one or who don't want to configure that, a 9/64 drill bit is all that's needed to fix it.
__________________
Offline
Jul 13, 2008, 02:07 PM
Drives: VI TME
I've tested various drill sizes for the eductor, indeed 3mm was not enough, i had to go 3,5mm but just touching the unit with a drill caused the suction from the right tank-side to drop dramatically. Enough to eventually run out of fuel? I dont know I just stated that this is the case and that it could cause problems on the racetrack.
This is how I would connect my dual walbro if I wanted to avoid drilling the eductor.
This will set the pumps in a low speed mode until desired boost is acheived.
The resistors have to be able to handle at least 200w each.
__________________
EVO 2. VI TME
Europes first 2.6l EVO on the streets making 722hp 880nm www.garaget.org/intero
Offline
Tags
blown, cnc, dual, fuel, full, gs342, mustang, parallel, pump, pumps, series, talon, tank, tsi, walboro  |
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
HTML code is Off
