Jan 2, 2009, 02:07 PM
#541
Personal Sales Rating: ( 48)
2003 Mitsubishi Lancer Evolution
Drives: 03 EVO VIII White
I think if you look at those graphs you'll see that the Kelfords and GSC S2 look basically the same. Any difference is within run-to-run variation for the most part. If you look at the cams themselves they are very similar as well.
I wouldn't expect any real difference going from S2's to Kelfords.
__________________
jid2 Built: Now featuring E85 super fuel
2.3L - GT3076R .63A/R, ETS equal length, Kelford 272's, BC valve springs, 1mm O/S valves, FIC BM 1450's, Full-Blown dual Walbros, Buschur IC, jid2 intake, airbox, IC pipes, APS BOV, TBE, ACT HDSS, Stock ECU, 28 psi 466hp/420 ft-lb...
Build Thread
Binary Lowered Recaro Seats, Girodisc 2-Piece, brake ducting, ST43's, SS lines and ATE Superblue, KW V3's 8K/10K, jid2 flat-bottom, adjustable splitter and aero, 18x9.5 +40 NT03's 265/18/35 BFG R1's
Offline
Jan 2, 2009, 02:16 PM
#542
Personal Sales Rating: ( 2)
Drives: 2003 Mitsubishi Lancer Evolution
Quote:
Originally Posted by DBallz
Well I need advice on cam choice for my evo 8. I'm currently running HKS 272's on a typical stock turbo setup. Well for this year I'm going with a FP Red turbo and some goodies to go with it. My power goal is 500whp on stock motor. So everyone on this forums say Kelford 272's are the way to go with a bigger turbo but I was leaning more towards to GSC S2's. I know I can get them both for a very good price and I know I have to upgrade my valve springs. But according to this original test the GSC were right behind the Kelford. I just want to make the right decision the first time.
Do both the GSC and Kelfords recommend/require valve springs or just the GSCs??
__________________
Apex Silver '03 VIII
Buschur Racing Intake, Deluxe FMIC, IC piping, TB & IM, 880s, ported exhaust, SS O2
FP's WR8 Turbo, 10.5 Hotside, HKS 264i/272e, DLI II Ignition Amp
RnR Racing 3"TBE, Works HF Cat, APS BOV, Hallman Pro RX MBC
Shep Trans; TRE Rear Diff, Stage 4 TC
ROBISPEC ///
Mellon Tuned
... she likes bein' forced ...
Offline
Jan 2, 2009, 05:02 PM
#543
Both, specs are nearly identical on those cams.
__________________
Build Thread
Offline
Jan 2, 2009, 05:37 PM
#544
Personal Sales Rating: ( 3)
Drives: the car pictured above ^
+1 for the Kelfords. I have them with my FP Red and they made serious power on pump gas.
Looking at those two graphs, I see same power curve but the Kelfords make 20WHP more up top.
Offline
Jan 2, 2009, 11:34 PM
#545
Personal Sales Rating: ( 4)
2008 Mitsubishi Lancer Evolution My Garage
Drives: PB EVO X GSR w/SSS, 04 Cobra, 01 Mustang GT S/C, and a Burro.....EVO 8 MR~SOLD
I just ordered my Kelford's, I cant wait to see the difference!
On the graphs the Kelford's did make more power.
__________________
EVERYONE~what do you have done to your car?
ME~"rims and tires"
It is better to die on your feet than to live on your knees.
Offline
Jan 3, 2009, 04:22 PM
#546
Drives: 06 EVO IX SE TB
I think the Kelford 272's and Kiggly Racing springs and retainers is the perfect setup for the red!
__________________
K&N Intake, AEM TRU Boost, AMS JDM Turboback exhaust, ETS lower intercooler piping
Tuned by MAGNUMPSI
Offline
Jan 3, 2009, 04:27 PM
#547
Quote:
Originally Posted by pure_evo
First off, I'd like to say that tests like this is what makes me appreciate the EVO community. Such extensive tests take time, effort, and not to mention dedication. To the crew of AMS (Martin specifically), I for one appreciate the hard work and it is going to serve as a valueable source for my next cam upgrade. Secondly, as I read through nearly 500 posts, I had to shake my head at the ungratefulness displayed by some evoM members with the repeated "what about this cam", "what about that cam" remarks. There are hundreds of cams on the market and the ones tested should give everyone in the EVO community an awesome baseline for choosing the correct cams for their own individual set up. It amazes me that the majority of people want everything at their disposal without doing a little research themselves. By reading through the several write-ups in "Turbo" magazine along with the knowledge contained in this thread, anyone should be able to make an informed decision as it relates to buying the proper camshaft combination. I personally learned quite a bit reading through this thread. I never would have taken into consideration the recommended threshold for a stock head (10.5mm lift) when comparing cams. From what I am able to gather, here is how I see things as it relates to my current/future set up. I plan on running a stock/E85 set up for the near term and ultimately go with a FP Red/E85 set up.
* upgrading from HKS 272 to HKS 280 gained around 20whp more with an increase of spool of about 150RPM
* GSC S2/S3 are recommended to be run with upgraded springs/retainers
* FP5R, GSC S3, Crane, and Tomei 280s are nearly the same overall
* GSC S2 and FP4R are nearly the same
* GSC S2 outperformed all tested cams (except Tomei 280s) between 5-7000RPM
* Kelford 272 has a 11.5mm lift
* JUN 272/272 = 225 intake and 226 exhaust; HKS 272/272 = 208 intake and 206 exhaust; GSC S2 = 217 intake and 217 exhaust
* JUN built around stock head flow rates
* BF272 (not tested) is nearly the same as JUN 272
* BC cams suck on stock head
* FP4R competed with Cosi M2 cams (not tested)
* FP4R has stock-like spool with better topend than HKS 272
So, with all of that said, as it relates to my current set and how I use my car (street, autox, drag), my choices would be:
1. GSC S2
2. Kelford 272
3. JUN 272
4. FP4R
I really appreciate the time and effort that the AMS crew put into these tests and it has certainly helped me to make my next cam upgrade decision.
"BF272 (not tested) is nearly the same as JUN 272" <----This is an old rumor that has been cleared up sometime ago.
__________________
Tuned by MAGNUMPSI
Offline
Jan 3, 2009, 05:36 PM
#548
Drives: EVOLUTION 6
From looking at this thread I'm stuck between gsc s2's ( which have a bit more mid-range power) and the kelfords which make more up top. My current turbo setup is the hks gt3037s kit. Any one with some info on which route i should take? Car will be used for street/TA/drag.
Offline
Jan 3, 2009, 09:11 PM
#549
Personal Sales Rating: ( 1)
Drives: 05 evo8. 91 AMS BUILT talon. 92 ALL MOTOR honda hatch,03 s10
i like the TOMEI 280 on my 37R.was running the GSC 280 .the old version
Offline
Jan 3, 2009, 09:14 PM
#550
Personal Sales Rating: ( 24)
Drives: 05 Wicked White VIII
Let us know what kind of gains you see after the tune.
Offline
Jan 4, 2009, 01:56 PM
#551
Personal Sales Rating: ( 5)
Location: South Beach, FL / Miami, FL / Pt. St. Lucie, FL / NYC
Drives: 05 Apex Silver Version 8, 2001 GSX-R 1000
Quote:
I have no idea if the Kelford require springs but I figure it has almost identical lift so comman sense says yea put springs in. I don't plan on reving the motor more then the stock redline but I don't want issues with the build later.
__________________
Stock Block and Head
FP Red 80mm
Kelford 272's
Beehive Springs
Precision 1k injectors
EPM 02 Dump
ETS 3.5" IC Kit
APS BOV
PPI Extreme Ported Hotside, Exhaust Mani, Intake Mani, and TB
469@28psi on 93
Junior Tuned
THE SHOP CT built
Old setup
Stock Evo 8 Turbo
322.7 whp 320tq 21.5 psi on 93 oct
355.8 whp 430tq 25 psi on c16
Offline
Jan 4, 2009, 02:00 PM
#552
Personal Sales Rating: ( 16)
Drives: Around Crowds watching street racers
Much more than max lift to worry about with valve springs.
Ramp Profile, duration....The distance the valve moves is sometimes irrelevant if the rate at which it opens/closes due to the aggressiveness of of the cam lobe very very fast.
Scorke
__________________
Pressure exploits either the greatest strengths, or the slightest weakness in human or machine; whether that pressure stems from forced atmospheric induction, or is psychological in nature. The result is that human, or machine, becomes legendary either for their increased strength under pressure, or for fracturing as a result of the stress. The most important modification is the driver.
Offline
Jan 4, 2009, 02:17 PM
#553
Drives: Evo VIII/SVO Mustang/BMW E30 M3
A top tier cam cannot deliver full power potential with the weak factory springs unable to exert accurate valve control in the meat of the powerband. It makes about as much sense as spending on a full-tilt suspension but using small wheels and skinny tires.
__________________
Ted B. Spec JAM Long Rod 2.0L - Headway Performance CNC Head & Valvetrain - DI Intake Manifold - 75mm Hypertune TB - HTA3582R Twin Scroll T4 - Machined 12mm lift Billet Cams - MPFab twinscroll T4 Manifold, TBE, UICP, LICP - MPFab Race FMIC - TiAl 44mm WG - Skunk2 Pro Cam Gears - FIC Bluemax 1250cc - FullBlown Dual 255lph - Synchronic BPV - Spark Tech COP Ignition - TRE Trans - Shep TC + LSD - SPEC Graphite Dual Disc
Offline
Jan 4, 2009, 11:32 PM
#554
Drives: 03 evo VIII
Do you guys think the FP beehive springs would be enough for the kelfods?
__________________
03 EVO
FatFab/35r/Shep/Magnus/QM/AMS/SparkTech/Cornfed on a FatFlash.
Best E.T. 11.300
Best trap 136.52
Offline
Jan 4, 2009, 11:50 PM
#555
Quote:
I will let everyone know how they do, Im also installing a gt35r with it so I should see some really good gains. I have to leave Iraq first.........
__________________
ME~"rims and tires"
Offline
Tags
ams, bottom, cam, cams, camshaft, combination, end, evo, idle, ix, magazine, modified, power, test, testing  |
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
HTML code is Off
