Aug 13, 2008, 05:18 PM
#481
Personal Sales Rating: ( 1)
Drives: 04 white EVO,93 awd TSi
Quote:
Originally Posted by Boosted98gsx
Are you guys planning on testing the FP1 FP1x FP2 FP2x FP3 FP3x and FP4's?
Those are DSM cams.
The EVO cams that are 1,2,3s are just Comps standard grinds. Then the 4R and 5R are custom spec cams FP designed but still manufactured by Comp. The Xs were only for the older style 4g63.
__________________
Buschur Built: JE/Crower,stg 3 head, BF272s, 1K PTEs double pumper, tubular 82mm HTA with a.63 housing, newly installed BR Race Core.
480whp unfiltered BR MD Dyno, 544 whp Dynojet STD correction, 3rd gear, 31 psi, Stock ECU and MAF. Straight Shell 93 pump.
Currently running 94170015 V5.10 with SD Patch(Omni 4BAR) 531 whp 406 tq 4th gear, 519 386 3rd, CBRDs MD 33 psi straight pump Shell 93 Self Tuned
Offline
Aug 19, 2008, 06:11 PM
#482
Personal Sales Rating: ( 6)
Drives: 2006 GG EVO IX SE
HOW about some cossie M2 they would be suitable for this car setup>>>
__________________
WTB: GG DRIVERSIDE AND PASSANGER SIDE FRONT FENDERS AND REAR DOORS
Offline
Aug 19, 2008, 07:16 PM
#483
Drives: 06 Evo IX SE
I really appreciate the effort here, but I was wondering if you have any plans to do testing with an IX? Maybe just with some of the top performers here. I would be pleased just to see the results from the kelfords, a gsc cam, and an fp cam. Thanks again for the work.
__________________
06 IX SE tuned by TTP
Offline
Aug 19, 2008, 07:57 PM
#484
Personal Sales Rating: ( 17)
Drives: '03 BBY Evo 8
Quote:
HOW about reading the thread?
THIS TEST IS OVER AND DONE WITH.
IF YOUR FAVORITE CAMS ARE NOT ON HERE, YOU WILL NEED TO TEST THEM YOURSELF.
__________________
Quote:
Originally Posted by Brian_H
I got mine off ebay, it's totally the same. I don't know anything about cars but I can tell you its totally the same, butt dyno felt huge results and my friends brothers uncles cousin runs one in a fast honda.
Offline
Aug 19, 2008, 10:35 PM
#485
Personal Sales Rating: ( 2)
Drives: evo ix mr
Quote:
Originally Posted by JRB_EVO
How does the idle sound with them?
it idle very nice.. a little loopey but i love it.
Offline
Aug 29, 2008, 04:24 PM
#486
Personal Sales Rating: ( 18)
Drives: A Black Mamba in kill mode all day 'eh day as when I hit the gas she goes fast!
First off, I'd like to say that tests like this is what makes me appreciate the EVO community. Such extensive tests take time, effort, and not to mention dedication. To the crew of AMS (Martin specifically), I for one appreciate the hard work and it is going to serve as a valueable source for my next cam upgrade. Secondly, as I read through nearly 500 posts, I had to shake my head at the ungratefulness displayed by some evoM members with the repeated "what about this cam", "what about that cam" remarks. There are hundreds of cams on the market and the ones tested should give everyone in the EVO community an awesome baseline for choosing the correct cams for their own individual set up. It amazes me that the majority of people want everything at their disposal without doing a little research themselves. By reading through the several write-ups in "Turbo" magazine along with the knowledge contained in this thread, anyone should be able to make an informed decision as it relates to buying the proper camshaft combination. I personally learned quite a bit reading through this thread. I never would have taken into consideration the recommended threshold for a stock head (10.5mm lift) when comparing cams. From what I am able to gather, here is how I see things as it relates to my current/future set up. I plan on running a stock/E85 set up for the near term and ultimately go with a FP Red/E85 set up.
* upgrading from HKS 272 to HKS 280 gained around 20whp more with an increase of spool of about 150RPM
* GSC S2/S3 are recommended to be run with upgraded springs/retainers
* FP5R, GSC S3, Crane, and Tomei 280s are nearly the same overall
* GSC S2 and FP4R are nearly the same
* GSC S2 outperformed all tested cams (except Tomei 280s) between 5-7000RPM
* Kelford 272 has a 11.5mm lift
* JUN 272/272 = 225 intake and 226 exhaust; HKS 272/272 = 208 intake and 206 exhaust; GSC S2 = 217 intake and 217 exhaust
* JUN built around stock head flow rates
* BF272 (not tested) is nearly the same as JUN 272
* BC cams suck on stock head
* FP4R competed with Cosi M2 cams (not tested)
* FP4R has stock-like spool with better topend than HKS 272
So, with all of that said, as it relates to my current set and how I use my car (street, autox, drag), my choices would be:
1. GSC S2
2. Kelford 272
3. JUN 272
4. FP4R
I really appreciate the time and effort that the AMS crew put into these tests and it has certainly helped me to make my next cam upgrade decision.
__________________
--- Black Mamba tuned by the NTEC mad scientist with a bunch of "go fast" parts while diggin' in some V8 ass spittin' E85 venom! ---
Offline
Aug 30, 2008, 12:56 AM
#487
Personal Sales Rating: ( 0)
Drives: EVO1
Quote:
on this car yes, but remember that these cams arent designed to be run on a GT35, so the results may be different with a GT42 for example.
__________________
built 2L - GSCS2 - Hypertune intake - GT3582.....
490whp pump gas 27psi dynamics 1.0CF
Offline
Aug 30, 2008, 01:34 AM
#488
Personal Sales Rating: ( 3)
Drives: 03 Evo, 98 Honda Accord, 09 Chevy Silverado
Kelford 272's have 11.0 mm lift, not 11.5... the 280's have a 11.5 mm lift.
1. GSC S2
2. Kelford 272
3. JUN 272
4. FP4R
Offline
Aug 30, 2008, 06:53 AM
#489
Quote:
Quote:
Thanks for the added details and it's certainly information that will shed some light on my potential choices. I'm going to get springs/retainers regardless of the route I choose for an added piece of mind and without knowing the specifications on the BF272, my choices are JUN272 followed closely by the GSC S2. I'm not willing to try anything above the 10.5mm lift range.
__________________
Offline
Aug 30, 2008, 07:01 AM
#490
Personal Sales Rating: ( 16)
Drives: 03 Evo VIII
For the price, GSC S2s cant be beat!
__________________
2003 EVO 8: Sold
2003 Black Terminator...UPR CAI, UPR Short Throw, Bassani Cat Back, BF 2.76 Upper w/Idlers, BF IRS Brace, Accufab TB, H&R Race Springs, MM Caster/Camber Plates, Evenflow Mod.
Offline
Aug 30, 2008, 07:09 AM
#491
Silver Sponsor
Personal Sales Rating: ( 28)
Drives: 05 EVO & 91 Stealth TT
I'd like to know the specs on the BF272 as well but I take comfort in the fact that the fast BR built cars run them.
Offline
Aug 30, 2008, 09:42 AM
#492
Drives: Evolution VIII
Guys I don't know to much about cams and all this lift stuff. I am running HKS 272/272 on my car and I wanted to upgrade to FP red. Which cams would you guys recommend for the street and drag strip.
Offline
Aug 30, 2008, 09:43 AM
#493
Personal Sales Rating: ( 15)
Drives: Wicked White Evo IX GSR
Quote:
Except they require a valve spring upgrade.
Offline
Aug 30, 2008, 10:59 AM
#494
Silver VendorEvoM Guru
Personal Sales Rating: ( 65)
Drives: Old Man with a 03' EVO VIII, 05' Subaru 2.5GT Limited, 06' Kawa Z1000, 02' Kawa ZR-7s, 07' GSXR 1000 (babysitting lil' brother's ride while he's in the sand box), 00' Integra Type R SOLD
All you need it is the inexpensive FP or GSC springs for OE retainers... for most of the cams here that require an upgrade.
__________________
Contact me for parts -n- installs!
Best deals on All Megan products!! Megan Evo X turbobacks and O2 housings!!! OE TYPE replacement rotors-n-pads DEAL. I'm only available 8am-12pm Central Tues-Sat, available all day Sun/Mon. Currently only accepting PayPal, all sales final, customer warranty claims processed directly through the original manufacturer. All shipping quoted for the contiguous 48 states.
Offline
Sep 5, 2008, 11:35 AM
#495
Quote:
Quote:
I planned on upgrading springs/retainers for the added piece of mind. Zeus, it looks like I'll have to wait on the install as Uncle Sam is sending me to train until early October.
__________________
Offline
Tags
ams, bottom, cam, cams, camshaft, combination, end, evo, idle, ix, magazine, modified, power, test, testing  |
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
HTML code is Off
