Jun 10, 2008, 04:27 PM
#421
Personal Sales Rating: ( 0)
Thanks to AMS and all the cam manufacturers for all their hard work.
Personally I am not surprised at the excellent numbers that Kelford has put out. I am currently using a custom grind from them on my nissan vvl build and I have had nothing short of a great experience working with kelford.
Tell them what you are after and they will make sure you have the cams that make power
__________________
2006 GG Evo MR
SR22VE Sentra (project car)
Offline
Jun 10, 2008, 04:46 PM
#422
Personal Sales Rating: ( 61)
Drives: Evo 8
Quote:
Originally Posted by Ludikraut
Kevin, being that I am in the market for a new set of cams, could you elaborate on the difference between your 272 and 280 cams for the Evo 8? Also how do your 272 cams compare to HKS 280 cams?
I am running the same setup as Martin, the only difference is that I am running a 50 trim turbo instead of the 35R. I am specifically interested in a road racing application ... in other words good power, but not so aggressive as to put excessive wear and tear on my valvetrain (supertech).
Thanks,
Markus
+1 Id like to know also.( w/37R on mine)
Offline
Jun 10, 2008, 04:51 PM
#423
Personal Sales Rating: ( 40)
Drives: '05 apex silver evo 8
Quote:
Originally Posted by CamMan
Obviously the magazine and AMS can't build every setup to test, but in my view they have chosen a very common build.
When people are shopping for cams they really need to consult the engine builder, tuner and cam maker to get the correct choice.
The 272 of ours that Martin tested is the 8th iteration of our 272 degree EVO cam, (no one puts more effort into EVO cam R&D than we do) we decreased the seat to seat duration and added more area at higher lifts and this gave us the balance that we have been looking for (good idle, spool and top end)
Because of the low total duration it also works well with smaller turbos than what was tested here.
Big UP'S to Import Tuner mag and AMS for a very good job, and to Motovicity along with their dealer network for supporting our range of products.
Kevin Ban
Managing Director
Kelford Cams
New Zealand
Kevin,
Can your 272 cams be used w/ stock valvetrain w/ the 11mm of lift that they are advertised at reliably or would you recommend upgraded valvetrain?
__________________
Ported IX Turbo/Buddy Club 272/280/Magnus Street SMIM/Muse exhaust manifold/ETS Short Route UICP/LICP/4" MAFless intake/ETS 3.5" Exhaust/ETS 3" widetank fmic/Walbro 255/ACT HD/GM 3 port BCS/Speed Density on stock ECU
MidgetSpec&English Racing
ETS
EDRCrew
Offline
Jun 10, 2008, 06:46 PM
#424
Personal Sales Rating: ( 11)
Drives: 05 Pum Pum Rider
Those Kelford 280's look mean. 11.5mm/11.5mm lift
__________________
No sig....sighhh
Offline
Jun 10, 2008, 07:07 PM
#425
Drives: Ford Bronco, Ford Escort, Ford Falcon, Honda Civic, EVOX (coming soon)
Marcus,
I have no experiance with the HKS280 sorry.
For road course racing, if the tracks are like we have here, where you are up and down the gearbox a lot I would be stcking with the 272's, if you are able to wind the thin out plenty I would consider the 280 on the intake side as it will make more top end on that setup.
Offline
Jun 10, 2008, 07:11 PM
#426
Quote:
Depends on application, boost, fuel, porting etc. but we would generally use 280's
Offline
Jun 10, 2008, 07:15 PM
#427
Quote:
Originally Posted by wshihdnevo
Kevin,
You are best to upgrade.
Although the stock spring will not coil bind, it does not have enough valve control at raised boost and rpm levels, then if you miss a gear and buzz the engine, you have no safety margin.
Offline
Jun 10, 2008, 07:18 PM
#428
Guys, I am not a big contributor to forums etc, if you have any questions, please feel free to send them to me via the camshaftshop website.
Happy motoring.
Offline
Jun 10, 2008, 08:16 PM
#429
Drives: EVO1
Kelford VS S2. S2 is the darker line. Is Martin going to post his conclusions on the testing? Were the cams also tested at a higher boost level, are those resluts going to be put up?
__________________
built 2L - GSCS2 - Hypertune intake - GT3582.....
490whp pump gas 27psi dynamics 1.0CF
Offline
Jun 10, 2008, 08:50 PM
#430
Personal Sales Rating: ( 14)
Drives: 03 Evo VIII, 04 A8L, 00 A4 1.8T, 08 R32, 82 YF750
Marcus,
Thank you !
l8r)
__________________
"Learning is the beginning of knowledge ...
knowledge is the beginning of understanding ...
understanding is the beginning of wisdom."
Suspension book for sale, NEW
Quote:
Any society that would give up a little bit of liberty to gain a little bit of security will deserve neither and lose both.
- Ben Franklin, Thomas Jefferson -
Offline
Jun 10, 2008, 09:40 PM
#431
Personal Sales Rating: ( 1)
Drives: 05 Evo GSR
Hmm...makes me second guess going with Kelford. I just don't want to get into that for the stock turbo. Doesn't seem worth it at that point if you don't plan on going larger.
Edit: Hmm...on the Kelford website they have one a step below the 272's. 264/270. Seems comparable to the GSC S1's roughly.
__________________
AMS TBE | K&N filter | Forge DV | Forge MBC | Walbro 255 | PPI LICP | Kelford 264 | Swift Sport | MR struts | Payne tune
Offline
Jun 10, 2008, 10:29 PM
#432
Silver Sponsor
Personal Sales Rating: ( 74)
Drives: Evo MR
Quote:
That seems to me to be a lift issue and not a Kelford issue. With 11.0mm of lift, most companies I've seen at least recommend upgraded springs and retainers.
__________________
GO HERE TO SEND US A TB: http://forums.evolutionm.net/showpos...&postcount=158
GET 100 cell race cats: http://forums.evolutionm.net/evo-sal...available.html
GET MIL.SPEC TB'S HERE:
AMS CHICAGO, IL
CBRD YORK, PA
ENGLISH RACING CAMAS, WA
GST HAYWARD, CA
MAP PLYMOUTH, MN
MFQ BURBANK, CA
SPEED ELEMENT FREMONT, CA
REESE TUNING SANTEE, CA
TTP ORLANDO, FL
TUNING TECH COLTON, CA
Offline
Jun 10, 2008, 10:36 PM
#433
Gold Sponsor
Drives: 97 240sx 95 240sx KA 92 Talon
Caution should be used when running stock valve train with larger lift cams. The factory retainers will contact the factory seals long before the coils will bind.
Offline
Jun 11, 2008, 12:21 AM
#434
Drives: 2000 BMW 528i Sport "the sweet six"; 1990 Eagle Talon Tsi "Now THIS is a Sports Car!"; 1990 Toyota Corolla "10 times around the world"; 2006 Pontiac GTO "How stupid that GM quit making this wonderful car!"
Quote:
Right. Lift that exceeds the original design envelope, and extreme acceleration of the moving masses, those are the problems. Read FP's web page on the FP5R for some good clues on what the wilder cams do to your valvetrain. I don't mean to say that it's all death and destruction, but everything has to be right.
http://store.forcedperformance.net/m...=Lancer-Engine
Gary
Offline
Jun 11, 2008, 04:15 AM
#435
Personal Sales Rating: ( 6)
Drives: MITSUBISHI EVOLUTION VIII,SRT-4(Sold),07 Eclipse Spyder GT
Kevin Ban
Managing Director
Kelford Cams
New Zealand
Are those the TX272? So I can go ahead and order them
Offline
Tags
ams, bottom, cam, cams, camshaft, combination, end, evo, idle, ix, magazine, modified, power, test, testing  |
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
HTML code is Off
