May 13, 2008, 04:25 PM
#181
Personal Sales Rating: ( 30)
Drives: 2006 EBP IX
Going to buy the magazine
EDIT: Piss on Wal-Mart
Offline
May 13, 2008, 04:37 PM
#182
Personal Sales Rating: ( 6)
Drives: 03 TB Evo
I am going crazy waiting to see the GSC cam results!!
awsome thread, good job AMS!
__________________
03 TB Evo. 4-4-09 @ GLD. 11.71 @ 120mph, 1.74 60'
FULL weight. stock turbo, All season's with 35psi in them
Best MPH- 121.9
Built 2.0/head, Kelford 272's
evo9 turbo, E85, lots of boost.
Offline
May 13, 2008, 04:42 PM
#183
Personal Sales Rating: ( 1)
Drives: 02/06ram35004x4diesel 03evo8
this thread is worst torture then waterboarding.
__________________
2.3L/ bj stage 6 head &int.mani/supertech valve train + 1mm/k1 crank/carrillo rods/ shearer 37r/ tomei 280s/ exedy twin carbon/ ams 1000 hp fuel system/ rc eng 1200 injectors/dli2/ aeromotive fpr/ aemems tuned by Sean Ivey engine by aniel pagan/ 643whp 32psi c-16 512whp 22psi 93oct.........theres 2 ppl that died/will die for you thats jesus christ for your sins and an american soldier for your freedom.............thank them both
Offline
May 13, 2008, 04:52 PM
#184
Gold Sponsor
Personal Sales Rating: ( 0)
Drives: 800whp 2004 EVO VIII, 540whp 2005 Cadillac CTS-V, '01 VW GTi
Quote:
Originally Posted by alan678
Gotcha....but that doesn't mean that they CAN'T be tested.....hopefully one day
With the Evo VIII Cosworth M2's (which have a 280 duration and an 11.0mm lift on both cams) the results should be pretty good in comparison since similar cams are used by most Evo IX owners....lets get the VIII owners some similar 'dyno proven' results
Evo VIII Cosworth M2 Spec sheet...
http://www.cosworth.com/uploads/1147891526.pdf
One thing to remember is that advertised duration is pretty much worthless when comparing cams. HKS 272, JUN 272, CRANE 272 are completely different from each other and make very different power. You really have to look at .050" lift duration numbers to get a better idea of what the cams are going to do.
Offline
May 13, 2008, 06:11 PM
#185
Drives: vi rs
Are you going to release the cam gear settings you used to get the cams to the manufacturer spec?
Offline
May 13, 2008, 06:16 PM
#186
Drives: 2002 WRX 4 sale!
that made picking a cam easy! thanks!
Offline
May 13, 2008, 06:21 PM
#187
Personal Sales Rating: ( 40)
Drives: '05 apex silver evo 8
^the test isnt even done?
__________________
Ported IX Turbo/Buddy Club 272/280/Magnus Street SMIM/Muse exhaust manifold/ETS Short Route UICP/LICP/4" MAFless intake/ETS 3.5" Exhaust/ETS 3" widetank fmic/Walbro 255/ACT HD/GM 3 port BCS/Speed Density on stock ECU
MidgetSpec&English Racing
ETS
EDRCrew
Online
May 13, 2008, 06:22 PM
#188
Personal Sales Rating: ( 21)
Drives: 2005 EVO MR (GONE); 2003 Acura TL
I noticed that you guys are trying to degree in the cams to the factory centerlines; however why don't you guys just install them straight up and run them out of the box?? It would make more sense to see the capablities of each cam as they were designed from the manufacturer. Just a thought
__________________
New times to come with new setup. Evo 9 turbo, Comp 280 Cams, XS Power TBE, UICP, PPI LICP, Hallman MBC, HKS intake, Walbro 255, Synpase BOV re-circulated, K-Sport Coilover, and tuned by SG Tuning in Reno, NV.
Times on Evo8 turbo, intake, JOE P. MBC, TBE, UICP, SG Tuned and all season tires.
11.83@115.8 @ sea level
60FT 1.773 114oct
11.86@111.4 @ sea level
60FT 1.764 114oct
11.97@110.1 @ sea level
60FT 1.740 110oct
12.02@110.2 5000ft above sea level
60ft 1.803 114oct
Offline
May 13, 2008, 06:44 PM
#189
Personal Sales Rating: ( 26)
Drives: 09 RalliArt; Lancer Evo IX MR; 1999 Honda Civic
Martin,
Any chance that the graphs can be plotted using RPM instead of car speed?
BTW, I appreciate the time and effort of doing this type of test! Good job!
__________________
Thanks!
-Joed
EVO MR 2006 - 403.08 WHP / 356.68 TQ - FPGreen // BR Stages 1, 2 & Race I/C // Nisei LICP // PTE 780CCs // Walbro 255 hp pump // Blitz iColor @ 25 PSI // LC-1 WB // GSC S2 // Defi BF w Gruppe-S Panel
Offline
May 13, 2008, 06:56 PM
#190
Drives: EVO1
Quote:
im pretty sure thats what they have done, set them up per each manufacturer's specs, then played aruond with cam gear settings, correct me if im wrong.
__________________
built 2L - GSCS2 - Hypertune intake - GT3582.....
490whp pump gas 27psi dynamics 1.0CF
Offline
May 13, 2008, 07:30 PM
#191
Personal Sales Rating: ( 43)
Drives: on the shoulder to pass
If I remember correctly the first article said that each cam is milled slightly different and may not even match the intended specs. Hence all the expensive testing to find it's centerline and correctly degree each cam to match the specs of the manufacturer. Two sets of cams from the same company can have the same duration and lift but be a half a degree off or more from each other.
__________________
Quote:
Originally Posted by Jrod@Buschur
Man... i'm so JDM I sleep on the right side of the bed. {thumbup}
Quote:
Originally Posted by gsnt
Fastest and quickest Evo VIII in the universe and surrounding states!
Quote:
Originally Posted by saev
"Well he may have passed me like I was in reverse, but at least I still got my PSHH."
Offline
May 13, 2008, 07:41 PM
#192
Correct! All of the tolerances (Cams, cam gears, timing belt) can throw the cam off from the manufacturer intended 0. Therefore, AMS dialed them to their true 0 considering Piston 1 at TDC... regardless of what the cam gears are finally dialed.
__________________
Thanks!
-Joed
Offline
May 14, 2008, 07:58 AM
#193
Personal Sales Rating: ( 20)
Drives: AMS Equipped EVO VIII
Subscribed, awaiting GSC S2 testing.
__________________
EVO VIII
Offline
May 14, 2008, 08:06 AM
#194
Personal Sales Rating: ( 9)
Drives: AS and WW Evo VIII MR, 89 Nissan 240sx Coupe, 97 Civic Cx Hatchback
Nice results on the HKS 272's
Offline
May 14, 2008, 08:33 AM
#195
Gold Sponsor
Personal Sales Rating: ( 42)
Drives: 2007 BMW 335i
sorry for this layover guys. Martin didn't realize that he was going to take a much needed vacation in the middle of this. I think he was due as he has not gone on one for the better part of 3-4 years LOL.
He will be back on Thursday and he will make up for lost time. Sorry again and thank you very much for your patience.
Eric
__________________
Eric Gaudi
-Sales Manager-
Eric@amsperformance.com
AMSperformance.com
Tel. 847-709-0530- World's QUICKEST EVO 8 - 8.42 with a best trap of 171 MPH
- World’s Most Powerful EVO – 1142 awhp
- 2008 AMS Racing – 40 Victories in Road Racing and Hill Climb
Online
Tags
ams, bottom, cam, cams, camshaft, combination, end, evo, idle, ix, magazine, modified, power, test, testing  |
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
HTML code is Off
