Oct 26, 2009, 12:56 PM
#46
Personal Sales Rating: ( 0)
Drives: many mitsu's
I had the same problem. I had a power enterprises belt. a mirage stub shaft.
I drove the car with a jdm motor swap for 1000 miles then did an off highway 4th gear pull and killed the oil pump. the belt was set on the tight side so we changed it put in a new front case looked at the tensioner wasnt leaking still stiff so we reused it. I drove the car for about 1000-1500 miles easy a few pulls but after that amount of time I thought everything was fine.
I did a 4th gear pull killed another oil pump. Both times I used the mitsu stub shaft. we were looking at the tensioner and decided to use a new one. I noticed that when we tried to re-compressed the old one (used on the first 2 pumps) that it popped in the vice like it may have been sticking.
So I used a mirage front case that came off of my stock 1.6 liter and was fine for 7years and had zero wear. so I now have a new tensioner, my 1.6 liter front case, and we used a gates black (normal) belt. I also used my 1.6 pressure relief distribution block in the head. The car is running again but I am afraid to boost on it.
My front case is eaten just like the one in the picture above.
This has been drivin me crazy not knowing what is doing this.
Offline
Oct 26, 2009, 04:18 PM
#47
Personal Sales Rating: ( 86)
Quote:
Originally Posted by Drifto
I am running the Power Enterprises belt that I'm pretty sure is bullet proof  . It was/is a stiff SOB - Almost feels plastic... It's suposed to be the stiffest belt made and they guarentee it not to stretch. That being said. I set the tensioner per Mitsu's recomendation and it is as quiet as the stock belt. It doesn't make any wierd noises either. I'll bet your whining sound is totally based off how you are setting up the tensioner. What your doing does make sense if your only worried about the belt coming loose, but when the engine excellerates there has to be sufficient travel in the opposite direction (compression)for the tensioner to absorb the extra tension placed on the belt. If the tensioner bottoms out, because of lack of travel, you will end up with a belt that is too tight. It will stay tight until the tensioner has a chance to re-adjust.
This post is not intended to imply that you're not justified in your practices with the hydraulic tensioner, but I don't think you can place the fault on the "blue belt" either. I'd bet that your methods of tensioning are not agreeing with the extra stiffness of these kinds of belts and that is the reason for the problem. Peolpe who follow the recomended guidelines for setting up the tensioner will have zero problems with the extra stiffness provided by a " Blue Belt"
wrong. the belt gets longer on tensioner side during a pull. not shorter.
and if you were correct I would be having same problems with black stock belts.
__________________
early evo nut rockin
evo1 and evo 4
Offline
Oct 28, 2009, 08:47 AM
#48
Personal Sales Rating: ( 4)
Drives: 05' Evo, 00' BMW 323 Wagon, 94' Nissan Truck
I shouldn't have posted. I forgot you already know everthing...Thanks for being open minded...
Offline
Oct 28, 2009, 10:17 AM
#49
That's irrelevant. We all know everything!
__________________
MASTER CERTIFIED ENGINE BUILDER
_____________
http://www.myspace.com/hiaspirations
Facebook : Jimmy Bowling Cincinnati
JIMI B \\// BUSCHUR RACING \\// FORCED PERFORMANCE
______________
IX RS/\ FP RED/\ FP5R FULL BUILD THREAD:
http://forums.evolutionm.net/evo-eng...tor-build.html
Offline
Oct 28, 2009, 11:54 AM
#50
Personal Sales Rating: ( 2)
Drives: volvo 740 turbo
So let me get this straight.. the person having the problems is 100% correct about everything, and the people that *aren't* having problems are wrong?
You sure you don't work for the Obama administration?
__________________
03 TB EvoVIII, ams 35r, fmic, cams, etc. 440whp
90 Volvo 740 16v, t67, blah blah blah 512whp
Offline
Nov 3, 2009, 07:13 PM
#51
I have about 20,000 miles on the power enterprise blue belt with no problems in a first generation DSM. Not sure what the commotion is all about.
Offline
Nov 3, 2009, 07:19 PM
#52
Personal Sales Rating: ( 19)
Drives: '05 MR
Is there something wrong with the factory belts? I hear of ppl right and left getting aftermarket belts. Was just curious as to why? You're supposed to change them at the same intervals anyway.
Offline
Nov 3, 2009, 08:39 PM
#53
Gold Sponsor
Drives: 2009 Octane Blue Ralliart and AMS/NOS Energry Drink Drag Evo
I did a motor build on an Evo IX last week. The customer purchased a Gates blue timing belt kit. After about a day of break in, a noise could be heard from under the cover. I removed it to find that the cogs in the belt were making noise in one section of the belt.
I removed it and installed a Power Enterprise blue belt and the noise was gone. I would have put an OEM IX belt on it, but we didn't have on in stock at the time and the car was scheduled to be dyno'd.
Offline
Nov 3, 2009, 08:44 PM
#54
Personal Sales Rating: ( 1)
Drives: 2003 evo.. 07 daytona 675
20,000 miles on power enterprise belt.. no issues..
__________________
perrin intake tube
ams mbc
buschur dp
under hood bushings
perrin adjustable shifter
megan resonated test pipe
ebay catback picked up on here
gsc s1 cams
fidanza 3.2 (x x x toast) and flywheel
ACT HDSS
powerslot rotors
hawk hps pads
MAF filter kit
perrin shorty antenna ( don't like the RC car look)
BAD NEED TO BE ON E85 :(
tuned by KevinD
Online
Tags
1990, belt, belts, blue, eagle, evolution, gates, good, kevlar, replace, supra, talon, timing, tomei, topline  |
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
HTML code is Off
