Evo Engine / Turbo / DrivetrainEverything from engine management to the best clutch and flywheel.
Sponsored by: World Racing
Welcome to EvolutionM.net!
Welcome to EvolutionM.net.
Drives: 2003 Evo Rip 1996 Eagle talon tsi 1997 Honda prelude Type SH
Points: 3,887, Level: 39
Daily Activity: 0%
Quote:
Originally Posted by diablo2184
why is it not extreme?
the 4g64 is a bored 4g63 is it not? as you increase the size, you are thinning the walls and making it weaker.....i think thats right. please correct me if i am wrong, but i think im somewhat on the right track.
and both the 4g64 and 2.4+ size engines shouldnt really go past 8k. the pistons are moving too fast and heat up too quickly, so high RPMs are not good on them.
No the 4g64 and 4g63 bore is pretty much the same . The 4g64 as a taller deck height aka the cylinders are longer.
__________________
Turbo smart MBC, ARP HS, BC 272/272, SBR turbo header, titek o2 housing, DC sport DP ,turbo xs CB, perrin light weight crank pulley ETS lower, upper and intake pipes, turbo xs bov, iredium plugs, ams mini race battery, walbro 255, Ingalls tq dampener Turbo XS FMIC Perrin Fuel Rail AMS 780cc tein s springs hotchisk rear 24mm rear sway bar
Selftuned at forced Induction
344whp 369tq 29psi dyno jet
Not that I know of. I feel it is really too much displacement for a 4 cylinder. Possible bore and stroke for a 2.6? I wouldn't go north of 2.3 with this engine IMHO.
Toyota have a 2.7L 4 banger.
This is definitely an extreme build. I don't see the point of it thought. Most of the high HP Evo are 2.0-2.2L. If you really want something wicke for the road course, you can always get a well built, proven 2.0L engine and have your tranny build with really tall gears.
We have some dyno sheets around here somewhere. Ill see what I can dig up.
__________________
Slowboy Racing
Jason Overdorf jso@slowboyracing.com
Visit our new webiste at www.slowboyracing.com and use coupon code Evolutionm and get 5 % off any order!
low down torque and response is the key and what we should have in the end product .
I have a 2.16 stroker now to be exact , and rev to 7000rpm with it - dont need anymore because that also has awesome spool up and this one should be even better but just produceing more power with the bigger turbo and displacement
Your not on the wrong track just......derailed. 4g64 has a 86.5mm bore with a 100mm stroke, the 4g63 has a 85mm bore and a 88 mm stroke ,the main difference has to do with the significant increase in stroke, thinning the walls 1.5 mm will make it weaker, how much so I am unsure.
Your comment about why you cannot rev these motors that fast is due to the change in the dynamics of having a significantly different stroke/rod length combination, and has NOTHING to do with pistons heating up too fast.
Scorke
__________________
Pressure exploits either the greatest strengths, or the slightest weakness in human or machine; whether that pressure stems from forced atmospheric induction, or is psychological in nature. The result is that human, or machine, becomes legendary either for their increased strength under pressure, or for fracturing as a result of the stress. The most important modification is the driver.
Not an evo but a an 2g. My buddy just got a 2.4 and He said he order the crower stroker making it a 2.6. I am pretty curious on how that turns out myself
__________________
Great sacrifice comes great rewards
New Update. We are putting a 40R on the 2.5L evo tonight. It will be a few days before we get it tuned buy as soon as we get graphs I will post them up.
__________________
Slowboy Racing
Location: Work - New York, Alaska, Mexico or the Caribbean. -Home - Tx Hill Country
Drives: 08 Blk STi, 03 Blk EVO 8
Points: 5,627, Level: 48
Daily Activity: 0.7%
Quote:
Will it be a twin scroll set up?
Quote:
Originally Posted by ozlookalike
from what I read before, Crower says that their 2.6l stroker will rev freely to 9500+rpm...that is however, dependent on the head setup.
That's nuts. I've never heard anything like that. Can you post where you read that. Not calling you out, I'm just curious.
__________________
For Sale - Stock O2 Housing $50 shipped.
