Home Features Community Marketplace Registry Garage Store
Go Back   evolutionm.net > Lancer Evolution 1-9 Forums > Evo Engine / Turbo / Drivetrain
Sign in using an external account
Register Forgot Password?
Sponsored by: World Racing
Welcome to EvolutionM.net!
Welcome to EvolutionM.net.
Thread Tools Search this Thread
Old Feb 9, 2008, 05:35 AM   #1
Personal Sales Rating: (56)
Garage is empty, add now
xLaNcErEvOx's Avatar
Drives: 03 Yellow Evo
Points: 9,299, Level: 64
Points: 9,299, Level: 64 Points: 9,299, Level: 64 Points: 9,299, Level: 64
Daily Activity: 0%
Daily Activity: 0% Daily Activity: 0% Daily Activity: 0%
Something wrong with my clutch
Story is:
I drove perfectly fine to my friends house last night. Right when I get in the car to leave I push the clutch down and the car starts, BUT then the clutch is on the floor with no pressure and i cant get into any gear.
My friend told me my slave cylinder is out so what do i do???
Offline
Old Feb 9, 2008, 05:48 AM   #2
Personal Sales Rating: (4)
Drives: 2006 Evo IX,
Points: 4,859, Level: 44
Points: 4,859, Level: 44 Points: 4,859, Level: 44 Points: 4,859, Level: 44
Daily Activity: 0.4%
Daily Activity: 0.4% Daily Activity: 0.4% Daily Activity: 0.4%
Check all the fittings on the clutch line for leaks. Check the fluid level on the master cylinder, if you did not find any leak and the level is good then try bleeding your clutch. If it does not help then yeah your slave cylinder went out.
Offline
Old Feb 9, 2008, 08:21 AM   #3
Silver Sponsor
Personal Sales Rating: (48)
2003 Mitsubishi Lancer Evolution
My Garage
KevinD's Avatar
Drives: '03 evo8 time attack car, '10 tundra tow vehicle, '03 evo daily
Points: 14,829, Level: 78
Points: 14,829, Level: 78 Points: 14,829, Level: 78 Points: 14,829, Level: 78
Daily Activity: 12.6%
Daily Activity: 12.6% Daily Activity: 12.6% Daily Activity: 12.6%
correction, if your slave cylinder went out you will have fluid leaking from it. if you don't have any fluid leaking anywhere (from slave or master or the line), your retainer ring for the throw out bearing came apart. unfortunately if that is the case, you need to take the tranny out to fix it.
you can tell if that is the case by looking at the clutch fork visually. if you look at the slave cylinder rod, where it meets the clutch fork, if it is pushed all the way to the passenger side of that hole in the bell housing then your retainer ring came apart. you can take the two bolts holding the slave cylinder in place and move it out of the way slightly, then try pulling the clutch fork forward (to the driver side. if it doesn't click in place then you're in trouble.
__________________
EVOLUTION DYNAMICS LLC
Tuning, Custom Fabrication, and installs in the DFW area.
www.evodynamics.com
email: evokevin@gmail.com
Phone + Text messages: 817-776-2170
Enkei, mil.spec, ACT, WhiteLine, FIC, ShepTrans, Zeitronix, Buschur Racing + many others
Evo Dynamics Unlimited Time Attack Build
Join us on FaceBook!
About Us: Evolution Dynamics
Offline
Old Feb 9, 2008, 01:48 PM   #4
Daily Activity: 0%
alright thanks for the insight
Offline
Old Aug 31, 2008, 08:22 PM   #5
Personal Sales Rating: (22)
Thoe99's Avatar
Drives: '03 Lancer Evolution 8
Points: 14,287, Level: 77
Points: 14,287, Level: 77 Points: 14,287, Level: 77 Points: 14,287, Level: 77
Daily Activity: 0.8%
Daily Activity: 0.8% Daily Activity: 0.8% Daily Activity: 0.8%
Quote:
Originally Posted by KevinD View Post
...you can tell if that is the case by looking at the clutch fork visually. if you look at the slave cylinder rod, where it meets the clutch fork, if it is pushed all the way to the passenger side of that hole in the bell housing then your retainer ring came apart. you can take the two bolts holding the slave cylinder in place and move it out of the way slightly, then try pulling the clutch fork forward (to the driver side. if it doesn't click in place then you're in trouble.
Which side is it supposed to be facing normally when the car is off? Can the retainer ring come apart with the car off?
I took the slave cylinder off to take my clutch restrictor off but didn't note which side that was facing. Right now it is towards the passenger side and my clutch has no pressure. It'll fall to the floor if I try to bleed it.
__________________
Power: BBK-Full turbo, E85, ported & ceramic-coated 10.5 hotside, PPI ported & ceramic-coated exhaust manifold and Megan O2 housing, GSC S1 cams, ETS 3.5" intercooler, QTP 3" downpipe, Hallman Pro MBC @24psi, PTE 1000cc injectors, Vibrant cone air filter, Nisei LICP
Suspension: RobiSpec KW Club Sports, 18x9½+40 Enkei NTO3-M, 265/35/18 Hankook R-S3, +more
Autocross Competition
2009 MSCC Tiger Overall champion
2009 MSCC Street Mod Street Tire champion
2009 MSCC Prepared champion
Offline
Old Sep 1, 2008, 08:34 AM   #6
Thoe99's Avatar
bump?
__________________
Offline
EvolutionM
Mitsubishi Lancer
Paid Advertisement
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Content Relevant URLs by vBSEO 3.5.2
All Passwords
