Jan 18, 2008, 01:41 PM
Personal Sales Rating: ( 4)
Quote:
Originally Posted by topturtle
The ECM optimizes the intake valve timing using the VVT (Variable Valve Timing) system to control the intake camshaft. The VVT system includes the ECM, the Oil Control Valve (OCV) and the VVT controller. The ECM sends a target duty-cycle control signal to the OCV. This control signal regulates the oil pressure supplied to the VVT controller. The VVT controller can advance or retard the intake camshaft. If
the difference between the target and actual intake valve timings is large, and changes in actual intake valve timing are small, the ECM interprets this as the VVT controller stuck malfunction and sets a DTC.
You may have inadvertently clogged the OCV filter located on the back of the head passenger side if I remember correctly. Without looking I couldnt tell you. Use correct build up oil when installing new cams. Rtv in the oil system when putting valve cover back together. Im just throwing things out there to help narrow it down.
is it the sensor about 3" below the intake cam gear on the back of the head??
__________________
2006 Evo 9 SE
Mods: GSC stg1 cams 3' tbe, injen upper intercooler piping/intake, ams lower intercooler pipe, mbc @22psi
Boost gauge, oil psi, and aem wideband, shifter bushings, hid fogs
Tuned by Mellon
Offline
Jan 18, 2008, 01:56 PM
we pull out the sensor and cleaned it...did NOT see any RTV... there was oil in one of the holes to it but idk if it should have drained out or not but its gone now because the sensor was removed and cleaned
__________________
2006 Evo 9 SE
Tuned by Mellon
Offline
Jan 18, 2008, 02:50 PM
ttt
__________________
2006 Evo 9 SE
Tuned by Mellon
Offline
Jan 18, 2008, 04:23 PM
k we're stumped....should i just retard the cam one(1) tooth and try that??
__________________
2006 Evo 9 SE
Tuned by Mellon
Offline
Jan 18, 2008, 04:29 PM
Personal Sales Rating: ( 35)
Drives: 06 TB Evo MR
When everything is lined up on the hack marks. What does your cam angle sensor on the other side look like. For some reason the ECU is thinking that cam angle target is off.
Offline
Jan 18, 2008, 04:42 PM
explain on what you mean "what does it look like??" please and thank you
__________________
2006 Evo 9 SE
Tuned by Mellon
Offline
Jan 18, 2008, 04:48 PM
Sorry. With all the timing marks lined up and the cover off the intake cam sensor on the driver side, is the paint mark on the sensor up top. Second just to rule it out when the cam belt was off were you able to move the intake cam gear a few degrees either direction.
Offline
Jan 18, 2008, 05:08 PM
its not the intake cam sensor..the sensor only goes on one way...no i did not try to move the cam gear a few degrees in either direction
__________________
2006 Evo 9 SE
Tuned by Mellon
Offline
Jan 18, 2008, 05:47 PM
Well with everything mechanically looking good then I would start looking into an ecu issue which would be Mellons area more than mine. Im sorry I couldnt help out more. Good luck and let us know when you get it solved.
Offline
Jan 18, 2008, 06:01 PM
Silver Sponsor +1
Personal Sales Rating: ( 445)
Drives: 2008 Evolution GSR SSS, 2005 Evolution MR, 2003 Evo GSR, 1995 TsiAWD, 1995 GST, 1995 Tsi 2wd, 1991 GVR4 WW, 1991 GVR4 NBM, 1993 TsiAWD, 1991 Tsi, 1995 RS N20
mivec trigger wheel 180* out of phase.
__________________
2005 Evolution VIII MR
763whp/595tq HTA86
10.19 & 143.3mph stock ECU
Factory ECU Expert
2008 Evolution X GSR
12.0@113mph Full Wt+
In House Mustang Dyno AWD-500!
www.ttp-engineering.com
(407) 475-0010
AIM=TTPEngineering
MODIFYING THE 4G63 SINCE 1995, YES 14 YEARS!
TUNING EVO V - EVO X & 2009 RALLIART!
TTP's Myspace page!
Offline
Jan 18, 2008, 06:13 PM
TTP has the nomenclature down more so than I. There should be a paint mark that is up top on the trigger wheel when all your timing marks lined up.
Offline
Jan 18, 2008, 06:29 PM
Quote:
what do i need to do to put this back in "phase??"
__________________
2006 Evo 9 SE
Tuned by Mellon
Offline
Jan 18, 2008, 07:49 PM
ttt
__________________
2006 Evo 9 SE
Tuned by Mellon
Offline
Jan 19, 2008, 06:51 AM
morning bumb
__________________
2006 Evo 9 SE
Tuned by Mellon
Offline
Jan 19, 2008, 11:23 AM
Personal Sales Rating: ( 6)
Drives: 2006 EVO IX
Here is what the FSM says to trouble shoot:
1. Oil feeder control valve.
2. Check oil passage of variable valve timing control system for being clogged.
3. Check variable valve timing sprocket operation mechanism for being stuck.
4. Replace ECM.
This is on a stock car.
What type of mivec map are you using? Is it the JDM RS map?
__________________
2006 EVO IX, Stock
2002 Toyota Tundra, 207 hp, 271 ft-lbs torque
1998 SE-R Race Car, 2008 SCCA ITA SoPac Champion
Offline
Tags
03, 2002, check, code, dtc, engine, evo, evolution, ix, lancer, maxima, mean, nissan, p0011, p011, po11, trouble  |
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
HTML code is Off
