Sep 22, 2007, 05:23 PM
#31
Personal Sales Rating: ( 4)
Drives: Evo VIII/SVO Mustang/BMW E30 M3
Quote:
Originally Posted by linuxman51
don't modify your car if you want to keep the low end. Long intake runners have a far more profound impact on high rpm power (negative) than short runners do on low end power.
Its obvious that you don't like the part-just say it.
I implied no such thing. There isn't nearly enough information available to form an opinion.
About runner length, my observation is the manifold this part aims to copy (JUN) appears to have significantly longer runners. Likewise, the AMS and Magnus manifolds both have longer runners. The runners of the JUN, AMS, and Magnus manifolds, while significantly longer, are NOT long by resonance calculations. The runners of the Ku manifold however, appear to be very short.
My point in illustrating this is purely logical. The AMS, JUN, and Magnus manifolds are proven to improve high speed torque by a significant margin, without adversely affecting spool characteristics - and there is substantial value in that.
The Ku manifold remains unproven at this point, and will remain so until proper A/B testing is available. We don't even know who the heck "Ku" is, or how much or little thinking went into this part. My concern is that it may very well affect spool characteristics as a result of the very short runners. No one knows the answer one way or another at this point.
__________________
Ted B. Spec JAM Long Rod 2.0L - Headway Performance CNC Head & Valvetrain - DI Intake Manifold - 75mm Hypertune TB - HTA3582R Twin Scroll T4 - Machined 12mm lift Billet Cams - MPFab twinscroll T4 Manifold, TBE, UICP, LICP - MPFab Race FMIC - TiAl 44mm WG - Skunk2 Pro Cam Gears - FIC Bluemax 1250cc - FullBlown Dual 255lph - Synchronic BPV - Spark Tech COP Ignition - TRE Trans - Shep TC + LSD - SPEC Graphite Dual Disc
Offline
Sep 22, 2007, 11:50 PM
#32
Personal Sales Rating: ( 0)
Drives: Your MOM
KU means penis in chinese
Offline
Sep 23, 2007, 07:57 AM
#33
Personal Sales Rating: ( 6)
2005 Mitsubishi Lancer Evolution
Drives: 2005 Evolution RS WW
In other words... ^ HA! you got dicked!
Some decent logs before and after would really make a world of difference to my opinion of the thing. Nothing like a good comparison on a newerish part.
__________________
Buschur 3" TBE no cat, Buschur deluxe FMIC & piping, HAFE GT3076R turbo kit, GM BCS, HKS 272's, Tial bov & 44WG, W255, FIC 850's, MaftPro, LMS meth kit, GTWorx springs, Bilstein HD's, ES bushings, AWD MS Alu D/S, Beatrush d/s bushings, Powerflex front & rear mount, ACT 2900 /street disc, Prolite flywheel, DBA 5000/4000 brakes, Goodridge, Motul. Emissions delete, all tuned with ecuflash!
-Dustin
Just PM me!
Offline
Sep 23, 2007, 08:36 AM
#35
Personal Sales Rating: ( 17)
Drives: 2005 Corvette C6 z51
screw the manifold i want the purple throttle body :P
__________________
Evo 8.5 11.7@118 1.68 ***SOLD***
05 Black C6 z51: A&A 3.8 V3 kit - LG Pro Longtube/Xpipe - B&B Bullets - TR6 - MSD 8.5 - LS7 Clutchkit
Offline
Sep 23, 2007, 03:27 PM
#36
Personal Sales Rating: ( 5)
Drives: whatcha think???
This manifold was used on the DSport cover car-240 with a full race turbo kit. Seemed to work great for him.
Offline
Sep 24, 2007, 07:24 AM
#37
Possibly, but the same thing ("works great") is often said of things like Splitfire plugs, Nology wires, and Turbinators.
I would be delighted to find something that works as well as the proven manifolds, but I'd like to see something solid in the way of testing and opinions as to proper port matching and fitment before forming an opinion.
__________________
Offline
Sep 24, 2007, 07:26 AM
#38
Drives: 2005 Evolution VIII
Quote:
Originally Posted by nothere
or, how much shorter are the runners than the stock piece?
Correct me if I am wrong, but aren't the runners on the OEM manifold longer than the sheetmetal intake manifolds?
It seems like they are because of the sheetmetal manifolds having a straight runner out of the plenum, and the OEM exiting the bottom, and curving down, then towards the head. (Plus they are not "straight shots" to the head intake ports. They all, when viewed from straight above the manifold, curve to the left as well, adding length also.
Hey TedB, wouldn't short runner lengths decrease spool-up time because of the shorter distance the air physically has to travel?
:Imightbeanidiotandovercomplicatingthis:
__________________
Thomas..
2005 EVO GSR Charleston, SC
Offline
Sep 24, 2007, 07:34 AM
#39
Quote:
No, the runner dimensions resonate at a certain frequencies, like a guitar string, speaker tube, or musical instrument. The shorter they are, the higher the resonance peak. If the resonance peak is either too low or too high, performance will suffer. This is a very basic description. Rest assured that it gets far more involved.
__________________
Offline
Sep 24, 2007, 07:47 AM
#40
Consider the Cyclone IM, with a combination of both.
Long tuned port runners for building low end torque, and spooling a turbo. Switching over to short runners once the car is spooled and increasing the ability to feed air quickly, and promoting better breathing at higher rpm. Or atleast better than the longer runners.
That might be more basic than Ted's post, but still the animal we're dealing with.
The balance comes in exactly where he said. Having the right port sizes or resonance to match the widest rpm range. To avoid a car with no powerband except on top, or on the bottom, etc.
__________________
-Dustin
Just PM me!
Offline
Dec 31, 2007, 02:57 PM
#41
Personal Sales Rating: ( 24)
Drives: 434whp CBRD SpeedFactory/Blouch Turbo EBP Evo IX 6spd...Yes, a Motha Fuct'n 6spd...WTF...OMG...PIITB!!!
any more info about this mani?
Offline
Jan 1, 2008, 02:27 PM
#42
Drives: VI TME
Quote:
I got mine a few weeks ago, havn't had any chance to test it yet but hopefully the car will be ready late february.
I bought it with a 70mm Throttle Body and that piece looks amazing, the manifold however is a bit of dissapointment, quality is poor and the runners are way to short! Theoretically the runner lenghts are optimized for a peak torque @ 9500rpm, then you'd probably have to rev your car to 12.000rpms to get any real benefits from this manifold.
Mine's going to be modified, I'm going to increase the runner length as much as possible.
Conclusion is: It might be worth it for the "bling" but if you're looking for serious power you could probably save yourself a lot of headache by buying a prooven intake manifold such as the AMS, JUN or Magnus.
I'll post som pictures tomorrow.
__________________
EVO 2. VI TME
Europes first 2.6l EVO on the streets making 722hp 880nm www.garaget.org/intero
Offline
Jan 1, 2008, 07:15 PM
#43
Personal Sales Rating: ( 25)
2003 Mitsubishi Lancer Evolution
Drives: 2003 EVO-2002 WRX-2003 R6 (sold) :(
Quote:
Originally Posted by Ted B
The manifold looks to be an attempt at a JUN copy. The issue I see right off the bat (aside from possible fit and finish imperfections) is with the very short runners. I don't have enough photos to be certain, but it appears the runners are very short - shorter than anything else I've seen, and that isn't something I regard as a good thing.
There just isn't enough information to draw sound conclusions.
I thought the runners looked very short too.
__________________
Rally Red Evolution 8
Offline
Mar 12, 2008, 07:43 PM
#44
Personal Sales Rating: ( 7)
Drives: 03 Evo 8, 05 Kawasaki 636RR, 08 Kawasaki KFX450R
Guess ill post up that i bought one too a while ago. like two years ago but havent driven my car since seeing i dont have a license and the car isnt insured or registered.
Anyway I had to drill a hole in it for the map sensor because it had no place for it. Also if you go with it you should know its flanged for a 5.0 FI Mustang. I went with a 75mm BBK which Im having re-done by FFTEC because the bushing leak and they also put a ISC adapter plate on it.
As for the EGR I took it off and disabled it using the perephery patch. All the solenoids i just mounted on a plate and ran my vacuum lines using a vacuum block for better distribution and less chance of leaks.
Question for the others with it. How did you guys mount your map sensor ? Or are you using AEM or something else ?
Ill post more as i go.
__________________
CBRD Slim Rad~Ported Evo 9 16g~Labonte's ISG-S3~BR S.S. o2~HKS Ann. Ed. Ex~3" TP~HKS 272's~PPI PEM~PTE 780's~TTP Spec BBL~SuperTech Duals~4" TurboXS FM~BR LICP~TTR UICP~Sychronic BPV~GM BCS~ACT HDSS~ACT Pro-Lite Flywheel~S.S. -6AN Lines~AMS Full S.S. Clutch Line~Walbro 255~BLOX FMM~Carbon Trunk Lid~JDM Map~Self-Tuned-30psi
::My car on car domain here:: along with Evo/DSM Shoot Out and Some pics many more to come.
Offline
Mar 13, 2008, 03:13 AM
#45
Drives: VI TME
__________________
EVO 2. VI TME
Offline
Tags
auto, body, eclipsie, engineering, good, intake, ku, kuengineering, manifld, manifold, manifolds, performance, plenum, throttle, wrx  |
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
HTML code is Off
